Black plastic cloth under stone. Stone is about 6 inches deep. Bought too much, you can see excess at end of walk.
That means….another sidewalk!
I had that bluestone as “scrap” in the backyard. That material cost about $2500 if I had to buy it
What non automotive projects and repairs are you doing?
Forum rules
- Has thanked: 1611 times
- Been thanked: 4072 times
- Has thanked: 987 times
- Been thanked: 1078 times
Send me your excess. I need to make a side walk to my new generator shed.
For $170 the Amazon purchased 'building in a box' is not bad. About 75 pounds of thin gauge steel and plastic assembled into a reasonably sturdy 3.5 x 6 foot shed. I had concern it would blow away in a gust of wind so I made a base of concrete and blocks to anchor the building. Assembly is nearly complete. Only need to add the double doors.
Power wash and paint a badly peeling southern exposure wall….not quite done but off the roof and ladder !
Finished that gutter…not too hateful
Pro question. Do you gals/guys ABS cement gutters ? Which pieces ??
I still use Aluminum downspouts with sheet metal screws. At some time you will have to remove the downspout to paint or something.
I finished the little generator shed. The double doors don't fit great, but they open and close. I added 3/16 steel plates under the corner anchor bolts to spread the load on the thin metal base plate. I don't think it will fly away now in any normal winds.
I still need to add a floor. Likely will use paving stones on sand base.
My electrician has a worker with a child in hospital so electrical work is on hold.
I’m going to glue everything except the top downspout. Ss screw there, so I can remove downspout as neededvolvolugnut wrote: 07 Oct 2025, 15:50 I still use Aluminum downspouts with sheet metal screws. At some time you will have to remove the downspout to paint or something.
Finished the south wall painting, rain today !
What do they call that kind of siding in your part of the world?
Cedar shakes. It’s very thin wood with a lot of structure running vertical, like grooves. Very common in New England
- Sveedy
- Has thanked: 445 times
- Been thanked: 479 times
I don't think gutter downspouts are supposed to be glued, but you might check with the manufacture/supplier to be sure.
1999 V70 GLT
1999 V70 GLT
