The Resurrection of (10/1998 to 01/2021, 11/21- 11/25) Elizabeth 1999 V70T5M56 Cylinder Head Job Topic is solved
misha
Year and Model: '97 850 2.5 20v
Has thanked: 152 times
Been thanked: 402 times
Re: The Resurrection of (10/1998 to 01/2021 )Elizabeth 1999 V70T5M56 Cylinder Head Job
Post by misha »
Yes.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
Yup, you'd be able to push them right out at that point.
Year and Model: 2001 V70
Has thanked: 927 times
Been thanked: 999 times
Post by volvolugnut »
Old, highly worn engines might have a ridge at the top of the top ring travel. If the ridge is significant, a ridge cutting tool is used to cut it down so the rings can come past the ridge and out the top.
Has thanked: 1497 times
Been thanked: 3810 times
Still have cylinder Cross hatch and no evidence if oil ring burning on this motor so I’ll be leaving bottom end alone.
Measured the top of block and she is as flat as a pancake, holding for machine shop.
Starter is out and at rebuild shop.
Weather excellent
Has thanked: 1836 times
Been thanked: 1709 times
Always amazed that when cared for how well the engines stand up to wear. Glad it is warming up to manageable temps to allow progress. Here it is not so warm. Up North of Alberta it is -44C without wind-chill!! With wind-chill in the -55 to -60C range. Here in Calgary it is a tropical -35C with wind-chill and to stay this way until next week.
Stay warm and toasty friends!
You know it’s cold when the Canadians complain
foggydogg
Has thanked: 83 times
Post by foggydogg »
"Post by scot850 » February 4th, 2021, 6:01 pm
But you can't fix crazy, even with a length of 2" x4"! I used to do that sort of crazy, but now too old and arthritic for that. Decided it was time to build a heated garage!"
Holy Moose, Neil, nice stuff there. And just in time it seems.
Thanks foggydogg and hoping you are doing well. The garage is what I always promised myself when I retired and especially now the old joints aren't too happy in the cold!
Actually today was cold but with a clear blue sky so wan't too bad.
I'm hoping over on the eastern shores it is much more balmy and allows play to continue on your cars. Abscate is now a man on a mission. Elizabeth will hopefully soon be back in the land of the living!
3 burnt exhaust valves
New seats, guides checked, cleaned
Headtested flat
Machine shop bill about $400 all in
misha
Post by misha »
Additional 2 were about to burn?
I'll be in a head rebuilt job soon because of bad valve stem seals(still original).
Will need to check compression first to be sure the engine is in good shape or is that not necessary?
All info you can provide is welcome.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
