bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
xyna wrote: 27 Jul 2023, 09:39 Did an oil change on my V70 today. Now slightly regretting that I bought a V70 with the infamous Magneti Marelli ETM, does anybody have experiences of replacing the throttle position sensor within the unit?
The issue with the ETMs is massively overblown. If you're good with soldering small electronics, it's a fairly straightforward repair. I'm terrible at it, so it didn't go well for me lol.
My best advise is to look for a used genuine Volvo unit that was manufactured after 2013 or so. Those will have contactless sensors and will last.
Has thanked: 1505 times
Been thanked: 3818 times
See the discussion in the ETM forum below. It’s basically a $150 fix if you plan ahead
FireFox31
Has thanked: 158 times
Been thanked: 300 times
Post by FireFox31 »
Checked my credit card bill from the July 4th auto parts store sale shopping that I did. Ouch. What was that about P80s only being worth $1500? Surely my fully rehabilitated ones can be worth... a few multiples of that.
WhatAmIDoing wrote: 26 Jul 2023, 13:33 And today while rotating tires I've learned my brake hose are beging to collapse internally. Oh what a fun weekend I have ahead of me.
How do you know the brake hoses are collapsing internally? Sounds like a diagnostic we should all be aware of.
hausmeister wrote: 27 Jul 2023, 11:47 Worked on cleaning up some Rust... :?
I'm shopping for a used tailgate since my rust there is so bad. Should be easier for my 2000 V70 than your 1995 T5. Good luck.
FireFox31
hausmeister
Year and Model: 1995 850T5-R
Has thanked: 250 times
Been thanked: 77 times
Post by hausmeister »
FireFox31 wrote: 27 Jul 2023, 21:37 I'm shopping for a used tailgate since my rust there is so bad. Should be easier for my 2000 V70 than your 1995 T5. Good luck.
Thx, it is not that bad, not rusted through yet, I think I can fix it. In hindsight I should have done this though as soon as I saw the first trace, as there was more under the glue than I thought.
850 T5-R '95 auto Image
xyna
Year and Model: Volvo 740 1990
Post by xyna »
bmdubya1198 wrote: 27 Jul 2023, 12:14 The issue with the ETMs is massively overblown. If you're good with soldering small electronics, it's a fairly straightforward repair. I'm terrible at it, so it didn't go well for me lol.
I read on another forum that you need to reprogram the car for the new contactless sensor, and some people say that it is a plug-and-play type of installation.
abscate wrote: 27 Jul 2023, 12:36 See the discussion in the ETM forum below. It’s basically a $150 fix if you plan ahead
Yeah, I'm leaning towards repairing it myself, rather than buying a new/used unit. But could it be possible that my gas pedal is failing? The car runs otherwise fine, but once in a while it feels like the pedal is having input lag or something like that. When I floor it, it takes about a second for the motor to react to it. This has happened even with out the ETS light being on.
jsrnsis
Year and Model: P80 enjoyer
Has thanked: 25 times
Been thanked: 68 times
Post by jsrnsis »
Pulled out the whole line of glue and after some rust converter will slap on some paint. Probably not going to look too pretty, but at least will not rust any more. Taking out the window is too much to ask for now, also the rust does seem to only be below it.
I pulled that little trim strip out very carefully by prying it away from the window and trying to pull it out in one big pull. The rest of it I was able to pull out using a small right angle pick, until I sliced open the webbing between my thumb and hand. The metal strip in that trim seems to just rust out, and that area collects so much dust. I was able to cover it up using self-adhesive t-shaped rubber trim from Amazon. I can link what I used when i get back to my laptop.
On another note, I'm getting real tired and real frustrated with seeing "backorded", "discontinued" and "unavailable" on parts websites lately..
And prices going from $55 for a Bosch distributor and rotor to $77 for just the distributor in less than a year.
FireFox31 wrote: 27 Jul 2023, 21:37 Checked my credit card bill from the July 4th auto parts store sale shopping that I did. Ouch. What was that about P80s only being worth $1500? Surely my fully rehabilitated ones can be worth... a few multiples of that.
If you'd want to flip P80s there's an easy formula. A $1000 car plus $5000 in parts becomes a car worth $3000.
If you're looking for a tailgate and have some options, try to find one without the internal latch mechanism. I've only seen one, on a black v70xc parts car around here, that didn't have that internal lever. But it closed much smoother than the ones with the internal lever, and didn't require any force when closing to get it fully latched.
And it will also save you from having to snap that plastic trim piece when you need to get the tailgate panel off.
1998 V70XC black 183xxx
2014 S80 T6 AWD 110xxx
1998 V70XC nautic blue 155xxx
1997 850 GLT 123xxx
2024 Honda CRF110F
Previous Volvos:
1997 850 GLT 239,577
1998 V70 NA silver 202,510
1994 850 NA gray 125,000
1998 V70 NA white 163xxx
bmdubya1198
xyna wrote: 28 Jul 2023, 09:10
No need to program anything, these ETMs can swap from car to car without issue. The only thing is that you need to keep them with the same engine (NA or turbo). I don't know why so many people claim they need programming, that's not true for any of them older than 2002.
Couple of car goofs this weekend
I forgot to clamp off the the hose on the coolant reservoir which eventually popped off and dumped the bottle. No over heat so I just stuck it back and drive 3 miles home, after a two hour run to JFK the day before
Oetikers apparently require some kind of clamping. Killed the level sensor struggling with the bottle though. FCP, baby
Replaced a rear soft brake line on the Kat
Out with the old, in with the new….nice ATE replacement , new design
Dewalt makes a nice tool for removing stuck soft brake lines
bmdubya1198
Whoops... those oetiker clamps work much better when clamped!
ZionXIX
Has thanked: 65 times
Been thanked: 194 times
Post by ZionXIX »
Special removal tool indeed. Is that disc upside down?
