Has thanked: 1850 times
Been thanked: 1710 times
I thought 286k was 'low mileage' for a Taco? I didn't even know they made 4 cylinder Tacos any more or is it a gen 1 or 2?
foggydogg
Has thanked: 83 times
Been thanked: 402 times
Post by foggydogg »
FireFox31 wrote: 18 Jun 2023, 20:18
bmdubya1198 wrote: 18 Jun 2023, 13:20 I'm parting a white S70 currently, I can't remember if it has mats in it or not.
I need great condition interior carpeting in 3960 light beige for a 1998 V70. I certainly need all front mats, carpeting, and padding. I would like the trunk carpeting due to sun fade and might need the rear carpeting. Would be ideal if all this carpeting came from the same car to show uniform wear.
I'd love a set of rubber mats for the four seats and the trunk.
PM'd
brunocerous
Year and Model: 1998 V70
Has thanked: 284 times
Been thanked: 36 times
Post by brunocerous »
abscate wrote: 17 Jun 2023, 11:43 You can build that hole back with JB weld , non quickset. Plug it up, then after it is set , drill the hole back through using the other side to Line it up. I’ve got an off set of Pagid pads I can send you
Thank you! I went and got some JB Weld yesterday, but when I went to change the other side, the seals looked so bad that I went ahead and ordered replacement calipers.
I managed to get the brake line off, but the threads that hold it in place don’t easily screw back in. Will I need to replace that screw?
1998 Volvo V70 rear brake caliper with broken seal
1998 V70 T5, AT, project
2004 XC90 AWD (sold)
1999 V70 XC AWD, AT (RIP)
1998 S70 T5, AT (RIP)
FireFox31
Has thanked: 158 times
Been thanked: 300 times
Post by FireFox31 »
brunocerous wrote: 19 Jun 2023, 09:15 I managed to get the brake line off, but the threads that hold it in place don’t easily screw back in. Will I need to replace that screw?
Yes, the fittings are likely ruined. See my growing draft thread about caliper failures for info about flaring new fittings.
FireFox31
454cid
Year and Model: 1996 850
Has thanked: 145 times
Been thanked: 130 times
Post by 454cid »
Wow that's nasty looking! I wonder if Volvo/ATE used an inferior grade of iron when making these calipers. I've never seen calipers get so eaten up, and I live in the salt, too.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
brunocerous
There must be something about the salt and the NYC-area potholes that make it particularly harsh. I’m glad I was able to get to the calipers before the completely disintegrated.
Has thanked: 1505 times
Been thanked: 3818 times
Use a Dremel to clean up the threads, and attach the line loosely before you bolt the caliper on. It’s much easier to thread when you can offer the caliper up to the thread at varying angles I’ve found.
jmartin919
Year and Model: S70 GLT SE 2000
Has thanked: 94 times
Been thanked: 39 times
Post by jmartin919 »
foggydogg wrote: 18 Jun 2023, 10:21
bmdubya1198 has that silver S70 with what looks like charcoal mats, I've forgotten what your T5M has.
Can I get more info on that white S70?
'00 S70 GLT SE
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
jmartin919 wrote: 19 Jun 2023, 14:47
In Classifieds… Miata section
viewtopic.php?t=102456&sid=c9babd888ae0 ... 82aa5571fe
There is only one oil stained carpet mat in bmdubya's white car and it is a rear mat in the front foot well. So unless the rest are in the trunk...........?
