2000 S70 T5 Stalled on freeway
- Has thanked: 1500 times
- Been thanked: 3810 times
Re: 2000 S70 T5 Stalled on freeway
Hope you weathered the storms ok. I think the turbo is the same 98-00. Check the end play while you have it out.
clifford06
- Year and Model: 2000 T5
- Has thanked: 6 times
- Been thanked: 4 times
Greetings. All good. Thanks . If I remove the studs that connect the unit that opens and closes the waste gate , and remove it. Do I really need to remove the turbo to drop the exhaust manifold ? Double nutted the studs and they backed out easily.
Thought that if I could remove the pin in the waste gate arm and disconnect the connector to turbo , I could avoid pulling turbo unit. Leaving only to replace gaskets. This unit seems to be only held in place by three studs to exhaust side , and four on engine side ( 2 up 2 down). Two studs bolted to block for supprt. Sorry that I can't find a part name for the unit in question.
Can't get pics to load. Thoughts and opinions respected.
clifford06
Sorry ,Imeant four bolts to exhaust manifold.
clifford06
Greetings. Head installed. Just found crank timing marks. While looking down from top of engine, I noticed that there is a raised notch on the crank pulley. This raised notch lines up directly between timing marks. I used white out to mark. I did this due to lack of space to pull wheel. Also, helps my helper ( my wife ) see timing marks. Hopes this may help others.
Remember you have to preload the cam pulley with CVVT on your 2000 T5...
clifford06
Greetings. Thanks for reply. Just dealing with TB kit issue now. INA kit belt is too thin for me. Bought it thinking belt was sturdy with good roller and tensioner. Can't trust it. Online suppliers have it on order. 2-3 days to ship. Local belt cost $79. Kit $240. Time is a issue.
clifford06
Thanks for preload notice. I was so glad to find crank marks . You have refreshed the frustrated mind.
clifford06
Greetings. I'll install my Aisin WP this weekend while waiting for my Conti belt to arrive.
Also, does anyone know the size of the two bolts that go into that PITA water line on the back of the head ? If I ever do another head job, I'll just use studs and nuts to replace them. That way I could install them like exhaust manifold studs. Add gasket . Align when head is put in place. Install nuts.
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
You may be referring to the Turbo exhaust flange.clifford06 wrote:Greetings. All good. Thanks . If I remove the studs that connect the unit that opens and closes the waste gate , and remove it. Do I really need to remove the turbo to drop the exhaust manifold ? Double nutted the studs and they backed out easily.
- rspi
Contact rspi..
Will it have to be preloaded if the hub was left together?abscate wrote:Remember you have to preload the cam pulley with CVVT on your 2000 T5...
- 798 Views
Last post by E Showell
- 1051 Views
Last post by leonardthefast
