Vida CEM swapping
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
T5Luke wrote: 28 Apr 2021, 17:40 CB 50 B9 F7 would give you the serial number in normal operation mode, maybe it is enough.
Nope... Read B9 F6 too, out of curiosity.
What B9 opcode stands for?
Code: Select all
CAN_HS ---> ID=000ffffe data=cb 50 b9 f7 00 00 00 00
CAN_HS <--- ID=01000003 data=cc 50 7f b9 22 00 00 00
CAN_HS ---> ID=000ffffe data=cb 50 b9 f6 00 00 00 00
CAN_HS <--- ID=01000003 data=cc 50 7f b9 12 00 00 00
This is a brick-shaped CEM.
vtl
Post by vtl »
B9 FB gets lot of data, VIN included. Found it in my old DiCE logs:
Code: Select all
02:42:50,578 0100 000004 PassThruWriteMsgs() msg[0].Data = [0x00, 0xf, 0xff, 0xfe, 0xcb, 0x50, 0xb9, 0xfb, 0x00, 0x00, 0x00, 0x00]
02:42:50,640 0100 000004 PassThruReadMsgs() msg[0].Data = [0x01, 0x20, 0x00, 0x03, 0x8f, 0x50, 0xf9, 0xfb, 0x57, 0x00, 0x30, 0x66]
02:42:50,640 0100 000004 PassThruReadMsgs() msg[0].Data = [0x01, 0x20, 0x00, 0x03, 0x09, 0x70, 0x28, 0x30, 0x30, 0x35, 0x0d, 0x0a]
02:42:50,640 0100 000004 PassThruReadMsgs() msg[0].Data = [0x01, 0x20, 0x00, 0x03, 0x0a, 0x59, 0x56, 0x31, 0x53, 0x5a, 0x35, 0x39]
02:42:50,656 0100 000004 PassThruReadMsgs() msg[0].Data = [0x01, 0x20, 0x00, 0x03, 0x0b, 0x32, 0x32, 0x35, 0x31, 0x31, 0x39, 0x38]
02:42:50,671 0100 000004 PassThruReadMsgs() msg[0].Data = [0x01, 0x20, 0x00, 0x03, 0x0c, 0x36, 0x32, 0x35, 0x0d, 0x0a, 0x32, 0x35]
02:42:50,687 0100 000004 PassThruReadMsgs() msg[0].Data = [0x01, 0x20, 0x00, 0x03, 0x0d, 0x31, 0x35, 0x36, 0x38, 0x39, 0x35, 0x32]
02:42:50,687 0100 000004 PassThruReadMsgs() msg[0].Data = [0x01, 0x20, 0x00, 0x03, 0x0e, 0x0d, 0x0a, 0x32, 0x39, 0x35, 0x0d, 0x0a]
02:42:50,703 0100 000004 PassThruReadMsgs() msg[0].Data = [0x01, 0x20, 0x00, 0x03, 0xf, 0x31, 0x39, 0x38, 0x36, 0x32, 0x35, 0x0d]
02:42:50,718 0100 000004 PassThruReadMsgs() msg[0].Data = [0x01, 0x20, 0x00, 0x03, 0x08, 0x0a, 0x32, 0x31, 0x0d, 0x0a, 0x32, 0x30]
02:42:50,734 0100 000004 PassThruReadMsgs() msg[0].Data = [0x01, 0x20, 0x00, 0x03, 0x09, 0x30, 0x35, 0x31, 0x32, 0x0d, 0x0a, 0x30]
02:42:50,750 0100 000004 PassThruReadMsgs() msg[0].Data = [0x01, 0x20, 0x00, 0x03, 0x0a, 0x30, 0x30, 0x30, 0x34, 0x33, 0x33, 0x38]
02:42:50,765 0100 000004 PassThruReadMsgs() msg[0].Data = [0x01, 0x20, 0x00, 0x03, 0x0b, 0x36, 0x30, 0x34, 0x30, 0x38, 0x32, 0x32]
02:42:50,781 0100 000004 PassThruReadMsgs() msg[0].Data = [0x01, 0x20, 0x00, 0x03, 0x4f, 0x30, 0x36, 0x39, 0x33, 0x31, 0x0d, 0x0a]
vtl
Post by vtl »
vtl wrote: 28 Apr 2021, 19:12 What B9 opcode stands for?
Service B9 == Read Data Block By Offset?
vtl
Post by vtl »
The part number:
Code: Select all
CAN_HS ---> ID=000ffffe data=cb 50 b9 f0 00 00 00 00
CAN_HS <--- ID=01000003 data=8f 50 f9 f0 00 08 68 85
CAN_HS <--- ID=01000003 data=09 13 20 20 41 30 65 70
CAN_HS <--- ID=01000003 data=4c 24 20 20 41 00 00 00
First byte in reply is a technical field, like rolling counter, start (0x80)/end(0x40 flag of the multipart message, etc. The P/N is:
08 68 85 13 == 8688513
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
Code: Select all
From Olaf's blog.
A1 No Operation Performed (keep alive)
A3 Security Access Mode
A5 Read Current Data By Offset
A6 Read Current Data By Identifier
A7 Read Current Data By Address
A8 Set Data Transmission
A9 Stop Data Transmission
AA Dynamically Define Record
AB Read Freeze Frame Data By Offset
AC Read Freeze Frame
AD Read Freeze Frame By DTC
AE Read DTC
AF Clear DTC
B0 Input Output Control By Offset
B1 Input Output Control By Identifier
B2 Control Routine By Offset
B4 Define Read Write ECU data
B8 Write Data Block By Offset
B9 Read Data Block By Offset
BA Write Data Block By Address
BB Read Data Block By Address
Active
Past
vtl
Post by vtl »
RickHaleParker wrote: 28 Apr 2021, 20:57 From Olaf's blog.
Yeah, I could not remember where I saw that and had to fire up the VM w/ VIDA and find the description in MSSQL DB.
Unfortunately, B9 is served only on CAN-HS :( CB 40 B9 F0 does nothing on CAN-LS. Ah, stupid me, the reply comes from different ID. Need to sleep more.
vtl
Post by vtl »
Cracking session with CEM type autodetected (no more ifdefs):
Code: Select all
CPU Maximum Frequency:   600000000
CPU Frequency:           600000000
Execution Rate:          600 cycles/us
PIN bytes to measure:    3
Number of samples:       30
CAN low-speed init done.
Reading part number from ECU 0x40 on CAN_LS
CAN_LS ---> ID=000ffffe data=cb 40 b9 f0 00 00 00 00
Part Number: 8688513
Searching P/N 8688513 in 49 known CEMs
CAN HS baud rate: 250000
PIN shuffle order: 0 1 2 3 4 5
CAN high-speed init done.
Putting all ECUs on CAN_HS into programming mode.
CAN_HS ---> ID=000ffffe data=ff 86 00 00 00 00 00 00
Reading part number from ECU 0x50 on CAN_HS
CAN_HS ---> ID=000ffffe data=50 88 00 00 00 00 00 00
CAN_HS <--- ID=00000003 data=50 8e 00 00 08 68 85 13
Initialization done.
Calculating bytes 0-2
1000 pins in 1356 ms, 737 pins/s, average response: 255 us, histogram 127 to 382 us
                   us:   247   248   249   250   251   252   253   254   255   256   257   258   259   260   261   262   263   264   265   266
[ 00 -- -- -- -- -- ]:     0  1051     0     0     0     0     0     0     0   430     0     0     0     0     0     0     0  1518     0     0 :     390607; best 00 is less than 00 by 390607
[ 01 -- -- -- -- -- ]:     0  1756     0     0     0     0     0     0     0   448     0     0     0     0     0     0     0   796     0     0 :     379320; best 00 is greater than 01 by 11287
[ 02 -- -- -- -- -- ]:     0  1700     0     0     0     0     0     0     0   462     0     0     0     0     0     0     0   836     0     0 :     379830; best 00 is greater than 02 by 10777
I pushed the WIP changes into branch "rework" if anybody is interested. It has no ifdefs, no MCP2515 support, no Teensy 3.x support.
bosse
Year and Model: V50 -11
Has thanked: 9 times
Post by bosse »
In dha there is all comands and can adresses.
But i guess you all have it already.
vtl
Post by vtl »
What is dha?
lukas743
Year and Model: S60 2002
Has thanked: 1 time
Post by lukas743 »
vtl wrote: 29 Apr 2021, 04:59What is dha?
It is mini version of VIDA :) with visible CAN Bus frames.
Last post has download link:
