Part Number: 30795115
Searching P/N 30795115 in 49 known CEMs
Candidate PIN 94 53 06 -- -- -- : brute forcing bytes 3 to 5 (3 bytes), will take up to 640 seconds
Progress: 0%..5%..10%..15%..20%..25%..30%..35%..40%..45%..50%..55%..60%..65%..70%..75%..80%..85%..90%..95%..
PIN is NOT cracked in 1220.88 seconds
done
Resetting all ECUs.
first two ok, third - no
94 53 85 25 40 55
Vida CEM swapping
vtl
- Year and Model: 2005 XC70
- Has thanked: 129 times
- Been thanked: 686 times
Thanks. Do you have a dump for that CEM?solitaire wrote: 03 May 2021, 01:21 Part Number: 30795115
done
Resetting all ECUs.
94 53 85 25 40 55
esbekir
- Year and Model: 850R 1996
- Has thanked: 2 times
hi friend,
The code is working on p2.
vtl
sample 30
bench.
sample 30
bench.
p2 ok log.docx- (21.74 KiB) Downloaded 232 times
esbekir
here is another p2.
successful.
CPU Maximum Frequency: 600000000
CPU Frequency: 600000000
Execution Rate: 600 cycles/us
PIN bytes to measure: 3
Number of samples: 30
CAN low-speed init done.
Reading part number from ECU 0x40 on CAN_LS
CAN_LS ---> ID=000ffffe data=cb 40 b9 f0 00 00 00 00
Can't find part number on CAN-LS, trying CAN-HS at 500 Kbps
CAN high-speed init done.
Reading part number from ECU 0x50 on CAN_HS
CAN_HS ---> ID=000ffffe data=cb 50 b9 f0 00 00 00 00
Part Number: 30765149
Searching P/N 30765149 in 49 known CEMs
CAN HS baud rate: 500000
PIN shuffle order: 3 1 5 0 2 4
Putting all ECUs into programming mode.
CAN_HS ---> ID=000ffffe data=ff 86 00 00 00 00 00 00
CAN_LS ---> ID=000ffffe data=ff 86 00 00 00 00 00 00
Initialization done.
Calculating bytes 0-2
1000 pins in 639 ms, 1564 pins/s, average response: 86 us, histogram 43 to 129 us
us: 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97
[ 00 -- -- -- -- -- ]: 0 0 0 0 0 0 195 0 1311 0 1325 1 165 0 0 0 0 0 0 0 : latency 131794; std 393.10
[ 01 -- -- -- -- -- ]: 0 0 0 0 0 0 180 0 1292 0 1300 0 228 0 0 0 0 0 0 0 : latency 132152; std 386.89
[ 02 -- -- -- -- -- ]: 0 0 0 0 0 1 140 0 1361 1 1314 0 183 0 0 0 0 0 0 0 : latency 132078; std 398.87
[ 03 -- -- -- -- -- ]: 0 0 0 0 0 0 140 0 1376 0 1305 0 179 0 0 0 0 0 0 0 : latency 132046; std 399.88
[ 04 -- -- -- -- -- ]: 0 0 0 0 0 0 137 0 1419 1 1259 0 181 0 0 0 0 0 0 0 : latency 131840; std 400.07
[ 05 -- -- -- -- -- ]: 0 0 0 0 0 0 156 2 1386 0 1286 0 170 0 0 0 0 0 0 0 : latency 131938; std 398.62
[ 06 -- -- -- -- -- ]: 0 0 0 0 0 0 158 0 1423 1 1236 0 182 0 0 0 0 0 0 0 : latency 131885; std 397.54
[ 07 -- -- -- -- -- ]: 0 0 0 0 0 1 135 0 1422 0 1276 0 163 0 0 0 0 0 0 0 : latency 131802; std 402.86
[ 08 -- -- -- -- -- ]: 0 0 0 0 0 0 140 0 1410 0 1277 1 172 0 0 0 0 0 0 0 : latency 131965; std 401.12
[ 09 -- -- -- -- -- ]: 0 0 0 0 0 0 134 0 1453 0 1251 0 162 0 0 0 0 0 0 0 : latency 131882; std 404.38
[ 10 -- -- -- -- -- ]: 0 0 0 0 0 0 133 0 1375 0 1279 0 213 0 0 0 0 0 0 0 : latency 132144; std 396.20
[ 11 -- -- -- -- -- ]: 0 0 0 0 0 0 118 1 1439 0 1283 0 156 0 0 0 0 0 0 0 : latency 131824; std 406.57
[ 12 -- -- -- -- -- ]: 0 0 0 0 0 0 141 0 1417 0 1263 0 179 0 0 0 0 0 0 0 : latency 131960; std 400.31
[ 13 -- -- -- -- -- ]: 0 0 0 0 0 0 132 0 1447 0 1257 0 164 0 0 0 0 0 0 0 : latency 131906; std 404.24
[ 14 -- -- -- -- -- ]: 0 0 0 0 0 0 145 0 1421 0 1256 0 178 0 0 0 0 0 0 0 : latency 131934; std 399.97
[ 15 -- -- -- -- -- ]: 0 0 0 0 0 0 130 1 1471 0 1244 0 151 0 0 0 0 0 0 0 : latency 131702; std 406.32
[ 16 -- -- -- -- -- ]: 0 0 0 0 0 0 116 0 1445 0 1273 0 166 0 0 0 0 0 0 0 : latency 131978; std 406.18
[ 17 -- -- -- -- -- ]: 0 0 0 0 0 0 127 0 1427 0 1296 0 150 0 0 0 0 0 0 0 : latency 131938; std 406.48
[ 18 -- -- -- -- -- ]: 0 0 0 0 0 0 128 0 1442 2 1262 0 163 0 0 0 0 0 0 0 : latency 131793; std 404.10
[ 19 -- -- -- -- -- ]: 0 0 0 0 0 0 129 1 1476 0 1238 0 156 0 0 0 0 0 0 0 : latency 131841; std 406.34
[ 20 -- -- -- -- -- ]: 0 0 0 0 0 0 159 0 1315 0 1293 0 233 0 0 0 0 0 0 0 : latency 132200; std 389.27
[ 21 -- -- -- -- -- ]: 0 0 0 0 0 0 94 0 1406 0 1229 0 271 0 0 0 0 0 0 0 : latency 132354; std 394.94
[ 22 -- -- -- -- -- ]: 0 0 0 0 0 0 133 0 1433 0 1260 0 171 0 0 0 0 0 0 0 : latency 131809; std 402.43
[ 23 -- -- -- -- -- ]: 0 0 0 0 0 0 106 1 1505 0 1238 0 150 0 0 0 0 0 0 0 : latency 131863; std 411.18
[ 24 -- -- -- -- -- ]: 0 0 0 0 0 0 121 0 1400 0 1295 0 184 0 0 0 0 0 0 0 : latency 132084; std 402.21
[ 25 -- -- -- -- -- ]: 0 0 0 0 0 0 107 0 1517 0 1215 0 161 0 0 0 0 0 0 0 : latency 131860; std 410.18
[ 26 -- -- -- -- -- ]: 0 0 0 0 0 0 120 0 1465 1 1245 0 166 0 0 0 0 0 0 0 : latency 131786; std 405.53
[ 27 -- -- -- -- -- ]: 0 0 0 0 0 0 111 0 1492 0 1254 0 143 0 0 0 0 0 0 0 : latency 131858; std 411.18
[ 28 -- -- -- -- -- ]: 0 0 0 0 0 0 132 1 1454 0 1249 0 164 0 0 0 0 0 0 0 : latency 131889; std 404.25
[ 29 -- -- -- -- -- ]: 0 0 0 0 0 0 99 0 1491 1 1269 1 136 0 0 0 0 0 0 0 : latency 131759; std 413.08
[ 30 -- -- -- -- -- ]: 0 0 0 0 0 0 154 0 1389 0 1252 0 205 0 0 0 0 0 0 0 : latency 132016; std 394.50
[ 31 -- -- -- -- -- ]: 0 0 0 0 0 0 129 0 1439 0 1280 0 152 0 0 0 0 0 0 0 : latency 131910; std 406.13
[ 32 -- -- -- -- -- ]: 0 0 0 0 0 0 112 0 1459 0 1276 0 153 0 0 0 0 0 0 0 : latency 131940; std 408.83
[ 33 -- -- -- -- -- ]: 0 0 0 0 0 0 104 0 1485 0 1259 1 148 0 0 0 0 0 0 0 : latency 131776; std 410.73
[ 34 -- -- -- -- -- ]: 0 0 0 0 0 0 129 0 1415 0 1279 0 177 0 0 0 0 0 0 0 : latency 132008; std 402.25
[ 35 -- -- -- -- -- ]: 0 0 0 0 0 0 129 0 1463 0 1240 0 168 0 0 0 0 0 0 0 : latency 131894; std 404.53
[ 36 -- -- -- -- -- ]: 0 0 0 0 0 1 134 0 1418 1 1287 0 159 0 0 0 0 0 0 0 : latency 131940; std 403.75
[ 37 -- -- -- -- -- ]: 0 0 0 0 0 0 115 0 1458 1 1270 0 153 0 0 0 0 0 0 0 : latency 131794; std 407.81
[ 38 -- -- -- -- -- ]: 0 0 0 0 0 0 133 0 1407 0 1279 0 181 0 0 0 0 0 0 0 : latency 132016; std 401.00
[ 39 -- -- -- -- -- ]: 0 0 0 0 0 0 122 0 1486 0 1231 0 161 0 0 0 0 0 0 0 : latency 131862; std 407.08
[ 40 -- -- -- -- -- ]: 0 0 0 0 0 0 143 1 1320 0 1340 0 193 0 0 0 0 0 0 0 : latency 132036; std 396.65
[ 41 -- -- -- -- -- ]: 0 0 0 0 0 0 137 0 1403 0 1282 0 178 0 0 0 0 0 0 0 : latency 132002; std 400.77
[ 42 -- -- -- -- -- ]: 0 0 0 0 0 0 149 0 1396 0 1283 0 172 0 0 0 0 0 0 0 : latency 131956; std 399.79
[ 43 -- -- -- -- -- ]: 0 0 0 0 0 0 147 2 1356 0 1326 0 169 0 0 0 0 0 0 0 : latency 132032; std 399.82
[ 44 -- -- -- -- -- ]: 0 0 0 0 0 0 159 0 1372 0 1296 0 170 0 0 0 0 0 0 0 : latency 131825; std 397.94
[ 45 -- -- -- -- -- ]: 0 0 0 0 0 0 127 0 1367 0 1324 0 182 0 0 0 0 0 0 0 : latency 132122; std 401.31
[ 46 -- -- -- -- -- ]: 0 0 0 0 0 0 141 0 1364 0 1311 0 184 0 0 0 0 0 0 0 : latency 132076; std 398.93
[ 47 -- -- -- -- -- ]: 0 0 0 0 0 0 136 0 1373 1 1288 0 202 0 0 0 0 0 0 0 : latency 132113; std 397.08
[ 48 -- -- -- -- -- ]: 0 0 0 0 0 0 123 0 1382 0 1311 0 181 0 0 0 0 0 0 0 : latency 131971; std 401.71
[ 49 -- -- -- -- -- ]: 0 0 0 0 0 1 138 0 1384 1 1295 0 181 0 0 0 0 0 0 0 : latency 132036; std 399.64
[ 50 -- -- -- -- -- ]: 0 0 0 0 0 0 127 0 1404 0 1282 0 187 0 0 0 0 0 0 0 : latency 132058; std 400.99
[ 51 -- -- -- -- -- ]: 0 0 0 0 0 1 137 1 1369 1 1323 0 165 0 0 0 0 0 0 0 : latency 131900; std 401.34
[ 52 -- -- -- -- -- ]: 0 0 0 0 0 0 138 0 1344 1 1324 0 193 0 0 0 0 0 0 0 : latency 132145; std 397.84
[ 53 -- -- -- -- -- ]: 0 0 0 0 0 0 140 0 1364 1 1339 0 156 0 0 0 0 0 0 0 : latency 132023; std 402.95
[ 54 -- -- -- -- -- ]: 0 0 0 0 0 0 134 0 1338 0 1368 0 160 0 0 0 0 0 0 0 : latency 132108; std 403.44
[ 55 -- -- -- -- -- ]: 0 0 0 0 0 0 135 0 1373 0 1314 0 175 0 0 0 0 0 0 0 : latency 131929; std 400.72
[ 56 -- -- -- -- -- ]: 0 0 0 0 0 0 146 0 1379 0 1299 0 176 0 0 0 0 0 0 0 : latency 132010; std 399.46
[ 57 -- -- -- -- -- ]: 0 0 0 0 0 0 141 0 1403 0 1275 0 181 0 0 0 0 0 0 0 : latency 131992; std 399.79
[ 58 -- -- -- -- -- ]: 0 0 0 0 0 0 130 1 1418 1 1257 0 193 0 0 0 0 0 0 0 : latency 132026; std 399.68
[ 59 -- -- -- -- -- ]: 0 0 0 0 0 0 139 0 1379 0 1299 0 180 0 0 0 0 0 0 0 : latency 131911; std 399.48
[ 60 -- -- -- -- -- ]: 0 0 0 0 0 0 135 0 1443 1 1231 0 190 0 0 0 0 0 0 0 : latency 131953; std 400.12
[ 61 -- -- -- -- -- ]: 0 0 0 0 0 1 132 1 1329 0 1343 0 194 0 0 0 0 0 0 0 : latency 132194; std 398.43
[ 62 -- -- -- -- -- ]: 0 0 0 0 0 0 113 0 1404 1 1314 0 165 0 0 0 0 0 0 0 : latency 131934; std 405.51
[ 63 -- -- -- -- -- ]: 0 0 0 0 0 1 119 0 1363 0 1340 0 177 0 0 0 0 0 0 0 : latency 132147; std 403.04
[ 64 -- -- -- -- -- ]: 0 0 0 0 0 0 128 0 1392 0 1305 0 175 0 0 0 0 0 0 0 : latency 132054; std 402.35
[ 65 -- -- -- -- -- ]: 0 0 0 0 0 0 141 0 1325 0 1370 0 164 0 0 0 0 0 0 0 : latency 132114; std 401.83
[ 66 -- -- -- -- -- ]: 0 0 0 0 0 0 140 0 1351 0 1346 0 160 0 0 0 0 0 0 0 : latency 131923; std 402.06
[ 67 -- -- -- -- -- ]: 0 0 0 0 0 0 147 0 1316 0 1358 0 179 0 0 0 0 0 0 0 : latency 132138; std 398.73
[ 68 -- -- -- -- -- ]: 0 0 0 0 0 0 154 0 1332 0 1327 0 187 0 0 0 0 0 0 0 : latency 132094; std 396.47
[ 69 -- -- -- -- -- ]: 0 0 0 0 0 0 132 0 1337 0 1356 0 175 0 0 0 0 0 0 0 : latency 132148; std 401.52
[ 70 -- -- -- -- -- ]: 0 0 0 0 0 0 176 0 1348 0 1307 0 166 0 0 0 0 0 0 0 : latency 131797; std 395.90
[ 71 -- -- -- -- -- ]: 0 0 0 0 0 0 133 1 1363 3 1330 0 170 0 0 0 0 0 0 0 : latency 132076; std 401.45
[ 72 -- -- -- -- -- ]: 0 0 0 0 0 0 157 0 1330 1 1332 0 180 0 0 0 0 0 0 0 : latency 132071; std 396.87
[ 73 -- -- -- -- -- ]: 0 0 0 0 0 0 134 0 1369 0 1309 0 185 0 0 0 0 0 0 0 : latency 131961; std 399.42
[ 74 -- -- -- -- -- ]: 0 0 0 0 0 0 134 0 1344 0 1351 0 171 0 0 0 0 0 0 0 : latency 132118; std 401.79
[ 75 -- -- -- -- -- ]: 0 0 0 0 0 0 139 1 1351 0 1329 0 180 0 0 0 0 0 0 0 : latency 132099; std 399.57
[ 76 -- -- -- -- -- ]: 0 0 0 0 0 0 138 0 1374 0 1304 0 184 0 0 0 0 0 0 0 : latency 132068; std 399.45
[ 77 -- -- -- -- -- ]: 0 0 0 0 0 0 118 0 1356 0 1350 0 173 0 0 0 0 0 0 0 : latency 132027; std 403.49
[ 78 -- -- -- -- -- ]: 0 0 0 0 0 0 130 0 1391 0 1328 0 151 0 0 0 0 0 0 0 : latency 132000; std 405.47
[ 79 -- -- -- -- -- ]: 0 0 0 0 0 0 152 0 1344 0 1309 0 195 0 0 0 0 0 0 0 : latency 132094; std 395.66
[ 80 -- -- -- -- -- ]: 0 0 0 0 0 1 144 0 1423 1 1244 0 187 0 0 0 0 0 0 0 : latency 131946; std 398.63
[ 81 -- -- -- -- -- ]: 0 0 0 0 0 0 125 0 1447 1 1226 0 198 0 0 0 0 0 0 0 : latency 131866; std 400.16
[ 82 -- -- -- -- -- ]: 0 0 0 0 0 1 156 0 1428 1 1247 0 167 0 0 0 0 0 0 0 : latency 131848; std 399.78
[ 83 -- -- -- -- -- ]: 0 0 0 0 0 0 130 0 1452 0 1256 0 162 0 0 0 0 0 0 0 : latency 131900; std 404.91
[ 84 -- -- -- -- -- ]: 0 0 0 0 0 0 145 2 1335 0 1329 0 189 0 0 0 0 0 0 0 : latency 132122; std 397.19
[ 85 -- -- -- -- -- ]: 0 0 0 0 0 0 137 0 1322 1 1334 0 203 0 0 0 0 0 0 0 : latency 132078; std 396.11
[ 86 -- -- -- -- -- ]: 0 0 0 0 0 0 152 0 1261 1 1399 0 187 0 0 0 0 0 0 0 : latency 132243; std 397.20
[ 87 -- -- -- -- -- ]: 0 0 0 0 0 0 138 1 1332 0 1355 0 174 0 0 0 0 0 0 0 : latency 132129; std 400.60
[ 88 -- -- -- -- -- ]: 0 0 0 0 0 0 139 0 1337 1 1345 0 175 0 0 0 0 0 0 0 : latency 131984; std 399.84
[ 89 -- -- -- -- -- ]: 0 0 0 0 0 0 135 0 1313 0 1360 0 192 0 0 0 0 0 0 0 : latency 132218; std 398.66
[ 90 -- -- -- -- -- ]: 0 0 0 0 0 0 149 0 1373 0 1316 0 162 0 0 0 0 0 0 0 : latency 131982; std 400.96
[ 91 -- -- -- -- -- ]: 0 0 0 0 0 0 134 1 1281 1 1391 0 192 0 0 0 0 0 0 0 : latency 132282; std 398.79
[ 92 -- -- -- -- -- ]: 0 0 0 0 0 0 129 0 1346 0 1339 0 183 0 0 0 0 0 0 0 : latency 132023; std 400.35
[ 93 -- -- -- -- -- ]: 0 0 0 0 0 1 153 0 1285 0 1386 0 175 0 0 0 0 0 0 0 : latency 132163; std 398.51
[ 94 -- -- -- -- -- ]: 0 0 0 0 0 0 154 0 1333 1 1337 0 175 0 0 0 0 0 0 0 : latency 132067; std 398.05
[ 95 -- -- -- -- -- ]: 0 0 0 0 0 0 131 0 1337 0 1349 0 183 0 0 0 0 0 0 0 : latency 132168; std 400.50
[ 96 -- -- -- -- -- ]: 0 0 0 0 0 0 136 2 1289 0 1379 0 191 0 0 0 0 0 0 0 : latency 132119; std 398.06
[ 97 -- -- -- -- -- ]: 0 0 0 0 0 0 134 1 1323 1 1365 0 176 0 0 0 0 0 0 0 : latency 132166; std 400.78
[ 98 -- -- -- -- -- ]: 0 0 0 0 0 0 130 0 1295 2 1375 0 198 0 0 0 0 0 0 0 : latency 132284; std 398.36
[ 99 -- -- -- -- -- ]: 0 0 0 0 0 0 123 0 1330 0 1339 0 204 0 0 0 0 0 0 0 : latency 132076; std 398.11
best candidates ordered by latency:
0: 21 lat = 132354
1: 98 lat = 132284
2: 91 lat = 132282
3: 86 lat = 132243
4: 89 lat = 132218
95: 18 lat = 131793
96: 26 lat = 131786
97: 33 lat = 131776
98: 29 lat = 131759
99: 15 lat = 131702
best candidates ordered by std:
0: 29 std = 413.08
1: 23 std = 411.18
2: 27 std = 411.18
3: 33 std = 410.73
4: 25 std = 410.18
95: 21 std = 394.94
96: 30 std = 394.50
97: 00 std = 393.10
98: 20 std = 389.27
99: 01 std = 386.89
lat_k 0.05%, std_k 0.46%
pin[0] choose candidate: 21 based on latency
[ 21 00 -- -- -- -- ]: 0 0 0 0 0 0 107 0 1298 0 1275 0 320 0 0 0 0 0 0 0 : latency 132616; std 385.63
[ 21 01 -- -- -- -- ]: 0 0 0 0 0 0 137 0 1297 0 1267 0 299 0 0 0 0 0 0 0 : latency 132456; std 383.78
[ 21 02 -- -- -- -- ]: 0 0 0 0 0 1 131 1 1257 0 1273 0 337 0 0 0 0 0 0 0 : latency 132628; std 379.56
[ 21 03 -- -- -- -- ]: 0 0 0 0 0 0 133 0 1279 0 1270 0 315 0 0 0 0 0 0 0 : latency 132405; std 381.87
[ 21 04 -- -- -- -- ]: 0 0 0 0 0 0 151 0 1258 0 1270 0 321 0 0 0 0 0 0 0 : latency 132522; std 378.90
[ 21 05 -- -- -- -- ]: 0 0 0 0 0 0 146 0 1256 0 1290 0 308 0 0 0 0 0 0 0 : latency 132520; std 381.30
[ 21 06 -- -- -- -- ]: 0 0 0 0 0 0 144 2 1280 0 1236 0 338 0 0 0 0 0 0 0 : latency 132534; std 377.56
[ 21 07 -- -- -- -- ]: 0 0 0 0 0 0 152 0 1280 1 1254 0 310 0 0 0 0 0 0 0 : latency 132316; std 379.54
[ 21 08 -- -- -- -- ]: 0 0 0 0 0 0 106 0 1305 0 1259 0 330 0 0 0 0 0 0 0 : latency 132626; std 384.59
[ 21 09 -- -- -- -- ]: 0 0 0 0 0 0 94 0 1305 0 1294 0 307 0 0 0 0 0 0 0 : latency 132628; std 389.27
[ 21 10 -- -- -- -- ]: 0 0 0 0 0 0 120 0 1318 0 1251 0 308 0 0 0 0 0 0 0 : latency 132365; std 384.86
[ 21 11 -- -- -- -- ]: 0 0 0 0 0 0 112 1 1336 0 1222 0 329 0 0 0 0 0 0 0 : latency 132535; std 383.99
[ 21 12 -- -- -- -- ]: 0 0 0 0 0 0 130 0 1304 2 1257 0 307 0 0 0 0 0 0 0 : latency 132484; std 383.51
[ 21 13 -- -- -- -- ]: 0 0 0 0 0 0 143 1 1357 0 1226 0 273 0 0 0 0 0 0 0 : latency 132257; std 386.62
[ 21 14 -- -- -- -- ]: 0 0 0 0 0 0 128 1 1284 1 1275 0 308 0 0 0 0 0 0 0 : latency 132397; std 383.17
[ 21 15 -- -- -- -- ]: 0 0 0 0 0 0 114 0 1331 0 1267 0 288 0 0 0 0 0 0 0 : latency 132458; std 388.77
[ 21 16 -- -- -- -- ]: 0 0 0 0 0 0 116 0 1298 0 1319 0 267 0 0 0 0 0 0 0 : latency 132474; std 391.11
[ 21 17 -- -- -- -- ]: 0 0 0 0 0 0 118 0 1257 1 1320 0 304 0 0 0 0 0 0 0 : latency 132621; std 385.93
[ 21 18 -- -- -- -- ]: 0 0 0 0 0 0 129 1 1307 0 1263 0 297 0 0 0 0 0 0 0 : latency 132326; std 384.65
[ 21 19 -- -- -- -- ]: 0 0 0 0 0 0 142 1 1317 0 1268 0 272 0 0 0 0 0 0 0 : latency 132339; std 386.42
[ 21 20 -- -- -- -- ]: 0 0 0 0 0 0 135 0 1274 0 1272 0 319 0 0 0 0 0 0 0 : latency 132550; std 381.51
[ 21 21 -- -- -- -- ]: 0 0 0 0 0 0 139 0 1310 0 1246 1 301 0 0 0 0 0 0 0 : latency 132292; std 382.72
[ 21 22 -- -- -- -- ]: 0 0 0 0 0 0 131 0 1282 1 1298 0 288 0 0 0 0 0 0 0 : latency 132487; std 385.90
[ 21 23 -- -- -- -- ]: 0 0 0 0 0 0 105 0 1334 0 1256 1 304 0 0 0 0 0 0 0 : latency 132521; std 387.98
[ 21 24 -- -- -- -- ]: 0 0 0 0 0 0 125 0 1317 0 1276 0 282 0 0 0 0 0 0 0 : latency 132430; std 387.80
[ 21 25 -- -- -- -- ]: 0 0 0 0 0 0 148 0 1313 0 1251 0 285 0 0 0 0 0 0 0 : latency 132217; std 383.60
[ 21 26 -- -- -- -- ]: 0 0 0 0 0 0 123 0 1315 0 1254 0 308 0 0 0 0 0 0 0 : latency 132494; std 384.82
[ 21 27 -- -- -- -- ]: 0 0 0 0 0 0 157 0 1315 0 1229 0 299 0 0 0 0 0 0 0 : latency 132340; std 381.03
[ 21 28 -- -- -- -- ]: 0 0 0 0 0 0 137 0 1265 0 1308 0 290 0 0 0 0 0 0 0 : latency 132502; std 384.96
[ 21 29 -- -- -- -- ]: 0 0 0 0 0 0 134 0 1382 0 1215 0 266 0 0 0 0 0 0 0 : latency 132097; std 388.96
[ 21 30 -- -- -- -- ]: 0 0 0 0 0 0 126 0 1280 0 1269 0 325 0 0 0 0 0 0 0 : latency 132586; std 382.12
[ 21 31 -- -- -- -- ]: 0 0 0 0 0 1 121 0 1279 2 1296 0 301 0 0 0 0 0 0 0 : latency 132553; std 385.40
[ 21 32 -- -- -- -- ]: 0 0 0 0 0 0 131 0 1280 0 1294 0 295 0 0 0 0 0 0 0 : latency 132506; std 385.16
[ 21 33 -- -- -- -- ]: 0 0 0 0 0 0 145 0 1302 0 1262 0 288 0 0 0 0 0 0 0 : latency 132257; std 383.58
[ 21 34 -- -- -- -- ]: 0 0 0 0 0 0 148 0 1289 1 1274 0 288 0 0 0 0 0 0 0 : latency 132405; std 383.37
[ 21 35 -- -- -- -- ]: 0 0 0 0 0 0 122 0 1354 0 1261 0 263 0 0 0 0 0 0 0 : latency 132330; std 390.99
[ 21 36 -- -- -- -- ]: 0 0 0 0 0 0 147 1 1307 0 1204 0 338 0 0 0 0 0 0 0 : latency 132336; std 377.14
[ 21 37 -- -- -- -- ]: 0 0 0 0 0 0 123 1 1305 0 1275 0 296 0 0 0 0 0 0 0 : latency 132487; std 386.10
[ 21 38 -- -- -- -- ]: 0 0 0 0 0 0 113 0 1278 2 1299 0 308 0 0 0 0 0 0 0 : latency 132606; std 385.90
[ 21 39 -- -- -- -- ]: 0 0 0 0 0 0 132 0 1268 0 1289 1 310 0 0 0 0 0 0 0 : latency 132557; std 382.94
[ 21 40 -- -- -- -- ]: 0 0 0 0 0 0 120 0 1199 0 1334 0 344 0 0 0 0 0 0 0 : latency 132675; std 380.84
[ 21 41 -- -- -- -- ]: 0 0 0 0 0 0 144 0 1217 0 1295 0 344 0 0 0 0 0 0 0 : latency 132678; std 377.31
[ 21 42 -- -- -- -- ]: 0 0 0 0 0 0 124 0 1303 0 1266 1 306 0 0 0 0 0 0 0 : latency 132511; std 384.68
[ 21 43 -- -- -- -- ]: 0 0 0 0 0 0 140 0 1296 1 1250 0 313 0 0 0 0 0 0 0 : latency 132473; std 381.42
[ 21 44 -- -- -- -- ]: 0 0 0 0 0 0 148 0 1330 0 1232 0 287 0 0 0 0 0 0 0 : latency 132187; std 383.53
[ 21 45 -- -- -- -- ]: 0 0 0 0 0 0 129 1 1289 0 1269 0 312 0 0 0 0 0 0 0 : latency 132527; std 383.14
[ 21 46 -- -- -- -- ]: 0 0 0 0 0 0 135 1 1329 0 1246 0 289 0 0 0 0 0 0 0 : latency 132377; std 385.39
[ 21 47 -- -- -- -- ]: 0 0 0 0 0 0 141 1 1313 2 1238 0 302 0 0 0 0 0 0 0 : latency 132274; std 382.01
[ 21 48 -- -- -- -- ]: 0 0 0 0 0 0 145 0 1324 0 1212 0 319 0 0 0 0 0 0 0 : latency 132410; std 380.44
[ 21 49 -- -- -- -- ]: 0 0 0 0 0 0 144 0 1279 1 1273 0 303 0 0 0 0 0 0 0 : latency 132471; std 382.03
[ 21 50 -- -- -- -- ]: 0 0 0 0 0 0 126 0 1294 0 1279 0 301 0 0 0 0 0 0 0 : latency 132510; std 385.15
[ 21 51 -- -- -- -- ]: 0 0 0 0 0 0 136 0 1332 0 1222 0 307 0 0 0 0 0 0 0 : latency 132271; std 382.83
[ 21 52 -- -- -- -- ]: 0 0 0 0 0 0 134 1 1301 1 1250 0 313 0 0 0 0 0 0 0 : latency 132484; std 382.17
[ 21 53 -- -- -- -- ]: 0 0 0 0 0 0 159 0 1288 0 1255 0 298 0 0 0 0 0 0 0 : latency 132384; std 380.66
[ 21 54 -- -- -- -- ]: 0 0 0 0 0 0 139 0 1345 0 1202 0 314 0 0 0 0 0 0 0 : latency 132382; std 382.21
[ 21 55 -- -- -- -- ]: 0 0 0 0 0 0 145 0 1267 0 1284 0 301 0 0 0 0 0 0 0 : latency 132353; std 381.87
[ 21 56 -- -- -- -- ]: 0 0 0 0 0 0 155 0 1289 0 1230 0 326 0 0 0 0 0 0 0 : latency 132454; std 377.80
[ 21 57 -- -- -- -- ]: 0 0 0 0 0 0 140 0 1281 1 1285 0 293 0 0 0 0 0 0 0 : latency 132463; std 383.90
[ 21 58 -- -- -- -- ]: 0 0 0 0 0 0 141 0 1291 0 1252 0 313 0 0 0 0 0 0 0 : latency 132345; std 380.98
[ 21 59 -- -- -- -- ]: 0 0 0 0 0 0 139 0 1322 0 1237 0 302 0 0 0 0 0 0 0 : latency 132404; std 383.30
[ 21 60 -- -- -- -- ]: 0 0 0 0 0 0 141 1 1313 0 1220 0 325 0 0 0 0 0 0 0 : latency 132457; std 379.99
[ 21 61 -- -- -- -- ]: 0 0 0 0 0 0 137 0 1296 0 1272 0 295 0 0 0 0 0 0 0 : latency 132450; std 384.28
[ 21 62 -- -- -- -- ]: 0 0 0 0 0 0 119 0 1263 0 1294 0 321 0 0 0 0 0 0 0 : latency 132505; std 383.26
[ 21 63 -- -- -- -- ]: 0 0 0 0 0 0 129 2 1334 0 1184 0 351 0 0 0 0 0 0 0 : latency 132512; std 378.90
[ 21 64 -- -- -- -- ]: 0 0 0 0 0 0 114 0 1274 0 1288 0 324 0 0 0 0 0 0 0 : latency 132644; std 384.06
[ 21 65 -- -- -- -- ]: 0 0 0 0 0 0 148 0 1279 1 1253 0 319 0 0 0 0 0 0 0 : latency 132487; std 379.44
[ 21 66 -- -- -- -- ]: 0 0 0 0 0 0 137 0 1294 1 1272 0 293 0 0 0 0 0 0 0 : latency 132314; std 383.92
[ 21 67 -- -- -- -- ]: 0 0 0 0 0 0 143 0 1276 0 1282 0 299 0 0 0 0 0 0 0 : latency 132474; std 382.85
[ 21 68 -- -- -- -- ]: 0 0 0 0 0 0 133 0 1292 1 1259 0 315 0 0 0 0 0 0 0 : latency 132513; std 382.18
[ 21 69 -- -- -- -- ]: 0 0 0 0 0 0 140 0 1282 1 1285 0 289 0 0 0 0 0 0 0 : latency 132318; std 383.98
[ 21 70 -- -- -- -- ]: 0 0 0 0 0 0 131 0 1279 1 1290 0 299 0 0 0 0 0 0 0 : latency 132515; std 384.48
[ 21 71 -- -- -- -- ]: 0 0 0 0 0 0 155 0 1279 0 1311 0 255 0 0 0 0 0 0 0 : latency 132332; std 386.89
[ 21 72 -- -- -- -- ]: 0 0 0 0 0 0 147 0 1266 0 1297 0 290 0 0 0 0 0 0 0 : latency 132460; std 383.45
[ 21 73 -- -- -- -- ]: 0 0 0 0 0 0 137 1 1285 0 1238 0 336 0 0 0 0 0 0 0 : latency 132416; std 378.58
[ 21 74 -- -- -- -- ]: 0 0 0 0 0 0 137 1 1248 0 1272 0 342 0 0 0 0 0 0 0 : latency 132637; std 378.23
[ 21 75 -- -- -- -- ]: 0 0 0 0 0 0 123 1 1311 0 1208 0 357 0 0 0 0 0 0 0 : latency 132597; std 378.85
[ 21 76 -- -- -- -- ]: 0 0 0 0 0 0 129 0 1298 0 1280 0 293 0 0 0 0 0 0 0 : latency 132474; std 385.73
[ 21 77 -- -- -- -- ]: 0 0 0 0 0 0 160 1 1310 1 1253 0 272 0 0 0 0 0 0 0 : latency 132145; std 383.18
[ 21 78 -- -- -- -- ]: 0 0 0 0 0 0 135 0 1309 0 1276 0 280 0 0 0 0 0 0 0 : latency 132402; std 386.54
[ 21 79 -- -- -- -- ]: 0 0 0 0 0 0 148 0 1327 0 1220 0 305 0 0 0 0 0 0 0 : latency 132364; std 381.72
[ 21 80 -- -- -- -- ]: 0 0 0 0 0 0 155 0 1263 0 1266 0 316 0 0 0 0 0 0 0 : latency 132486; std 378.93
[ 21 81 -- -- -- -- ]: 0 0 0 0 0 0 128 1 1243 0 1297 0 328 0 0 0 0 0 0 0 : latency 132520; std 380.93
[ 21 82 -- -- -- -- ]: 0 0 0 0 0 0 139 0 1230 0 1260 0 371 0 0 0 0 0 0 0 : latency 132726; std 374.66
[ 21 83 -- -- -- -- ]: 0 0 0 0 0 0 123 0 1262 1 1301 0 313 0 0 0 0 0 0 0 : latency 132609; std 383.95
[ 21 84 -- -- -- -- ]: 0 0 0 0 0 0 148 0 1329 0 1204 0 316 0 0 0 0 0 0 0 : latency 132247; std 380.03
[ 21 85 -- -- -- -- ]: 0 0 0 0 0 0 155 0 1302 1 1237 0 305 0 0 0 0 0 0 0 : latency 132385; std 380.29
[ 21 86 -- -- -- -- ]: 0 0 0 0 0 0 0 0 1294 1 1318 0 387 0 0 0 0 0 0 0 : latency 133185; std 394.42
[ 21 87 -- -- -- -- ]: 0 0 0 0 0 0 138 1 1291 1 1247 0 322 0 0 0 0 0 0 0 : latency 132506; std 380.42
[ 21 88 -- -- -- -- ]: 0 0 0 0 0 0 136 0 1293 1 1244 0 323 0 0 0 0 0 0 0 : latency 132380; std 380.34
[ 21 89 -- -- -- -- ]: 0 0 0 0 0 0 128 0 1339 0 1218 0 315 0 0 0 0 0 0 0 : latency 132440; std 383.54
[ 21 90 -- -- -- -- ]: 0 0 0 0 0 0 147 1 1339 2 1229 0 282 0 0 0 0 0 0 0 : latency 132293; std 384.35
[ 21 91 -- -- -- -- ]: 0 0 0 0 0 0 161 0 1280 0 1282 0 277 0 0 0 0 0 0 0 : latency 132350; std 383.05
[ 21 92 -- -- -- -- ]: 0 0 0 0 0 0 153 0 1286 0 1276 0 282 0 0 0 0 0 0 0 : latency 132245; std 383.13
[ 21 93 -- -- -- -- ]: 0 0 0 0 0 0 133 0 1260 0 1291 0 316 0 0 0 0 0 0 0 : latency 132580; std 382.22
[ 21 94 -- -- -- -- ]: 0 0 0 0 0 0 160 0 1297 0 1228 0 315 0 0 0 0 0 0 0 : latency 132396; std 378.49
[ 21 95 -- -- -- -- ]: 0 0 0 0 0 0 132 0 1309 1 1235 0 319 0 0 0 0 0 0 0 : latency 132311; std 381.39
[ 21 96 -- -- -- -- ]: 0 0 0 0 0 0 144 1 1315 2 1239 0 299 0 0 0 0 0 0 0 : latency 132387; std 382.39
[ 21 97 -- -- -- -- ]: 0 0 0 0 0 0 141 1 1288 0 1267 0 303 0 0 0 0 0 0 0 : latency 132463; std 382.49
[ 21 98 -- -- -- -- ]: 0 0 0 0 0 0 142 0 1271 1 1261 0 325 0 0 0 0 0 0 0 : latency 132539; std 379.56
[ 21 99 -- -- -- -- ]: 0 0 0 0 0 0 131 0 1278 0 1256 0 332 0 0 0 0 0 0 0 : latency 132449; std 380.07
0: 86 lat = 133185
1: 82 lat = 132726
2: 41 lat = 132678
3: 40 lat = 132675
4: 64 lat = 132644
95: 92 lat = 132245
96: 25 lat = 132217
97: 44 lat = 132187
98: 77 lat = 132145
99: 29 lat = 132097
0: 86 std = 394.42
1: 16 std = 391.11
2: 35 std = 390.99
3: 09 std = 389.27
4: 29 std = 388.96
95: 56 std = 377.80
96: 06 std = 377.56
97: 41 std = 377.31
98: 36 std = 377.14
99: 82 std = 374.66
lat_k 0.35%, std_k 0.85%
pin[1] choose candidate: 86 based on latency
[ 21 86 00 -- -- -- ]: 0 0 0 0 0 0 0 0 1202 0 1360 0 438 0 0 0 0 0 0 0 : latency 133472; std 389.63
[ 21 86 01 -- -- -- ]: 0 0 0 0 0 0 0 0 1209 0 1359 0 432 0 0 0 0 0 0 0 : latency 133446; std 390.20
[ 21 86 02 -- -- -- ]: 0 0 0 0 0 0 0 2 1341 0 1236 0 421 0 0 0 0 0 0 0 : latency 133154; std 390.72
[ 21 86 03 -- -- -- ]: 0 0 0 0 0 0 0 1 1269 0 1305 0 422 0 0 0 0 0 0 0 : latency 133168; std 390.02
[ 21 86 04 -- -- -- ]: 0 0 0 0 0 0 0 1 1314 0 1263 0 422 0 0 0 0 0 0 0 : latency 133213; std 390.50
[ 21 86 05 -- -- -- ]: 0 0 0 0 0 0 0 0 1297 0 1251 0 452 0 0 0 0 0 0 0 : latency 133310; std 387.40
[ 21 86 06 -- -- -- ]: 0 0 0 0 0 0 0 0 1339 1 1223 0 434 0 0 0 0 0 0 0 : latency 133054; std 389.10
[ 21 86 07 -- -- -- ]: 0 0 0 0 0 0 0 1 1237 0 1324 0 438 0 0 0 0 0 0 0 : latency 133399; std 388.91
[ 21 86 08 -- -- -- ]: 0 0 0 0 0 0 0 0 1244 0 1317 0 439 0 0 0 0 0 0 0 : latency 133390; std 388.89
[ 21 86 09 -- -- -- ]: 0 0 0 0 0 0 0 1 1284 0 1281 0 434 0 0 0 0 0 0 0 : latency 133297; std 389.10
[ 21 86 10 -- -- -- ]: 0 0 0 0 0 0 0 0 1255 0 1307 0 435 0 0 0 0 0 0 0 : latency 133225; std 388.81
[ 21 86 11 -- -- -- ]: 0 0 0 0 0 0 0 0 1315 1 1240 1 443 0 0 0 0 0 0 0 : latency 133256; std 388.14
[ 21 86 12 -- -- -- ]: 0 0 0 0 0 0 0 1 1354 1 1228 0 416 0 0 0 0 0 0 0 : latency 133120; std 391.43
[ 21 86 13 -- -- -- ]: 0 0 0 0 0 0 0 1 1289 0 1301 0 409 0 0 0 0 0 0 0 : latency 133237; std 391.88
[ 21 86 14 -- -- -- ]: 0 0 0 0 0 0 0 0 1286 0 1285 0 426 0 0 0 0 0 0 0 : latency 133145; std 389.71
[ 21 86 15 -- -- -- ]: 0 0 0 0 0 0 0 0 1291 1 1264 0 444 0 0 0 0 0 0 0 : latency 133305; std 388.04
[ 21 86 16 -- -- -- ]: 0 0 0 0 0 0 0 0 1324 0 1259 0 417 0 0 0 0 0 0 0 : latency 133186; std 391.28
[ 21 86 17 -- -- -- ]: 0 0 0 0 0 0 0 0 1254 0 1291 0 455 0 0 0 0 0 0 0 : latency 133402; std 387.05
[ 21 86 18 -- -- -- ]: 0 0 0 0 0 0 0 0 1317 1 1258 0 421 0 0 0 0 0 0 0 : latency 133072; std 390.21
[ 21 86 19 -- -- -- ]: 0 0 0 0 0 0 0 1 1366 0 1218 0 415 0 0 0 0 0 0 0 : latency 133095; std 391.90
[ 21 86 20 -- -- -- ]: 0 0 0 0 0 0 0 1 1186 0 1395 0 418 0 0 0 0 0 0 0 : latency 133461; std 392.26
[ 21 86 21 -- -- -- ]: 0 0 0 0 0 0 0 0 1334 0 1212 0 450 0 0 0 0 0 0 0 : latency 133052; std 387.44
[ 21 86 22 -- -- -- ]: 0 0 0 0 0 0 0 0 1315 0 1267 0 418 0 0 0 0 0 0 0 : latency 133206; std 391.10
[ 21 86 23 -- -- -- ]: 0 0 0 0 0 0 0 0 1308 0 1237 0 455 0 0 0 0 0 0 0 : latency 133294; std 387.17
[ 21 86 24 -- -- -- ]: 0 0 0 0 0 0 0 0 1274 1 1280 0 445 0 0 0 0 0 0 0 : latency 133341; std 387.91
[ 21 86 25 -- -- -- ]: 0 0 0 0 0 0 0 1 1337 0 1216 1 442 0 0 0 0 0 0 0 : latency 133073; std 388.10
[ 21 86 26 -- -- -- ]: 0 0 0 0 0 0 0 0 1326 0 1244 0 430 0 0 0 0 0 0 0 : latency 133208; std 389.92
[ 21 86 27 -- -- -- ]: 0 0 0 0 0 0 0 0 1288 0 1280 0 432 0 0 0 0 0 0 0 : latency 133288; std 389.48
[ 21 86 28 -- -- -- ]: 0 0 0 0 0 0 0 0 1281 0 1282 0 437 0 0 0 0 0 0 0 : latency 133312; std 388.94
[ 21 86 29 -- -- -- ]: 0 0 0 0 0 0 0 0 1319 1 1243 0 434 0 0 0 0 0 0 0 : latency 133094; std 388.85
[ 21 86 30 -- -- -- ]: 0 0 0 0 0 0 0 1 1255 0 1318 0 426 0 0 0 0 0 0 0 : latency 133339; std 390.10
[ 21 86 31 -- -- -- ]: 0 0 0 0 0 0 0 0 1322 0 1243 0 435 0 0 0 0 0 0 0 : latency 133226; std 389.36
[ 21 86 32 -- -- -- ]: 0 0 0 0 0 0 0 0 1322 0 1233 0 442 0 0 0 0 0 0 0 : latency 133105; std 388.22
[ 21 86 33 -- -- -- ]: 0 0 0 0 0 0 0 1 1253 3 1298 0 445 0 0 0 0 0 0 0 : latency 133378; std 387.48
[ 21 86 34 -- -- -- ]: 0 0 0 0 0 0 0 1 1302 1 1279 0 417 0 0 0 0 0 0 0 : latency 133226; std 390.83
[ 21 86 35 -- -- -- ]: 0 0 0 0 0 0 0 0 1292 0 1266 0 442 0 0 0 0 0 0 0 : latency 133300; std 388.42
[ 21 86 36 -- -- -- ]: 0 0 0 0 0 0 0 0 1313 1 1258 0 425 0 0 0 0 0 0 0 : latency 133088; std 389.75
[ 21 86 37 -- -- -- ]: 0 0 0 0 0 0 0 0 1309 0 1262 0 429 0 0 0 0 0 0 0 : latency 133240; std 389.88
[ 21 86 38 -- -- -- ]: 0 0 0 0 0 0 0 0 1225 0 1320 1 454 0 0 0 0 0 0 0 : latency 133459; std 387.24
[ 21 86 39 -- -- -- ]: 0 0 0 0 0 0 0 0 1325 0 1247 0 428 0 0 0 0 0 0 0 : latency 133206; std 390.12
[ 21 86 40 -- -- -- ]: 0 0 0 0 0 0 0 1 1289 1 1275 0 431 0 0 0 0 0 0 0 : latency 133145; std 388.83
[ 21 86 41 -- -- -- ]: 0 0 0 0 0 0 0 0 1263 0 1312 0 425 0 0 0 0 0 0 0 : latency 133324; std 390.33
[ 21 86 42 -- -- -- ]: 0 0 0 0 0 0 0 0 1309 1 1354 0 336 0 0 0 0 0 0 0 : latency 133053; std 400.61
[ 21 86 43 -- -- -- ]: 0 0 0 0 0 0 0 1 1305 1 1340 0 353 0 0 0 0 0 0 0 : latency 133092; std 398.32
[ 21 86 44 -- -- -- ]: 0 0 0 0 0 0 0 0 1270 0 1379 0 348 0 0 0 0 0 0 0 : latency 133021; std 399.16
[ 21 86 45 -- -- -- ]: 0 0 0 0 0 0 0 0 1312 0 1342 0 346 0 0 0 0 0 0 0 : latency 133068; std 399.50
[ 21 86 46 -- -- -- ]: 0 0 0 0 0 0 0 0 1262 0 1411 0 327 0 0 0 0 0 0 0 : latency 133130; std 402.52
[ 21 86 47 -- -- -- ]: 0 0 0 0 0 0 0 0 1276 1 1355 0 365 0 0 0 0 0 0 0 : latency 133042; std 396.76
[ 21 86 48 -- -- -- ]: 0 0 0 0 0 0 0 0 1297 0 1345 0 358 0 0 0 0 0 0 0 : latency 133122; std 398.08
[ 21 86 49 -- -- -- ]: 0 0 0 0 0 0 0 0 1294 0 1367 0 339 0 0 0 0 0 0 0 : latency 133090; std 400.50
[ 21 86 50 -- -- -- ]: 0 0 0 0 0 0 0 0 1301 0 1294 0 405 0 0 0 0 0 0 0 : latency 133208; std 392.50
[ 21 86 51 -- -- -- ]: 0 0 0 0 0 0 0 0 1286 0 1368 0 343 0 0 0 0 0 0 0 : latency 132979; std 399.61
[ 21 86 52 -- -- -- ]: 0 0 0 0 0 0 0 0 1268 0 1384 0 348 0 0 0 0 0 0 0 : latency 133160; std 399.65
[ 21 86 53 -- -- -- ]: 0 0 0 0 0 0 0 0 1278 0 1368 0 354 0 0 0 0 0 0 0 : latency 133152; std 398.75
[ 21 86 54 -- -- -- ]: 0 0 0 0 0 0 0 0 1304 0 1346 0 350 0 0 0 0 0 0 0 : latency 133092; std 399.04
[ 21 86 55 -- -- -- ]: 0 0 0 0 0 0 0 0 1296 0 1333 0 367 0 0 0 0 0 0 0 : latency 132962; std 396.38
[ 21 86 56 -- -- -- ]: 0 0 0 0 0 0 0 0 1299 0 1350 0 351 0 0 0 0 0 0 0 : latency 133104; std 398.94
[ 21 86 57 -- -- -- ]: 0 0 0 0 0 0 0 1 1329 0 1326 0 344 0 0 0 0 0 0 0 : latency 133027; std 399.55
[ 21 86 58 -- -- -- ]: 0 0 0 0 0 0 0 0 1241 1 1395 0 363 0 0 0 0 0 0 0 : latency 133243; std 397.99
[ 21 86 59 -- -- -- ]: 0 0 0 0 0 0 0 1 1305 0 1341 0 349 0 0 0 0 0 0 0 : latency 132905; std 398.39
[ 21 86 60 -- -- -- ]: 0 0 0 0 0 0 0 0 1314 0 1226 0 460 0 0 0 0 0 0 0 : latency 133292; std 386.73
[ 21 86 61 -- -- -- ]: 0 0 0 0 0 0 0 0 1286 0 1366 0 348 0 0 0 0 0 0 0 : latency 133124; std 399.43
[ 21 86 62 -- -- -- ]: 0 0 0 0 0 0 0 0 1325 0 1340 0 332 0 0 0 0 0 0 0 : latency 132879; std 400.77
[ 21 86 63 -- -- -- ]: 0 0 0 0 0 0 0 0 1261 1 1369 0 369 0 0 0 0 0 0 0 : latency 133215; std 396.89
[ 21 86 64 -- -- -- ]: 0 0 0 0 0 0 0 1 1125 0 1381 0 493 0 0 0 0 0 0 0 : latency 133733; std 385.09
[ 21 86 65 -- -- -- ]: 0 0 0 0 0 0 0 1 1301 1 1378 0 319 0 0 0 0 0 0 0 : latency 133032; std 402.69
[ 21 86 66 -- -- -- ]: 0 0 0 0 0 0 0 0 1295 0 1350 0 352 0 0 0 0 0 0 0 : latency 132979; std 398.39
[ 21 86 67 -- -- -- ]: 0 0 0 0 0 0 0 0 1320 0 1329 0 351 0 0 0 0 0 0 0 : latency 133062; std 398.86
[ 21 86 68 -- -- -- ]: 0 0 0 0 0 0 0 0 1294 0 1323 0 383 0 0 0 0 0 0 0 : latency 133178; std 395.06
[ 21 86 69 -- -- -- ]: 0 0 0 0 0 0 0 1 1341 0 1312 0 346 0 0 0 0 0 0 0 : latency 133007; std 399.33
[ 21 86 70 -- -- -- ]: 0 0 0 0 0 0 0 1 1306 1 1308 0 381 0 0 0 0 0 0 0 : latency 133011; std 394.50
[ 21 86 71 -- -- -- ]: 0 0 0 0 0 0 0 0 1261 0 1404 0 335 0 0 0 0 0 0 0 : latency 133148; std 401.47
[ 21 86 72 -- -- -- ]: 0 0 0 0 0 0 0 0 1285 0 1375 1 339 0 0 0 0 0 0 0 : latency 133109; std 400.42
[ 21 86 73 -- -- -- ]: 0 0 0 0 0 0 0 0 1278 0 1365 0 353 0 0 0 0 0 0 0 : latency 132970; std 398.27
[ 21 86 74 -- -- -- ]: 0 0 0 0 0 0 0 0 1304 1 1337 0 358 0 0 0 0 0 0 0 : latency 133107; std 397.88
[ 21 86 75 -- -- -- ]: 0 0 0 0 0 0 0 0 1255 0 1404 0 341 0 0 0 0 0 0 0 : latency 133172; std 400.78
[ 21 86 76 -- -- -- ]: 0 0 0 0 0 0 0 0 1288 0 1384 0 328 0 0 0 0 0 0 0 : latency 133080; std 401.99
[ 21 86 77 -- -- -- ]: 0 0 0 0 0 0 0 0 1298 0 1339 0 360 0 0 0 0 0 0 0 : latency 132989; std 397.38
[ 21 86 78 -- -- -- ]: 0 0 0 0 0 0 0 0 1281 0 1355 0 364 0 0 0 0 0 0 0 : latency 133166; std 397.46
[ 21 86 79 -- -- -- ]: 0 0 0 0 0 0 0 1 1267 0 1388 0 344 0 0 0 0 0 0 0 : latency 133151; std 400.01
[ 21 86 80 -- -- -- ]: 0 0 0 0 0 0 0 0 1326 0 1251 0 423 0 0 0 0 0 0 0 : latency 133194; std 390.65
[ 21 86 81 -- -- -- ]: 0 0 0 0 0 0 0 0 1295 0 1266 0 436 0 0 0 0 0 0 0 : latency 133147; std 388.64
[ 21 86 82 -- -- -- ]: 0 0 0 0 0 0 0 0 1344 0 1215 0 441 0 0 0 0 0 0 0 : latency 133194; std 389.04
[ 21 86 83 -- -- -- ]: 0 0 0 0 0 0 0 1 1292 0 1267 0 440 0 0 0 0 0 0 0 : latency 133293; std 388.47
[ 21 86 84 -- -- -- ]: 0 0 0 0 0 0 0 0 1311 3 1330 0 356 0 0 0 0 0 0 0 : latency 133087; std 397.77
[ 21 86 85 -- -- -- ]: 0 0 0 0 0 0 0 1 1264 1 1383 0 348 0 0 0 0 0 0 0 : latency 133029; std 398.90
[ 21 86 86 -- -- -- ]: 0 0 0 0 0 0 0 0 1316 1 1333 0 350 0 0 0 0 0 0 0 : latency 133067; std 398.83
[ 21 86 87 -- -- -- ]: 0 0 0 0 0 0 0 0 1298 0 1334 0 368 0 0 0 0 0 0 0 : latency 133140; std 396.85
[ 21 86 88 -- -- -- ]: 0 0 0 0 0 0 0 0 1309 1 1311 0 375 0 0 0 0 0 0 0 : latency 132951; std 395.22
[ 21 86 89 -- -- -- ]: 0 0 0 0 0 0 0 0 1273 0 1411 0 316 0 0 0 0 0 0 0 : latency 133086; std 403.81
[ 21 86 90 -- -- -- ]: 0 0 0 0 0 0 0 3 1307 1 1309 0 380 0 0 0 0 0 0 0 : latency 133136; std 394.72
[ 21 86 91 -- -- -- ]: 0 0 0 0 0 0 0 0 1274 0 1372 0 354 0 0 0 0 0 0 0 : latency 133160; std 398.80
[ 21 86 92 -- -- -- ]: 0 0 0 0 0 0 0 0 1290 0 1363 0 344 0 0 0 0 0 0 0 : latency 132973; std 399.44
[ 21 86 93 -- -- -- ]: 0 0 0 0 0 0 0 0 1301 0 1365 0 334 0 0 0 0 0 0 0 : latency 133066; std 401.08
[ 21 86 94 -- -- -- ]: 0 0 0 0 0 0 0 0 1281 0 1379 0 340 0 0 0 0 0 0 0 : latency 133118; std 400.51
[ 21 86 95 -- -- -- ]: 0 0 0 0 0 0 0 0 1306 0 1351 0 343 0 0 0 0 0 0 0 : latency 133074; std 399.91
[ 21 86 96 -- -- -- ]: 0 0 0 0 0 0 0 0 1271 0 1388 0 338 0 0 0 0 0 0 0 : latency 132999; std 400.45
[ 21 86 97 -- -- -- ]: 0 0 0 0 0 0 0 0 1340 1 1313 0 346 0 0 0 0 0 0 0 : latency 133011; std 399.33
[ 21 86 98 -- -- -- ]: 0 0 0 0 0 0 0 1 1260 0 1394 0 345 0 0 0 0 0 0 0 : latency 133167; std 399.99
[ 21 86 99 -- -- -- ]: 0 0 0 0 0 0 0 0 1294 0 1369 1 336 0 0 0 0 0 0 0 : latency 133085; std 400.72
0: 64 lat = 133733
1: 00 lat = 133472
2: 20 lat = 133461
3: 38 lat = 133459
4: 01 lat = 133446
95: 73 lat = 132970
96: 55 lat = 132962
97: 88 lat = 132951
98: 59 lat = 132905
99: 62 lat = 132879
0: 89 std = 403.81
1: 65 std = 402.69
2: 46 std = 402.52
3: 76 std = 401.99
4: 71 std = 401.47
95: 38 std = 387.24
96: 23 std = 387.17
97: 17 std = 387.05
98: 60 std = 386.73
99: 64 std = 385.09
lat_k 0.20%, std_k 0.28%
pin[2] choose candidate: 64 based on latency
Candidate PIN 21 86 64 -- -- -- : brute forcing bytes 3 to 5 (3 bytes), will take up to 639 seconds
Progress: 0%..5%..10%..15%..20%..done
found PIN: 47 86 89 21 20 64
PIN is cracked in 714.09 seconds
Validating PIN
PIN verified.
done
Resetting all ECUs.
CAN_HS ---> ID=000ffffe data=ff c8 00 00 00 00 00 00
CAN_LS ---> ID=000ffffe data=ff c8 00 00 00 00 00 00
successful.
0: 21 lat = 132354
1: 98 lat = 132284
2: 91 lat = 132282
3: 86 lat = 132243
4: 89 lat = 132218
95: 18 lat = 131793
96: 26 lat = 131786
97: 33 lat = 131776
98: 29 lat = 131759
99: 15 lat = 131702
0: 29 std = 413.08
1: 23 std = 411.18
2: 27 std = 411.18
3: 33 std = 410.73
4: 25 std = 410.18
95: 21 std = 394.94
96: 30 std = 394.50
97: 00 std = 393.10
98: 20 std = 389.27
99: 01 std = 386.89
0: 86 lat = 133185
1: 82 lat = 132726
2: 41 lat = 132678
3: 40 lat = 132675
4: 64 lat = 132644
95: 92 lat = 132245
96: 25 lat = 132217
97: 44 lat = 132187
98: 77 lat = 132145
99: 29 lat = 132097
0: 86 std = 394.42
1: 16 std = 391.11
2: 35 std = 390.99
3: 09 std = 389.27
4: 29 std = 388.96
95: 56 std = 377.80
96: 06 std = 377.56
97: 41 std = 377.31
98: 36 std = 377.14
99: 82 std = 374.66
0: 64 lat = 133733
1: 00 lat = 133472
2: 20 lat = 133461
3: 38 lat = 133459
4: 01 lat = 133446
95: 73 lat = 132970
96: 55 lat = 132962
97: 88 lat = 132951
98: 59 lat = 132905
99: 62 lat = 132879
0: 89 std = 403.81
1: 65 std = 402.69
2: 46 std = 402.52
3: 76 std = 401.99
4: 71 std = 401.47
95: 38 std = 387.24
96: 23 std = 387.17
97: 17 std = 387.05
98: 60 std = 386.73
99: 64 std = 385.09
Validating PIN
PIN verified.
done
Resetting all ECUs.
- RickHaleParker
- Been thanked: 978 times
Got one done today, the 2005 XC90 T6.
The other one ( Frankenstein ... the V8 conversion ) has some weird stuff going on. Currently Frankenstein is uncrackable. It might be the low battery. I try again after I get the battery back to full charge. You all know how Frankenstein is without his electrons.
Main will does retrieve the CEM part number. Rework returns a value of 0 for the part number.
2005 XC90 T6.
2005 XC90 T6.
Code: Select all
Summary: Both VTL's Main and Rework will crack this CEM-H.
with the latency candidates. None of the standard deviation
candidates where correct.
2005 XC90 T6. CEM-H 30765643, VTL's Main respostory.
CPU Frequency: 180000000
Execution Rate: 180 cycles/us
Minimum CEM Reply Time: 30us
Platform: P2
Number of loops: 1000
---> ID=000ffffe data=50 88 00 00 00 00 00 00
<--- ID=00000003 data=50 8e 00 00 30 76 56 43
Part Number: 000030765643
1000 pins in 657 ms, 1522 pins/s, average response: 86candidate: 93 with latency
[ 00 -- -- -- -- -- ]: 000 000 000 019 162 148 1209 157 1161 012 132 000 000 000 000 : 260514
[ 99 -- -- -- -- -- ]: 000 000 000 022 152 160 1188 131 1174 023 150 000 000 000 000 : 260618
0: 93 = 261450
1: 61 = 260799
2: 84 = 260741
3: 89 = 260740
4: 95 = 260726
5: 86 = 260721
6: 69 = 260711
7: 87 = 260708
8: 98 = 260689
9: 65 = 260686
10: 85 = 260679
11: 97 = 260677
12: 78 = 260677
13: 72 = 260661
14: 88 = 260644
15: 71 = 260637
16: 53 = 260634
17: 55 = 260623
18: 60 = 260623
19: 99 = 260618
20: 66 = 260615
21: 94 = 260613
22: 92 = 260611
23: 49 = 260610
24: 91 = 260603
pin[0] candidate: 93 with latency 261450
[ 93 00 -- -- -- -- ]: 000 000 000 008 074 142 1156 146 1111 049 314 000 000 000 000 : 261457
[ 93 99 -- -- -- -- ]: 000 000 000 014 095 149 1106 145 1108 039 344 000 000 000 000 : 261473
0: 43 = 261868
1: 87 = 261714
2: 96 = 261711
3: 59 = 261697
4: 85 = 261681
5: 65 = 261679
6: 92 = 261673
7: 89 = 261667
8: 93 = 261661
9: 69 = 261658
10: 63 = 261656
11: 95 = 261643
12: 57 = 261641
13: 91 = 261639
14: 86 = 261634
15: 52 = 261625
16: 71 = 261612
17: 53 = 261608
18: 97 = 261593
19: 72 = 261592
20: 46 = 261578
21: 31 = 261563
22: 45 = 261562
23: 73 = 261550
24: 37 = 261546
pin[1] candidate: 43 with latency 261868
Warning: Selected candidate is very close to the next candidate!
Selection may be incorrect.
[ 93 43 00 -- -- -- ]: 000 000 000 000 000 148 1125 158 1181 036 352 000 000 000 000 : 261888
[ 93 43 99 -- -- -- ]: 000 000 000 000 000 138 983 158 1261 048 412 000 000 000 000 : 262334
0: 93 = 262559
1: 44 = 262449
2: 91 = 262443
3: 64 = 262428
4: 43 = 262427
5: 59 = 262420
6: 51 = 262406
7: 95 = 262396
8: 61 = 262396
9: 84 = 262385
10: 52 = 262385
11: 49 = 262383
12: 89 = 262380
13: 42 = 262380
14: 69 = 262372
15: 85 = 262370
16: 65 = 262367
17: 54 = 262363
18: 73 = 262361
19: 56 = 262360
20: 86 = 262349
21: 72 = 262346
22: 55 = 262345
23: 99 = 262334
24: 62 = 262332
pin[2] candidate: 93 with latency 262559
Candidate PIN 0x93 0x43 0x93 -- -- -- : brute forcing bytes 3 to 5 (3 bytes), will take up to 657 seconds
Progress: 0%..5%..10%..15%..20%..25%..30%..35%..40%..45%..50%..done
found PIN: 0x25 0x43 0x27 0x93 0x52 0x93
PIN is cracked in 921.60 seconds
Validating PIN
PIN verified.
done
Resetting all ECUs.
2005 XC90 T6. CEM-H 30765643, VTL's Rework repository.
Part Number: 30765643
Searching P/N 30765643 in 49 known CEMs
Putting all ECUs on CAN_HS into programming mode.
1000 pins in 639 ms, 1564 pins/s, average response: 82 us, histogram 41 to 123 us
us: 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93
[ 00 -- -- -- -- -- ]: 0 0 0 0 0 0 0 0 0 62 92 135 1195 225 975 47 101 0 0 0 : latency 129655; std 321.81
[ 99 -- -- -- -- -- ]: 0 0 0 0 0 0 0 0 0 79 80 190 1137 367 1004 56 87 0 0 0 : latency 137304; std 319.76
0: 93 lat = 138336
1: 41 lat = 137497
2: 56 lat = 137483
3: 77 lat = 137478
4: 89 lat = 137459
0: 77 std = 334.80
1: 39 std = 334.48
2: 11 std = 334.37
3: 09 std = 333.49
4: 27 std = 333.34
lat_k 0.61%, std_k 0.10%
pin[0] choose candidate: 93 based on latency
[ 93 00 -- -- -- -- ]: 0 0 0 0 0 0 0 0 0 41 64 155 1008 343 969 154 266 0 0 0 : latency 138401; std 295.55
[ 93 99 -- -- -- -- ]: 0 0 0 0 0 0 0 0 0 42 59 182 1096 331 940 133 217 0 0 0 : latency 138052; std 303.93
0: 43 lat = 138820
1: 00 lat = 138401
2: 80 lat = 138359
3: 70 lat = 138284
4: 40 lat = 138273
0: 71 std = 314.72
1: 67 std = 313.24
2: 47 std = 310.94
3: 20 std = 310.87
4: 69 std = 310.59
lat_k 0.30%, std_k 0.47%
pin[1] choose candidate: 43 based on latency
[ 93 43 00 -- -- -- ]: 0 0 0 0 0 0 0 0 0 0 0 165 1121 284 987 181 262 0 0 0 : latency .
[ 93 43 99 -- -- -- ]: 0 0 0 0 0 0 0 0 0 0 0 180 1075 363 1075 109 198 0 0 0 : latency 138452; std 322.22
0: 93 lat = 138923
1: 07 lat = 138795
2: 00 lat = 138684
3: 80 lat = 138636
4: 02 lat = 138601
0: 54 std = 331.31
1: 88 std = 329.26
2: 76 std = 327.50
3: 94 std = 327.14
4: 63 std = 326.43
lat_k 0.09%, std_k 0.63%
pin[2] choose candidate: 93 based on latency
Candidate PIN 93 43 93 -- -- -- : brute forcing bytes 3 to 5 (3 bytes), will take up to 639 seconds
found PIN: 25 43 27 93 52 93
PIN is cracked in 913.62 seconds
Validating PIN
PIN verified.
done
Resetting all ECUs.
CAN_LS ---> ID=000ffffe data=ff c8 00 00 00 00 00 00Active
Past
Past
vtl
I pushed some commits today.RickHaleParker wrote: 03 May 2021, 18:37 Got one done today, the 2005 XC90 T6.
They don't meant to be correct, they ares just the bytes sorted by std.RickHaleParker wrote: 03 May 2021, 18:37 2005 XC90 T6.
Here's the case when the code decides std is glaring more than the latency (which normally has the priority):
0: 28 lat = 135466
1: 08 lat = 135450
2: 10 lat = 135436
3: 58 lat = 135394
4: 98 lat = 135346
0: 45 std = 379.09
1: 00 std = 374.51
2: 04 std = 370.43
3: 47 std = 370.37
4: 78 std = 370.25
lat_k 0.01%, std_k 1.22%
pin[1] choose candidate: 45 based on std
- RickHaleParker
Can anybody spot what is wrong with these settings? No response on a 2005 XC90 T6.
This is CEM-40 (CAN-LS).
Active
Past
Past
- RickHaleParker
I was making a statement of facts for that case. Anything else would be a waste of time ... you don't have a complaint department.vtl wrote: 03 May 2021, 20:15 They don't meant to be correct, they ares just the bytes sorted by std.
Active
Past
Past
- 8980 Views
Last post by RickHaleParker
- 8798 Views
- 27 Replies
- 27619 Views
Last post by cn90
- 10206 Views
Last post by jonesg
- 5420 Views
