Really enjoyed reading this old thread. Also getting P0305.
Two questions.
1. How do I test the intake manifold gasket using starter fluid? Where do I spray it?
2. Is there a write-up on building a smoke tester?
P0305 Code (misfire code) Topic is solved
songzunhuang
- Year and Model: 98 V70 T5
- Has thanked: 2 times
- Been thanked: 30 times
1. Spray the starter fluid around the intake manifold while the engine is running. Target where the gasket is sandwiched to the cylinder head. If there's a leak, the fluid should get sucked in and noticeably change the way the engine runs. When I had my gasket issue, I kept getting a misfire at cylinder 5. If you have an ODBII reader, you may be able to pinpoint the cylinder and then you can spray there.jzd wrote: 20 Mar 2023, 13:57 Really enjoyed reading this old thread. Also getting P0305.
Two questions.
2. YouTube is your friend. Do a search there. I found most of the homemade smoke testers a bit questionable. I wonder if this is something that one of the AutoParts stores will rent or let you borrow?
Good luck to you.
Song Huang
1998 V70 T5 - Hurt your eyes red
2000 Honda S2000 - Berlina Black
1984 BMW 633CSi - Dolphin Grey
2024 Lexus - Eminent White Pearl
2004 XC90 T6 AWD Ruby red (RIP)
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 97 times
- Been thanked: 340 times
Smoke testers aren't all that expensive.
- foggydogg
- Has thanked: 83 times
- Been thanked: 405 times
I've had this one for a while, works well.jzd wrote: 20 Mar 2023, 13:57 Really enjoyed reading this old thread. Also getting P0305.
Two questions.
www.amazon.com/ANCEL-S100-Automotive-Ad ... s9dHJ1ZQ==
- 2008 Views
Last post by jtp
- 13 Replies
- 3631 Views
Last post by jerseykat1
- 444 Views
Last post by 2forty
- 1233 Views
Last post by blomkvist
- 1715 Views
Last post by FLXC90
