Vida CEM swapping
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
I'm struggling with my early style P2 CEM. It is very slow, and it always gives the best latency to byte 00, in all PIN positions.
vtl
Post by vtl »
Old code was branched out to "old" in case anyone will need it, rework was merged back into master.
h3b
Year and Model: 2005 XC90 D5 Aut.
Post by h3b »
What can i do for example if i have the pin code?
Is there anything except cem swapping?
I've a 05 XC90 D5 so should be one of the later P2 if i understand that correctly.
vtl
Post by vtl »
With the pin code in hands you can invest your money into the Czech Republic economy: https://d5t5.com/article/volvo-change-configuration. Having a sw backup of your CEM also comes handy at times.
RickHaleParker
Been thanked: 979 times
Post by RickHaleParker »
vtl wrote: 03 May 2021, 20:15
Here's the case when the code decides std is glaring more than the latency (which normally has the priority):
The new master went with Standard Deviation on Frankenstein. Frankenstein is still uncrackable.
CPU Maximum Frequency: 600000000
CPU Frequency: 600000000
Execution Rate: 600 cycles/us
PIN bytes to measure: 3
Number of samples: 30
CAN low-speed init done.
Reading part number from ECU 0x40 on CAN_LS
CAN_LS ---> ID=000ffffe data=cb 40 b9 f0 00 00 00 00
Part Number: 31394157
Searching P/N 31394157 in 49 known CEMs
CAN HS baud rate: 500000
PIN shuffle order: 3 1 5 0 2 4
CAN high-speed init done.
Putting all ECUs into programming mode.
CAN_HS ---> ID=000ffffe data=ff 86 00 00 00 00 00 00
CAN_LS ---> ID=000ffffe data=ff 86 00 00 00 00 00 00
Reading part number from ECU 0x50 on CAN_HS
CAN_HS ---> ID=000ffffe data=50 88 00 00 00 00 00 00
CAN_HS <--- ID=00000003 data=50 8e 00 00 31 39 41 57
Initialization done.
Calculating bytes 0-2
1000 pins in 640 ms, 1562 pins/s, average response: 87 us, histogram 43 to 130 us
lat_k 0.01%, std_k 1.37% pin[0] choose candidate: 20 based on std
lat_k 0.01%, std_k 0.44% pin[1] choose candidate: 01 based on std
lat_k 0.01%, std_k 0.39% pin[2] choose candidate: 46 based on std
Candidate PIN 20 01 46 -- -- -- : brute forcing bytes 3 to 5 (3 bytes), will take up to 640 seconds
Progress: 0%..5%..10%..15%..20%..25%..30%..35%..40%..45%..50%..55%..60%..65%..70%..75%..80%..85%..90%..95%..
PIN is NOT cracked in 1225.39 seconds
done
Resetting all ECUs.
CAN_HS ---> ID=000ffffe data=ff c8 00 00 00 00 00 00
CAN_LS ---> ID=000ffffe data=ff c8 00 00 00 00 00 00
Full Log is attached.
FrankensteinNewMasterFullLog.zip
(8.59 KiB) Downloaded 114 times
Active
Past
vtl
Post by vtl »
Do you have a dump?
RickHaleParker
vtl wrote: 04 May 2021, 08:21 I'm struggling with my early style P2 CEM. It is very slow, and it always gives the best latency to byte 00, in all PIN positions.
What happens if you exclude 00 as a candidate? say measure 01 - 99 rather then 00 - 99.
Active
Past
h3b
Post by h3b »
vtl wrote: 04 May 2021, 11:21 With the pin code in hands you can invest your money into the Czech Republic economy: https://d5t5.com/article/volvo-change-configuration. Having a sw backup of your CEM also comes handy at times.
ah okay, thanks. then i will try it. do i just need a teensy 4.0? or do i have to make a circuit like you did on your github page? or is a external board like this (https://amzn.to/3ehKCfO) fine?
vtl
Post by vtl »
h3b wrote: 04 May 2021, 14:51 ah okay, thanks. then i will try it. do i just need a teensy 4.0? or do i have to make a circuit like you did on your github page? or is a external board like this (https://amzn.to/3ehKCfO) fine?
You need a Teensy and two of these transceivers. And DC-DC in case USB power is weak.
h3b
Post by h3b »
vtl wrote: 04 May 2021, 14:54
Okay, i have the teensy 4.0 already then i will try it the next days. my car doesn't move far anyway right know, because the power steering oil cooler decided to leak heavy.
Thanks! I'll give feedback if it works :)
