454cid
Year and Model: 1996 850
Has thanked: 145 times
Been thanked: 129 times
Post by 454cid »
Did? How about planning on doing today? I need to change the oil in the 850. I've got drain plug gaskets and I've got filters, but I think I have to go get some more oil. I only have 1 gallon of Rotella T6 5w40, that I know of. I've got other oil, but I'd rather not mix weights/brands.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
Has thanked: 1505 times
Been thanked: 3818 times
I thought you could mix brands of oil. I know you can’t mix shell and Mobil gasoline ….
454cid
Post by 454cid »
abscate wrote: 18 Oct 2023, 10:45 I thought you could mix brands of oil. I know you can’t mix shell and Mobil gasoline ….
I've been using Shell Rotella T6 5w40. I do have some Shell Rotella Gas Truck, but it's only 5w30. It would probably be ok when cold but I'm afraid it would separate and float on the top of the 5w40 when hot. :shock:
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
Has thanked: 1848 times
Been thanked: 1710 times
Well the 'boss' washed the R today, filled the tank with fuel stabilizer and 91 octane and drove the car 5km home. Hopefully that got some of the cleaner/stabilizer into the whole fuel system. I now have to swap the tires/rims over for the storage set and then cover the car up for the winter in the old (heated) garage. Finally I'll connect the trickle charger and the car can sleep again until next year!
Then have the 06 XC70 winter tires/rims to fit and then clean all the rims and store for next year.
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
That should be enough to get the stabilizer mixed in. She should be ready for hibernation now!
MoVolvos
Has thanked: 310 times
Been thanked: 524 times
Post by MoVolvos »
454cid wrote: 18 Oct 2023, 12:14
First time hearing that oil will separate when hot.
454cid
Post by 454cid »
MoVolvos wrote: 19 Oct 2023, 20:58
It won't. I was trying out-abscate, abscate.
I ended up buying Valvoline's "European" oil. It's a 5 quart jug, so I'll top it off with Rotella T6. Both are 5w40 oils.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
Yeah, I’ve been known to get pick a pun pocket or two here, with some fake news.
Shell plus Mobil equals Schmell is a ‘Car Talk’ Classic
pfmet
Year and Model: V70 1999
Has thanked: 44 times
Been thanked: 22 times
Post by pfmet »
This popped up on FCP’s morning email blast. Pretty interesting.
pfmet
Post by pfmet »
I didn’t do anything to my Volvo yesterday. I’m trying to sort out..
Why was I doing this,
Rather the this?
