98 V70 trailer Topic is solved
- Has thanked: 1614 times
- Been thanked: 4078 times
I needed a spare a Antlia but an Antlia in Antlers is an Anathema
- CIK7
- Year and Model: 2026 Sportrailer GLT
- Has thanked: 350 times
- Been thanked: 108 times
LOL sometimes I dont get jokes. Its funny nonetheless.
06 Odyssey LX, silver, 127921, current
98 V GLE/SE red, 379k, 5sp, trailer in progress...
95 854 Turbo 258K, auto, sold
09 Rav4 Ltd3.5Fwd, red, 208k/213k, sold
03 Accord 2dr V6 silver, 196K/232K, 6sp, t-boned, sold
- CIK7
The most intimidating part of the entire trailer build will be the welding. Never done it before and just now today I bought the proper welding sticks. I also got some extra cash so I might also buy a decent camera or a smartphone so I can record everything properly. Believe it or not, I only have a flip phone no matter how high-end it is. It's the Sonim XP3900 (xp3+) non-5g with mobile hotspot. Tomorrow morning, I will have another update for you. Maybe late next week I will begin practice welding. However, I think it'll be sometime between Monday and Wednesday when I have a vehicle update for you guys in the Volvo car chat forum.
- CIK7
The time has finally come for me to ask you: Where do I find automotive bodyshop seal sealer?volvolugnut wrote: 19 Feb 2026, 08:40 Find some automotive body shop seal sealer. This is used to seal weld seams at the factory and the body shops. It may come in a plastic bag and you need to reuse a calking tube to dispense as needed. Squeeze out a sealer bead and smooth with a putty knife.
This will reduce worry about incomplete welds.
- Has thanked: 987 times
- Been thanked: 1078 times
There was a typo in my original post. It should have read 'seam sealer'.CIK7 wrote: 18 Mar 2026, 17:15The time has finally come for me to ask you: Where do I find automotive bodyshop seal sealer?volvolugnut wrote: 19 Feb 2026, 08:40 Find some automotive body shop seal sealer. This is used to seal weld seams at the factory and the body shops. It may come in a plastic bag and you need to reuse a calking tube to dispense as needed. Squeeze out a sealer bead and smooth with a putty knife.
NAPA stores have several types available in calking gun tubes. Rather expensive at $ 25 a tube and up. Very thick and sticky stuff.
- CIK7
I actually ended up going to searching on Amazon and eBay after I posted that. And yes, thank you for clarifying that. I found that typo.volvolugnut wrote: 18 Mar 2026, 18:10There was a typo in my original post. It should have read 'seam sealer'.CIK7 wrote: 18 Mar 2026, 17:15The time has finally come for me to ask you: Where do I find automotive bodyshop seal sealer?volvolugnut wrote: 19 Feb 2026, 08:40 Find some automotive body shop seal sealer. This is used to seal weld seams at the factory and the body shops. It may come in a plastic bag and you need to reuse a calking tube to dispense as needed. Squeeze out a sealer bead and smooth with a putty knife.
- CIK7
Today, I picked up the 'update' I told you I would release today. The corrections I made to it are in the black pen.
yanga001
- Has thanked: 62 times
- Been thanked: 115 times
Brakes are an interesting beast. I’m wondering can you still use the main rear system by plugging the two front lines and using some sort of actuator linked to the electronic trailer braking module. Did you look into surge based or the ones that need like a 7 pin terminal.
I’ve got a wrecked v70 that I’ve pondered doing this too. Can bump out the door enough and the rear still tracks straight if I recall correctly.
Wishing you luck and will be following this as well.
2008 S60 2.5T Auto (Sold)
- CIK7
Part 1: That's an interesting idea. I might look into that.yanga001 wrote: 20 Mar 2026, 12:08 I’m wondering can you still use the main rear system by plugging the two front lines and using some sort of actuator linked to the electronic trailer braking module.
Part 2: Are you referring to a '7 way' or '5 way' trailer wired plug/socket? Those do have the braking wire capable. I already have a four-way and five-way. If I find a way to hook up the brakes then yes, I will use a five-way.
Part 3: Super fun, this conversion.
Part 4: Thank you.
Two more suggestions for your welding and sealing work:
Use an small, stiff brush to spread and smooth the sealer. An acid brush commonly used for soldering works well.
Use a good smoke/dust mask to keep the welding smoke out of your lungs. A wind or fan at your back helps. If you have trouble holding the tip of the welding rod steady, use half a rod and use a heavy glove on your off side hand to help strady the welding rod.
Wear heavy full coverage shirt, pants and shoes. Weld splatter will burn you! Even the arc flash can give you sun burn.
Use all the Personal Protective Equipment (PPE) you can get.
