Start a new thread in the P2 forum ( this one) for your projects, this is the one night stand “ what i did today” thread..daughtersmechanic wrote: 26 Jul 2019, 12:44 Daughter finally found the time and some cash to "allow" dad to do some work on her beast of a car. So, last weekend, I replaced the starter (and reclaimed my crowbar), plugs (long story short, I thought plugs were the cause of an issue. They weren't, but were at least 15k past replacement and the center electrodes were all but gone), thermostat & temperature sensor (that fixed the issue), and added four quarts of oil (yeah, four). Engine runs rough for a minute when first started, but then smooths out.
Thought I'd replace the burned out driver's side rear brake light. Easy-peasy. Except that the previous kucklehead broke the upper taillight socket the last time, and used a screw and some kind of tar-like adhesive to get it to work. Now, it's a trip to eBay, on my dime, for an intact assembly.
Should have left well enough alone but, idiot that I am, I borrowed the scanner from O'Reilly's and came away with 11 codes, indicating issues with the Evap system (hopefully, just a hose somewhere), the camshaft reset valve (whatever that is), and the turbocharger (those are the ones that really scare me). So, the to-do list now reads (in no particular order):
- Replace the upper taillight
- Replace the right rear wheel bearing/hub
- Fix the evap system
- Fix/replace the camshaft reset valve
- Troubleshoot/fix? the turbocharger issue
- Change the oil and filter
- Troubleshoot the automatic locks, which occasionally lock up the car all by themselves (Daughter has no fob) and refuse to let her in.
- Replace the fuel filter (so Georgeandkira stays off my case!)
Thanks, in advance, to everyone who has, and will, post solutions here!
- Has thanked: 1613 times
- Been thanked: 4078 times
- MDK
- Year and Model: 2004 S60R
- Been thanked: 42 times
Trim ring around prdl gear matic. The wood trim piece from the 2006 XC70 trim piece was too long to fit in my dash.so I measured 7.5 " inches to the right.... 8.5" to the left and marked it with a sharpie and pulled painter's tape between the 2 points and cut it with a manual hacksaw.. I don't have a band saw.. good enough
velorider
- Year and Model: 2005 S60 T5
- Has thanked: 2 times
- Been thanked: 27 times
Installed the anti-axle ping axle bolts today. Wow! Picked up the car a little over a 1.5 year ago and replaced the front end suspension components but still had a "clunking" noise. After installing the anti-axle ping everything quiet and feels tight.
daughtersmechanic
- Year and Model: 2001 V70 XC
[/quote]
[/quote]
I may take you up on that, Empty Nester, if I ever get another opportunity. Took her almost six months to bring it to me for the starter, and by then the hot start issue (thermostat/temp sensor fixed it, I hope) had begun. Praying that she gets an oil change in the next month or two. I haven't done my own maintenance for the last 20 years. Now, I'm just trying to keep her from being stranded.
Daughters! (maybe we need a thread for that)
[/quote]
2001 XC70, The Beast, 222K
- MDK
I had a really deep dent in my hood on my 2004 S60 R. About the size of a quarter, with aluminum hoods being what they are, I found a good clean hood in the scrapyard. 60 $ from a 2006 XC70...no paint, no body work. Just swapped it out. The other thing is...is that my noise dampening panel had a few tears in it and in poor condition, so that's nice and clean too! Rolling on..
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
I didn't think the P2 hoods were aluminum.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
I hope not, because it means I lost all my arm strength last year...
- 12198 Replies
- 1684776 Views
Last post by RedBrickCollector
- 97 Replies
- 210475 Views
Last post by br0dy519
- 59 Replies
- 62551 Views
Last post by smacknab
- 7109 Views
Last post by xHeart
- 12349 Views
