V8 Balance Shaft
tomabras
Year and Model: 2007 S80
Post by tomabras »
Hello,
Are dimensions for tool 9997248 still available (Roger_850T)?
Roger_850T
Year and Model: 854T 1995
Been thanked: 26 times
Post by Roger_850T »
Hi tombras,
The tool is still available to purchase if you prefer. Here is one place that has it for $22.18:
https://www.volvospecialtools.com/index ... E0BBB66715
I think there are also European sources as well.
Here are the dimensions I have for the tool. (Not my photo, but I saved it for reference.)
I hope this is helpful for you!
Roger
11 XC60 137k
08 V50 Project... Still in pieces
05 XC90 V8 213k
95 854T 350k Still my favorite daily driver
02 V70 186k+ Gave to my daughter, still going strong
03 S80 111k (crashed, but driver walked away unhurt)
93 945T 217k (gone to be parted out)
87 245 300k+ sold, still going afaik
84 264 Diesel, RIP at 160k
78 242 manual everything.
73 P1800ES, fun until the rust set in...
Oak123
Year and Model: Xc90 v8
Post by Oak123 »
Sadly rear bearing fails even in upgraded models.
Due to heat protective seal breaks overtime and bearing dries out.
Noticed this at around 340 000 km while changing timing chain for fun :)
bobsepe
Year and Model: 2006 XC90
Been thanked: 4 times
Post by bobsepe »
This can be over come
I packed the area around the rear seal with grease by removing the rear knock sensor and squirting grease through the hole. As the motor warms, the grease melts and lubs the bearing. Pump in about 150 ml grease. To save the bearing this must be done at first sign of noise.
