Just wrestled with that on the Rescue R, FCP has individual pigtails, but it's a little fiddly, you have to deal with the tiny spade connectors on the feed plug that connects to the harness.454cid wrote: 19 Feb 2023, 15:48 I put a new plate on the 850, as I wanted one of the new design. I then I put new Hella "50% brighter" bulbs in the S70, as the lights are terrible due to aiming after the frontend was smashed by the previous owner. Hopefully they'll be a little bit better. I looked at each bulb I removed. One was an Osram made in Germany and the other was a Philips made in Poland.
The internal connectors were different. One side had a plastic housing for the wires that pulled off, the other side had individual metal spade connectors that needed a locking tab pushed.... and the wire insulation was cracking and missing, which I think I've read is typical.
- foggydogg
- Has thanked: 83 times
- Been thanked: 405 times
- Has thanked: 317 times
- Been thanked: 531 times
I have to say, good on Volvo for making it easy to change these harnesses. Many BMWs, for example, are not nearly this easy to repair headlight harnesses on. And they all suffer the same issue of wiring insulation being baked off.
- Has thanked: 1613 times
- Been thanked: 4075 times
Part 31274302 on the Kat AWD, used on cars from 1998-2013
Heavy polymer cup that fits around the fill spout. Held in with large wire snap ring , about 15 cm
454cid
- Year and Model: 1996 850
- Has thanked: 151 times
- Been thanked: 139 times
That's ripped up a bit on my 99. It doesn't really have a functional catch or lip anymore, that my 96 does. I've never seen that before until my Volvos. I guess it's to keep gas off the paint.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
yanga001
- Has thanked: 62 times
- Been thanked: 115 times
Did the headgasket treatment again, stopped small amount of bubbles coming out of the coolant overflow tube. Put the correct coolant back in this time and will monitor progress in the deisgnated intervals.
Fixed my foglights and cleaned the wagon. For my partner i changed an alternator which took under 45 minutes. Was such a treat compared to having to remove the power steering pump, associated pulley assembly and then reassembling it.
2008 S60 2.5T Auto (Sold)
- CIK7
- Year and Model: 2026 Sportrailer GLT
- Has thanked: 350 times
- Been thanked: 108 times
I spent the last 1hr 45min disassembling the interior of the parts car. Do I need to keep the front ashtray? No. Am I going to? Yes. Why? Because of the novelty-ish feeling. Watch out for an update here and then on my Classifieds post. Going to be good!
06 Odyssey LX, silver, 127921, current
98 V GLE/SE red, 379k, 5sp, trailer in progress...
95 854 Turbo 258K, auto, sold
09 Rav4 Ltd3.5Fwd, red, 208k/213k, sold
03 Accord 2dr V6 silver, 196K/232K, 6sp, t-boned, sold
454cid
Mostly scrape ice off of it and try to keep the windshield from freezing up as I drive....stupid hvac system doesn't want to switch to defrost or the floor.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
- CIK7
I taught the front passenger door card a trick on my parts car.
- Has thanked: 2212 times
- Been thanked: 1853 times
- BlackBart
- Has thanked: 967 times
- Been thanked: 923 times
This is the same for all those years? The P2's? My rubber neck is flopping loose on refills, I think the wire has sprung!abscate wrote: 20 Feb 2023, 02:49 Part 31274302 on the Kat AWD, used on cars from 1998-2013
