Vida CEM swapping
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
blasaab wrote: 27 May 2021, 11:59 Hi all i have done about 10 reads off my car. 3-4 Times i have got verified pin see photo is this correct?
Yes, that's the pin.
blasaab
Year and Model: Volvo xc90/V50/144
Been thanked: 3 times
Post by blasaab »
T5Luke havent been online for a while so im wondering if someone have got his cem Read tool to work? Only shows error or shuts down for me
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
Yes that is the correct pin.
In the code, increase Samples to a higher value. See if the reliability goes up.
Here is the line you are looking for:
#define SAMPLES 30 /* number of samples per sequence, more is better (up to 100) */
Active
Past
RickHaleParker
Any Ideas? The microcontroller is not on the list.
M32C
M30855FWUGP
PBF 516F100
Active
Past
vtl
Post by vtl »
Yes, it is a pain. I spend about 20 minutes trying to connect to the chip every time I need to flash something. You have the RESET circuit, right?
blasaab
Post by blasaab »
RickHaleParker wrote: 27 May 2021, 16:10
Yes i have tried Up to 90 and same result.
I have send code to Vdash and could change headlight config. Was in hurry and couldnt wait for T5LUKE program because monday is last day for inspection.
blasaab
Post by blasaab »
Vtl just for info on my cem the only working script was the old One.
Thanks all for the help and tips in this thread.
RickHaleParker
vtl wrote: 28 May 2021, 05:14 Yes, it is a pain. I spend about 20 minutes trying to connect to the chip every time I need to flash something. You have the RESET circuit, right?
That a clue, enabling a connection is a PIA.
What microcontroler profile are you using in settings? Trying to eliminate as many variables as possible.
Reset: I got all the connection pins soldered on then the Reset pad lifted. Moved the Rest connection pin to the cap and resistor in common with the pad. When the pad lifted it exposed what looks like a through hole. These may not be just pads.
Reset - +5V Move to GND and back +5V to reset.
Hold - GND
CNVss - +5V
( Null modem connection )
TDX - Interface RDX.
RDX - Interface TDX
Active
Past
RickHaleParker
I was able to get a beading needle to pass through a pad. The black dots in the center of the pads are holes. You just need to clear out the conformal coating. I would give you the diameter but my digital calipers just bit the dust.
Sent the other half after a packet of beading needles. Going to see if I can clean out the hole with the beading needles and use them as no solder test posts.
Active
Past
vtl
Post by vtl »
RickHaleParker wrote: 28 May 2021, 14:06 What microcontroler profile are you using in settings? Trying to eliminate as many variables as possible.
The one you add to config file by hands, to reflect addresses of our flash.
