It will, but this isn’t the same pattern as it would flash when there’s a misfire. This is less of a flash and more of a flicker.RickHaleParker wrote: 01 Sep 2020, 22:02 Wait a second. The CEl will flash if the ECM detects abnormal combustion.
ECM-6300 and ECM-6B00 2000 V70R [BAD Battery to fusebox supply cable!] EPIC Troubleshooting Topic is solved
- Has thanked: 316 times
- Been thanked: 531 times
- Been thanked: 4071 times
Going way back on this, there is an interesting note that the fault code causes your 3Hz flicker, while turning the light on in VIDA does not. That means VIDA has multiple inputs the cel drain transistor..of course it should, and points away from The actual trigger transistor for the CEL, but to those inputs instead
...unless....the transistor is failing in AC mode. Turning it on in Vida is DC
Asking it to pulse might be bringing the filter and voltage regulator circuit into fault.
Can you monitor these voltages during the fault ?
The voltage on the that wire jumps between 12v and a few mV when it's doing this. The pinout shows when the CEL is activated, there should be a few mV (near 0) and when it's off it should be battery voltage.
- RickHaleParker
- Been thanked: 980 times
What two points are you measuring from?bmdubya1198 wrote: 02 Sep 2020, 08:48 The voltage on the that wire jumps between 12v and a few mV when it's doing this. The pinout shows when the CEL is activated, there should be a few mV (near 0) and when it's off it should be battery voltage.
Jumping from 12V to virtually zero is expected across a part of a circuit which is being opened and closed.
1. Voltage across a open is always equal to the supply voltage.
2. A close switch drops zero or virtually zero volts.
A open drops the entire supply voltage everything else in a open circuit drops 0 volts.
Active
Past
Past
- RickHaleParker
Could be a internal ECM defect triggering the I/O transistor when there is no command to turn on the CEL.
Active
Past
Past
I'm getting the voltage reading from the pin on connector 24/13D under the dash and chassis ground. I think it's definitely an internal ECM defect.
There's a command for turning on the CEL, however the signal for whatever reason is intermittent when it should be steady.
- RickHaleParker
Defective bulb test circuit ?bmdubya1198 wrote: 02 Sep 2020, 19:27 however the signal for whatever reason is intermittent when it should be steady.
Does it flicker when you turn the key to POS II but do not start?
Active
Past
Past
Nope. Dead steady as it should be. Only happens when cranking and running.RickHaleParker wrote: 02 Sep 2020, 21:38 Defective bulb test circuit ?
- 837 Views
Last post by jonesg
- 16 Replies
- 4223 Views
Last post by daninater
- 11 Replies
- 9040 Views
Last post by jessefox1092
- 5463 Views
Last post by jonesg
- 3903 Views
Last post by PixelDust
