Rattnalle
Year and Model: 2004 V70 2.5T
Has thanked: 20 times
Been thanked: 133 times
Post by Rattnalle »
tyguyc wrote: 04 Dec 2019, 08:01
Rattnalle wrote: 04 Dec 2019, 06:54 The spring for my fuel door broke a few weeks ago. I've been putting it off because I thought it'd be a hassle. Now I checked and the local auto-parts-warehouse has the whole spring assembly for $7. In stock. Guess where I were yesterday?
Ill guess where you was yesterday.
At the local auto-parts-warehouse, spending 7 of your hard earned smackers.
I was there and spent the equivalent of 60 of them but I didn't think to check for this.
So I guess it'll stay broken for another week or two before I go by again.
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1078 times
Post by volvolugnut »
I replaced the lower windshield corner seals again on 2001 V70. Last time was 2012 and removal confirms they were Volvo parts. This time I purchased from FCP with lifetime replacement. Next time (2026) they will be free replacements. This car sits outside all the time.
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 112 times
Post by E Showell »
Bro helped me replace R brake pads (Akebono ceramics) and Brembo rotors. Nice lip on the rotors and pads were at about 2 mm thickness. Not sure what specs are for end of life, but I was getting low speed parking lot pad squeak, so I figured it was time.
We only got the fronts done. Rears are going to have to wait.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
850 LPT
Has thanked: 335 times
Been thanked: 247 times
Post by 850 LPT »
Picked up the 05' V70 5-speed from my indie with a new passenger side axle installed. I'm really glad I didn't attempt this myself. He had a tough time getting the old one out. It wouldn't budge while in the car, so he took the whole carrier out. Then he had to heat up the bearing assembly while pressing it out. Now I have a brand new wheel bearing because he didn't feel comfortable re installing the old one :shock: .
He was not able to fix my "check stop lamp" problem. but he did some diagnosing. It looks like my REM is on it's way out and may have to be rebuilt. Before I spend big bucks though, I will take the tail gate trim off and redo the brake light connector. I have a sneaky suspicion that the pins are not seating properly and the REM is not happy. We will see.
58' Porsche Diesel Junior
13' Honda Odyssey :oops:
E Showell
Post by E Showell »
REM?
'95 855 auto (sold)
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
E Showell wrote: 13 Dec 2019, 18:56REM?
Rear Electronic Module.
Volvo Glossary. Bookmark it.
Active
Past
Has thanked: 1611 times
Been thanked: 4075 times
Rapid eye movements. From dream state of sleep.
I pulled every single fuse from my REM and Dremeled off oxidation on the fuse blades. Very strange. Doesn’t happen on any other fuses in my fleet.
About every 18 months, my rear lights ( marker,turn, brake) stop working until I clean fuse5 or 6
RickHaleParker
abscate wrote: 14 Dec 2019, 03:32 About every 18 months, my rear lights ( marker,turn, brake) stop working until I clean fuse5 or 6
What are you using to clean the fuse and socket?
How is the condition of the socket?
You might need to extract the terminals and replace them.
Active
Past
First few times Scout knife and scraping
When I did the whole REM, I used a Dremel and a stone bit.
Thread on the failure , here
viewtopic.php?f=9&t=73056&p=481181&hili ... se#p481181
RickHaleParker
abscate wrote: 14 Dec 2019, 03:45 First few times Scout knife and scraping
I doubt you got a stone bit or a knife down in the socket.
Spray the socket with MAF cleaner then brush it with a Dental Interdental Brush.
Active
Past
