xanthefin
Year and Model: 1997 850
Has thanked: 106 times
Been thanked: 130 times
Post by xanthefin »
What units are here? Years? I have 1 unit left for my tires.
Or i need recalibrate this meter.. guess that dot means cut here :arrow:
hausmeister
Year and Model: 1995 850T5-R
Has thanked: 250 times
Been thanked: 77 times
Post by hausmeister »
Have a quick question, what is the part number for the 2pin connector with round pins, as used on brake reservoir, fan relay, and I think Temp sensor? ( think they are the same)
Is it 9144275? Is that still available somewhere?
I would need a few, mine are pretty broken.
850 T5-R '95 auto Image
Has thanked: 1836 times
Been thanked: 1709 times
There was a thread on the fan relay connector like this recently (last 2 months), which I think included the part number. Can't recall if it is still available though.
This is the thread:
viewtopic.php?p=620746&hilit=Fan+relay+ ... or#p620746
hausmeister
Good find! I wish you luck on the repairs.
yanga001
Has thanked: 59 times
Been thanked: 110 times
Post by yanga001 »
xanthefin wrote: 28 May 2023, 09:37 What units are here? Years? I have 1 unit left for my tires.
Looks like mm based on the size of your pinky XD. I’d say it means racing slicks ready to go!
2008 S60 2.5T Auto (Sold)
Finally got a car up on my lift! Only had it since about July last year, and the joke of it it is not my car!
I am helping my new Volvo friend Ed with his 96 850 10V base. He was told there is a rod knock, but I'm hoping it was a bad diagnosis as the water pump shaft is wobbling like a good 'un. I think it is the impeller that is causing the knocking noise. It is definitely bad as it is leaking water.
So far it has been so much easier working on a car where you are not lying on a cold floor flat on your back!
Hardest part so far is the water pump is in the trunk but the battery is completely flat and the trunk lock is jammed so the key won't turn. At least Volvo has done one thig right in that the seat backs in the 850 sedan fold down giving access!!
Got the car to the point of draining as much water as the radiator and block drain will do, and after a lot of faffing around managed to find all the alignment marks for the timing belt. Someone had mad so many thick white marks on the pulleys it was impossible to tell the correct ones!
Had to keep rotating the engine cleaning all the marks off to make sure I found the correct ones!
Tomorrow, TB off, and then remove the water pump and fit the new one. Hopefully enough time to refit the original TB and start the car if the battery is charged and see if we have fixed the knocking noise! If we are successful, then I will go over the car and see what else needs doing. The RR parking brake does not work and I think the caliper may be seized as well for starters. Then there are various heat shield nuts missing, broken limit pads on the front control arms and of course the trunk lock I've noticed so far. That was the quick check!!
Lining 850 up for hoist
We have lift off
We have lift off
Which is the lining marks below............? Previous person that worked on this put so much paint on hard to find the correct ones!
Just a few timing marks
And yes, once I figured one out the rest became more obvious what they meant!
jsrnsis
Year and Model: P80 enjoyer
Has thanked: 25 times
Been thanked: 68 times
Post by jsrnsis »
Anyone in the New York capitol region need any 850 parts......
It's a 97 GLT with the low pressure turbo.
Engine and transmission have 237k but it ran and shifted like a dream, engine bay seems untouched, muffler and tailpipe are brand new OEM Volvo, trunk lid seems good, drivers side doors seem good, drivers side front rim is supposedly broken but the front tires were brand new, struts replaced recently, interior WAS gray but I don't know how much is left.
And the person who was driving is fine, just a little cut up from glass.
And on the same note, does anyone in the area have a 93-98 p80 they're thinking of parting with that we could buy?
Update: tow yard wants $1,500 in fees unless we surrender the title to them, RIP car.
1998 V70XC black 183xxx
2014 S80 T6 AWD 110xxx
1998 V70XC nautic blue 155xxx
1997 850 GLT 123xxx
2024 Honda CRF110F
Previous Volvos:
1997 850 GLT 239,577
1998 V70 NA silver 202,510
1994 850 NA gray 125,000
1998 V70 NA white 163xxx
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
Ouch, that took a hard hit. Glad to hear the driver is okay!
brunocerous
Year and Model: 1998 V70
Has thanked: 284 times
Been thanked: 36 times
Post by brunocerous »
I changed the front rotors and brake pads on Blue Steel. While in there, I noticed that the seals on both calipers had started to peel away from the edges, so I have some more work to do.
1998 Volvo V70 wheel with new brake discs
1998 V70 T5, AT, project
2004 XC90 AWD (sold)
1999 V70 XC AWD, AT (RIP)
1998 S70 T5, AT (RIP)
