MrAl wrote: 03 Feb 2023, 13:09 Little update on today's work....
Apparently the solar panel is working. It is the first time ever i saw the battery voltage climb up a little. Normally after the engine is turned off the voltage continuously falls, fast at first, then slower as time goes on. After about 24 hours it can drop to as low as 12.01 volts.
Now, the voltage initially fell somewhat, then started to climb as i think the sun got brighter. It's up almost as high as when i first shut the engine off after running for some minutes. That's pretty amazing, and if this behavior keeps up this could be my solution to low battery problems, and i would suspect other people can do the same thing if they have battery problems.
There may still be a problem however. That is, right now the sun is quite bright, but once we get some cloudy weather the effectiveness remains to be seen. Will it perform well enough in that kind of weather.
I'll be keeping a close eye on it over the next few days, and nights, and see how it fares after one night with no sun at all.
Hello again,
Well here we are today, one day after installing the solar panel.
Last night the voltage went down but not as low as usual and that's a good sign.
This morning it did not start to creep up until around 8:15am well after sunrise. That's because during the first two hours there is a lot of shade blocking out the sun.
After that, the voltage actually went up from 12.03 volts to 12.04 volts !! WOW aint that great (ha ha). That was a good sign though because it meant that at least it may be able to hold the voltage from falling down more which would mean discharging more and that's bad.
So after about an hour it went up to 12.16 volts which is a really good sign. 0.1 volts is a lot for a 12v battery, and it's not near noon yet when the sun is in the most ideal place in the sky.
It is going up more now too so i'll see if the battery starts smoking soon (ha ha ha). Ok i seriously doubt that but i hope it at least keeps it up during the day that would reduce the total drain over a 24 hour period. I am looking to get away with starting the car just once every 3 days unless i have to go somewhere of course.
The normal trickle charge voltage is 13.8 volts i think but i dont think i want it that high. That's if it could ever do that anyway.
Another thing though is the sun is still pretty bright out there today so it's not the best test yet. The best test will be on a gloomy overcast day with lots of cloud cover. So unfortunately even if it works very good today it may not work very well on a cloudy day.
We'll see i guess and i'll update again then.
