I agree, really nice looking 240 wagon. Always loved those cars.
Plastic foot rest? A 2 minute job isn't it if I recall correctly (as long as it is not broken).
- Has thanked: 2215 times
- Been thanked: 1853 times
454cid
- Year and Model: 1996 850
- Has thanked: 151 times
- Been thanked: 139 times
Placed an FCP order, and filled up the windshield washer fluid reservoir in the 99 S70 with temperature appropriate washer solution.
I keep comparing/contrasting the S70 with my 850, and the S70 wins without question in the windshield washer department. The 850 takes time to prime, and runs through fluid very fast, which makes me think some of the plumbing is bad. The S70 sprays (in a nice pattern) as soon as I activate the washers, and I've been running on the small amount that was in the car when I bought it.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
yanga001
- Has thanked: 62 times
- Been thanked: 115 times
Checked the Wagon today and it seems like the uro parts radiator hose has finally sealed up my cooling system. Been having fun leaks for months but i dont see any wet spots on the ground anymore.
The new air filter seems to have solved the P0131 issue and P0422 dtc's i was attributing to a bad o2 sensor. Will give it another 200 km and see if it comes back.
2008 S60 2.5T Auto (Sold)
If the 850 is using a lot of fluid and takes a one time to prime it is likely the one way valves are leaking in the pipe work. You can also replace the spray units on the hood with P2 versions which give a much better spray pattern.
- Has thanked: 317 times
- Been thanked: 531 times
^This. You can replace the check valve(s) if they're not holding fluid, and I highly recommend swapping the nozzles to either later P80 or P2 nozzles. As you can see, MUCH nicer spray pattern!scot850 wrote: 28 Nov 2022, 07:56 If the 850 is using a lot of fluid and takes a one time to prime it is likely the one way valves are leaking in the pipe work. You can also replace the spray units on the hood with P2 versions which give a much better spray pattern.
454cid
Replacing the nozzles with later nozzles was my first "mod" (only one really). I used Pro Parts nozzles, not Volvo, Though.... against Abscate's advise. They may actually be worse than the factory 850 nozzles. I'm wondering if besides one way valves that aren't working, I have a low pressure issue too, such that any nozzle won't spray well. I'll address it when the weather gets nice again.... the 850 is off the road for now. Well, I may drive it one more time to wash it, and fill it up with gas. For now, I'm just enjoying the things the S70 does better.... I am liking the turbo!bmdubya1198 wrote: 28 Nov 2022, 09:18^This. You can replace the check valve(s) if they're not holding fluid, and I highly recommend swapping the nozzles to either later P80 or P2 nozzles. As you can see, MUCH nicer spray pattern!scot850 wrote: 28 Nov 2022, 07:56 If the 850 is using a lot of fluid and takes a one time to prime it is likely the one way valves are leaking in the pipe work. You can also replace the spray units on the hood with P2 versions which give a much better spray pattern.
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
brunocerous
- Year and Model: 1998 V70
- Has thanked: 303 times
- Been thanked: 43 times
abscate wrote: 19 Nov 2022, 17:28 Local travel only Bruno. That white residue has plugged the cracks but the if that lets go there will be a big coolant loss
Definite;y gorp someJB on each crack to get through the holiday week(s) then reward her with a new Nissens ftom FCP and two new radiator hoses. Do you want some cool kid oetiker clamps so you can gloat over your uneducated brother?
The radiator hoses (with oetiker clamps!) and transmission cooling lines were updated relatively recently. Do I need new clips for the transmission lines? A coolant system cleaner?
1998 V70 T5, AT, project
2004 XC90 AWD (sold)
1999 V70 XC AWD, AT (RIP)
1998 S70 T5, AT (RIP)
Don't think you need a coolant cleaner unless you are not replacing the coolant relatively frequently like every 3-4 years. You can flush it with water.
I would suggest if the Nissens radiator is not supplied with new 'O' rings and clips the 'O' rings are definitely worth changing, the clips/clamps you can re-use (make sure you check the correct orientation when removing or they will leak) and use a tightened zip-tie around then to prevent them coming back off.
- Goupil
- Year and Model: 98' V70 LPT
- Has thanked: 30 times
- Been thanked: 116 times
It's not broken and I even have two in the carscot850 wrote: 27 Nov 2022, 14:40 Plastic foot rest? A 2 minute job isn't it if I recall correctly (as long as it is not broken).
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
