454cid
Year and Model: 1996 850
Has thanked: 151 times
Been thanked: 139 times
Post by 454cid »
Finally cleaned the trunk out of the S70. I had oil change stuff in there and a spare tire for my truck. Threw away a broken snow scraper.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
Has thanked: 1614 times
Been thanked: 4078 times
Watched Evita head off to work ….
CIK7
Year and Model: 2026 Sportrailer GLT
Has thanked: 350 times
Been thanked: 108 times
Post by CIK7 »
Added aftermarket horn wiring. Works great. Louder than factory wiring. Using 2 Wolo 310-2T low tones
06 Odyssey LX, silver, 127921, current
98 V GLE/SE red, 379k, 5sp, trailer in progress...
95 854 Turbo 258K, auto, sold
09 Rav4 Ltd3.5Fwd, red, 208k/213k, sold
03 Accord 2dr V6 silver, 196K/232K, 6sp, t-boned, sold
96 964 silver, 146K, diff&trans/engine self-destr, crushed 😭
Picked up an entire 4x bedroom house moving kit in wagon
Has thanked: 2215 times
Been thanked: 1853 times
Is it a compactor you bought or those extra strong vacuum bags? :D
crlande
Year and Model: 240DL;850;S70
Has thanked: 1 time
Been thanked: 36 times
Post by crlande »
As awesome as he is, this had to be multiple runs with a roof rack and or a trailer!
CIK7
Post by CIK7 »
abscate wrote: 10 Mar 2023, 18:17 Picked up an entire 4x bedroom house moving kit in wagon
I would like a picture! Have any pictures from that move?
WhatAmIDoing
Has thanked: 104 times
Been thanked: 105 times
Post by WhatAmIDoing »
CIK7 wrote: 07 Mar 2023, 19:54 Today I worked on the rear shocks.
I removed the first shock mount bolt on driver side. Sheared it off. Remembered on stuck bolts, Robert loosens then tightens then loosens again to prevent shearing. I did that on the 2nd one and worked fine. Both on passenger sides did not get stuck. Went to hardware store to buy 4 new flange bolts and a cobalt drill bit. Came home and installed new passenger side shock mount with blue threadlocker. Drilled out half of the sheared screw before running out of ample power in drill batteries. Took a 2-4hr break. Came back out and finished drilling out the sheared screw. Definitely nicked the chassis threads. Removed brake caliper and rotor to adjust emergency brake and reinstalled. Removed old driver side shock and replaced with new one. The nicked bolt hole was still good and accepted the new bolt with blue threadlocker. Finally new shocks and mounts means I finally got the volvo back on the road! I ripped down east main st! Soooooooooo fun! I have more tasks to complete soon. Non-working horn and rear windows might need regulator swap.
An older fella turned me on to Free-All. I know everyone has their favorite penetrating oil, but I'm now convinced this stuff is magic. I've gotten some of the crustiest stuff imaginable to break loose with it. Works fast. Pretty good rust remover too.
I’m pretty sure I was at that protest in the 60s….
Chuck W
Year and Model: 97 854 T5
Has thanked: 97 times
Been thanked: 340 times
Post by Chuck W »
Rotated the tires on the T5, front to rear. The front Nokians were showing 60% and the rears 80%. All wear is nice and even though.
Also been enjoying the added bump from the NA cam swap (and new valve seals). Need to mess with the tune a bit more, I suppose, but it has been running great with no changes since (and I've been busy with other projects).
