MrAl
Year and Model: v70, 1998
Has thanked: 83 times
Been thanked: 73 times
Post by MrAl »
scot850 wrote: 31 Jan 2023, 13:54 Normal parasitic drain on earlier P80's I have had as little as 10-20mA. That is what I would call normal. My 00 R runs much higher than that due to the aftermarket alarm system and so it is in the 45-50 mA range. So even if you are only getting 5 mA on a bad day, I would expect it to be able to keep it charged sufficient for starting for much longer than now. The brand I looked at was called Powoxi at Amazon. The one I linked is 7.5W but they do do them up to 20W. What I liked about this brand is the options that come with it and the rubber suction cups that stick to the windows. This link should hopefully take you to Amazon.com website:
https://www.amazon.com/Waterproof-Maint ... 0cnVl&th=1
Oh yes i never checked the drain because i would have to disconnect the battery.
But i meant to say i cant see the pic in your post. And if a link it's not working.
Has thanked: 1847 times
Been thanked: 1710 times
If you can't see the link it is down to the same problem I can't see Amazon links posted in the US. God knows why not.
Go to Amazon.com
Post this thread in the search:
20W 12V Solar Battery Charger, Waterproof 20 Watt 12 Volt Solar Panel Trickle Charger & Maintainer, Built-in Intelligent MPPT Charge Controller for Car Boat Marine RV Trailer Automotive
That should find it.
ZionXIX
Has thanked: 65 times
Been thanked: 194 times
Post by ZionXIX »
Has anyone tried optima batteries in these cars?
454cid
Year and Model: 1996 850
Has thanked: 145 times
Been thanked: 129 times
Post by 454cid »
ZionXIX wrote: 31 Jan 2023, 23:06 Has anyone tried optima batteries in these cars?
It's my understanding that Optima batteries aren't what they used to be. If I recall correctly they got bought out a few years ago.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
Has thanked: 1504 times
Been thanked: 3817 times
Really good detailed stuff on readiness testing
https://www.rlescalambre.net/
foggydogg
Been thanked: 402 times
Post by foggydogg »
WhatAmIDoing wrote: 31 Jan 2023, 12:21 Was able to get a junk yard alternator and PS pump with ~100k miles. Hopefully I'll be driving the V70 again this weekend.
Likely the best solution to get you going again; with a bit of luck you'll have miles of motoring pleasure.
MrAl
Post by MrAl »
scot850 wrote: 31 Jan 2023, 22:33 If you can't see the link it is down to the same problem I can't see Amazon links posted in the US. God knows why not.
Go to Amazon.com
Oh didnt know the links were messed up like that. Ill take a look.
MrAl
Post by MrAl »
abscate wrote: 01 Feb 2023, 02:05 Really good detailed stuff on readiness testing
The question is, how do you find out why a monitor is not going ready even after a lot of driving?
There are times I feel like smacking my head really hard (my wife agrees that too :o :lol: :lol: ).
I have a Volvo SC-816 audio unit which I pulled a few months back.With help from a friend at the local dealer, he was able to get me a code, after a false start as it was not the original radio sold with the car but a factory reconditioned unit. My friend found the code for that but it would not accept that either and locked me out again. That was when I started building a simple test system to allow me to power up the head units I have to make sure they:
1) Would power up
2) The codes I have worked as they should
3) If the unit was showing the 'OFF' on the screen rather than the 'CODE' message (code entered 3 times wrongly it locks you out), you have to leave the head unit in your car with the ignition on at II position for up to 2 hours or more to get it to reset to the CODE message. This allows me to do that without the need for a car and leaving the ignition on for long periods of time. Works great for that!
Anyway the code I had for the re-conditioned unit would not work. So we assumed the unit had gone bad (Volvo tech dept). Disappointed as the unit was nearly mint condition! Planned to then remove the front panel and transfer to a less well kept unit.
I contacted my friend today to get the code for another SC-816 I had to save, and while e-mailing him asked him to re-check the code for the other unit as I could not find any e-mail from him with that code. Turns out I got that code via a phone call and had transposed 2 of the numbers!! Ran down to the garage and tried again and it works! Yahoo!!
Now need to go get motivated on building the version 2.0 and then 3.0 system to test speakers and sound output, then to test amps and possibly even Dolby units too! When I say test, I mean they code, power up, bulbs all work and cassette/CD units function and all speaker outputs work. Also can test speakers to ensure they are good, then finally the amplifiers and cables for them.
I don't have any plans to try to fix or test internal components on failed units! That is waay passed my pay-grade! :D
Here is a picture of the unit with the bulbs replaced. Unit did not look molested with, but only had 3 bulbs fitted. Test system now updated to V 1.1 with switch for night-time lights which are normally controlled by the headlight switch and brightness rheostat.
Bulbs replaced and face plate not re-fitted
Similar unit also with bulbs replaced and face refitted
This unit had 5/5 bulbs failed!
Well worth the effort!
