2004 XC70 no start - faulty fuel pump and/or electrical connections? Topic is solved
- Been thanked: 4064 times
I’m going to push you away from the “ junk in tank diagnosis”. You don’t get crap in fuel anymore unless someone hates you and puts it in your tank directly, likewise for plugged fuel filters.
enotslim
- Year and Model: 2004 XC70
- Has thanked: 71 times
- Been thanked: 16 times
"Old junk" hanging around in a 19-year-old car and finally causing problems? Does the inlet really have an impeller that can fail? Is it powered? I have everything needed to disassemble/reassemble the entire fuel pump unit (but not replacement parts). Replacement won't answer the question without a diagnosis.abscate wrote: 16 Aug 2023, 02:13 I’m going to push you away from the “ junk in tank diagnosis”. You don’t get crap in fuel anymore unless someone hates you and puts it in your tank directly, likewise for plugged fuel filters.
I could drive it two floors down into the parking lot at work hoping it will fail.
Now:
2004 XC70
Then:
1972 144
1988 240 Wagon
1998 V70 T5
2004 XC70
Then:
1972 144
1988 240 Wagon
1998 V70 T5
Danalberto231
- Year and Model: 1989
I also think I read that the PEM was introduced to the XC70 sometime during the 2004 model year. Maybe my 2004 XC70 is pre-PEM? Would a VIN lookup provide that info? How about a scan tool?
Hubspot partner agency
Mehendi designs
Mehendi designs
enotslim
I don't remember finding any information via the VIN or using a scan tool about presence or absence of the PEM in my 2004 XC70. I never found one by looking in all the known locations as described earlier in this thread. Vida/DiCE seems like it might provide info about the presence/absence of a PEM. I have Vida but not DiCE so I can't try this. Does someone know for certain? As in have you detected lack (especially) and/or presence of a PEM this way?
Now:
2004 XC70
Then:
1972 144
1988 240 Wagon
1998 V70 T5
2004 XC70
Then:
1972 144
1988 240 Wagon
1998 V70 T5
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 532 times
2003 and up it should have a pem. jack up and use jackstand,enotslim wrote: 19 Aug 2023, 08:00 I don't remember finding any information via the VIN or using a scan tool about presence or absence of the PEM in my 2004 XC70. I never found one by looking in all the known locations as described earlier in this thread. Vida/DiCE seems like it might provide info about the presence/absence of a PEM. I have Vida but not DiCE so I can't try this. Does someone know for certain? As in have you detected lack (especially) and/or presence of a PEM this way?
passenger side of tank, looking up it sits on top of tank peeping out.
goldxc70
- Year and Model: XC70 2004
- Has thanked: 27 times
- Been thanked: 3 times
I believe this is correct. Some 2004 models do not have PEM while some later models do. I double checked this with my indy Volvo shop (long time Volvo tech).Danalberto231 wrote: 17 Aug 2023, 06:53 I also think I read that the PEM was introduced to the XC70 sometime during the 2004 model year. Maybe my 2004 XC70 is pre-PEM? Would a VIN lookup provide that info? How about a scan tool?
Mehendi designs
goldxc70
In my case, thhe pump itself appeared to be fine but the fuel pickup/impeller appeared to have failed. I can't say of this was caused by wear or contamination in the fuel but it was definitely not free to spin as the new one was.enotslim wrote: 15 Aug 2023, 20:51 ...Can the fuel pickup/impeller/(not a siphon) be serviced? Blocked by "stones" that presumably precipitate from contaminants in the tank?
- jonesg
i ran my old volvo on fumes too often and burned the pump up.goldxc70 wrote: 04 Sep 2023, 09:20In my case, thhe pump itself appeared to be fine but the fuel pickup/impeller appeared to have failed. I can't say of this was caused by wear or contamination in the fuel but it was definitely not free to spin as the new one was.enotslim wrote: 15 Aug 2023, 20:51 ...Can the fuel pickup/impeller/(not a siphon) be serviced? Blocked by "stones" that presumably precipitate from contaminants in the tank?
- Has thanked: 311 times
- Been thanked: 817 times
My 07 XC70 I was troubleshooting the PEM and I didn’t the PEM anywhere in VIDA.enotslim wrote: 19 Aug 2023, 08:00 I don't remember finding any information via the VIN or using a scan tool about presence or absence of the PEM in my 2004 XC70. I never found one by looking in all the known locations as described earlier in this thread. Vida/DiCE seems like it might provide info about the presence/absence of a PEM. I have Vida but not DiCE so I can't try this. Does someone know for certain? As in have you detected lack (especially) and/or presence of a PEM this way?
- 949 Views
Last post by Chriskelly1962
- 5996 Views
Last post by misha
- 2278 Views
Last post by wahiddd
- 636 Views
- 621 Views
Last post by Bigbishop
