Engine died while driving and won't start. Topic is solved
- Has thanked: 316 times
- Been thanked: 531 times
It sounds like it's grinding a bit in addition to the rough idle, is your timing belt tensioner set right? Or do you have an exhaust leak or aftermarket exhaust?
- valvolvo70
- Year and Model: 1998 V70 T5 249K
- Has thanked: 10 times
- Been thanked: 8 times
My rented fuel pressure test kit came with a multi meter...misha wrote: 06 May 2020, 13:37Yes....if the Maf is bad.
This shows that the problem is not the MAF.
I suspect that it is the oil in cap & rotor like allready suggested...but could be something else which makes problem when it's heat soaked.
Something like relay,probably ground or b+ cable.
I would suggest a voltage drop test across cables or simple charging voltage test across battery terminals with a multimeter when problem occurs.
Let somebody to keep the gas pedal,not allowing the engine to die while you check charging voltage across battery terminals.
engine off- 12.76 volts (just purchased a new battery Monday)
engine idle (steady)- 14.08 (stumbling dropped/fluctuating to 12-13 volts)
engine @ 3K rpm (steady) 14.08-.09
- valvolvo70
Definitely an rusted and welded 2X exhaust leak, cheapo performance sound!bmdubya1198 wrote: 06 May 2020, 14:57 It sounds like it's grinding a bit in addition to the rough idle, is your timing belt tensioner set right? Or do you have an exhaust leak or aftermarket exhaust?
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Voltage is good.
The part when you get 12-13v is probably when rpm is fluctuating between 500-900...when engine is struggling to stay running.
Time to sort out the cap and rotor...to keep it clean and dry...before we proceed further.
Did you ever checked main fuel injection relay in the fusebox?
Also....i can't remember.....when stalling occurs...did you tried to jump fuel pump relay with circlip in proper terminals?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- valvolvo70
misha wrote: 06 May 2020, 15:37 Voltage is good.
The part when you get 12-13v is probably when rpm is fluctuating between 500-900...when engine is struggling to stay running. Right
Time to sort out the cap and rotor...to keep it clean and dry...before we proceed further. I cleaned it yesterday but I'll check again in the event oil is blowing back in. I'm going to replace both rear cam seals too.
Did you ever checked main fuel injection relay in the fusebox? Yes, I have a spare and swapped.
Also....i can't remember.....when stalling occurs...did you tried to jump fuel pump relay with circlip in proper terminals? I have a jumper but didn't think to jump when stumbling. I used it to verify the pump was running/fuel in rail.
- misha
Before you attack the cam seals....try with jumping the fuel pump relay when stumbling occurs again.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- valvolvo70
Jumped relay and didn't make a difference. Don't know if it was exhaust but it smelled like gas in the vehicle while jumped. Plugged the relay back in and stumbled, but not at higher rpms 2K-2500K.misha wrote: 06 May 2020, 16:49 Before you attack the cam seals....try with jumping the fuel pump relay when stumbling occurs again.
- misha
Do you have a fuel leak somewhere?
Since we covered fuel...then it must be ignition/spark issue.
You will need to fix oil leak in the cap and rotor.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- valvolvo70
misha wrote: 07 May 2020, 15:28 Do you have a fuel leak somewhere? No, I was sitting in the drivers seat with the door open and my exhaust leak is right under the center console.
Since we covered fuel...then it must be ignition/spark issue. Makes sense...It just died, shut off, which is weird.
You will need to fix oil leak in the cap and rotor. yup.
- Has thanked: 311 times
- Been thanked: 817 times
It's not weird at all if the cam seal is blown. Which it is.
- 1276 Views
Last post by FL850_1997
- 3610 Views
Last post by lummert
- 19 Replies
- 3940 Views
Last post by cn90
- 14 Replies
- 3460 Views
Last post by dj_v70
- 1563 Views
Last post by sleddriver
