MrAl
Year and Model: v70, 1998
Has thanked: 83 times
Been thanked: 73 times
Post by MrAl »
Hi,
I drove it around town ha ha. I dont drive as much as i used to so it's a special occasion for me :-)
Along the way though i saw a couple older Volvos. I really like the look of those. For some reason i like the 'boxy' look of those slightly older models, not sure what year they are, but they are really cool i think. I would guess they are v70's too because they are the station wagons. I kinda wish i had one of those, but the older model may mean more mechanical problems and availability of parts.
I would think Volvo would do well to make sure parts for older cars are still available and that would speak loudly to their longevity which would be good for sales i would think. I dont have any statistics on hand though.
Thanks for reading. To those that didnt read, thanks for thinking about reading :-)
kallekula
Year and Model: S70 2000
Has thanked: 58 times
Been thanked: 75 times
Post by kallekula »
I replaced my pedal position sensor. Old one showed intermittent ohm values. Bet it was also a cause of my lousy brakes. Car feels more secure to drive now 😃
BMW 540i 2002
S70 Base 2000
Has thanked: 1504 times
Been thanked: 3817 times
kallekula wrote: 13 Aug 2022, 02:32 I replaced my pedal position sensor. Old one showed intermittent ohm values. Bet it was also a cause of my lousy brakes. Car feels more secure to drive now 😃
Is this the one mounted in the brake booster? 9441116
kallekula
Post by kallekula »
Correct
BMW 540i 2002
S70 Base 2000
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 417 times
Been thanked: 457 times
Post by Sveedy »
Got to use my new wheel cribs - Love them !
I needed to change my downpipe and exhaust, as well as the exhaust flange on the turbo, and these made the job much easier. I could spin around on the creeper without hitting any jack stands, and these actually bring the car up about 2" - 3" higher than my jack stands could at their very highest setting ( which I would never feel comfortable with ). I had the entire exhaust system out in about 30 min.
Since I only needed small 2 x 4 blocks, I was able to buy warped rejects from Home Depot for about $ 1 per 8ft stick. I made the cribs 2 piece, so I can raise the car 6" at a time per side. Ended up with apx 18" + clearance.
1999 V70 GLT
BlackBart
Has thanked: 927 times
Been thanked: 884 times
Post by BlackBart »
Did you screw them together?
Sveedy
Post by Sveedy »
But of course :) 3" screws from both directions, whenever possible. Thought about glue, but I think that would be over kill, as most everything is downward force anyway.
1999 V70 GLT
Goupil
Year and Model: 98' V70 LPT
Has thanked: 30 times
Been thanked: 112 times
Post by Goupil »
Got the head off despite a work call that took some time and some proper heat (the cold garage floor has never been so welcoming :mrgreen: )
Realised I forgot the seal for the water pipe at the back of the head in my skandix order :(
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
Goupil wrote: 13 Aug 2022, 15:12 Realised I forgot the seal for the water pipe at the back of the head in my skandix order :(
Ah yes... every time!
FireFox31
Has thanked: 158 times
Been thanked: 300 times
Post by FireFox31 »
Sveedy wrote: 13 Aug 2022, 11:56 Got to use my new wheel cribs - Love them !
Those don't look safe enough to me. Each wheel has all its weight on two 2x4s. I would feel much more comfortable having the front and rear be a solid stack of 2x4s to the ground to transfer that weight all the way down. Short pieces could be screwed in between the ends of the side pieces. Similar filler pieces probably aren't needed on the sides. Photoshop attached.
FireFox31
