MoVolvos
Has thanked: 310 times
Been thanked: 524 times
Post by MoVolvos »
brunocerous wrote: 02 Dec 2023, 06:53 The plastic harness into which the headlight bulb plugs fell apart as soon as I removed it from the assembly, so I went to take one from the T5, and the same thing happened.
I can snug the connectors back on to a new bulb, but is there a more permanent fix?
Though the wire covering is now plastic it's not that bad in the sense that all 4 of our Volvos were worse. We just used harness tape and it was a done deal on all of them. Do not remove any of the broken pieces and just wrap.
Used a similar brand of High Heat Tape for under the hood. Have also use the more softer tape for wiring and harness inside the car. As a matter of fact we use the softer on the S70 wiring below. The High Heat Tape is good for plug wire and others next to the engine.
(www.amazon.com/XFasten-Harness-4-Inch-5 ... r=8-3&th=1)
Wiring Tape 1 (1).jpg (494.91 KiB) Viewed 493 times
Wiring Tape 1 (2).jpg (487.15 KiB) Viewed 493 times
Has thanked: 1498 times
Been thanked: 3810 times
Ran the Kat out of gas for second time in two days. Got distracted chasing a bad battery but then realized my Gauge is sitting at 2’ and AWD cars totalize , not average. I had put one gallon in to get home from the last , drove around for 25 miles, then ran out again.
Instead of chasing red herrings, I measured fuel pressure when stalled. 5-10 psi. Amazing
Runn8jg out of gas symptoms. Slight surging on 45 mph road, then power decline, rough idle m stall
Car will them crank, idle rough as the cavitation gets fuel pump delivers a bit of fuel to injectors, idles 5-10 seconds, stalls. No power, you can’t move car under idle
Too funny.
Abby amd I used solid tow bar method to retrieve car one mile from home , waited an hour for Universoty traffic to slack off until 6 pm, went home , ate pizza, came back and got her safe
I need to cut down a tall tree, so that herring will be useful
Chuck W
Year and Model: 97 854 T5
Has thanked: 96 times
Been thanked: 333 times
Post by Chuck W »
abscate wrote: 05 Dec 2023, 03:05 I need to cut down a tall tree, so that herring will be useful
Or maybe a pair of shrubberies? With one placed slightly higher so you get a two layer effect with a little path.
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
MoVolvos wrote: 04 Dec 2023, 23:10
While the wiring is good now, that headlight is done for. You probably get next to no light out of those reflectors!
Chuck W wrote: 05 Dec 2023, 05:04
Path! Path!
MoVolvos
Post by MoVolvos »
bmdubya1198 wrote: 05 Dec 2023, 08:41
Those reflectors were definitely shot. The pictures were from the October 16th 2022 post when the work was done. The lights are still okay after painting the reflectors and no wiring issues.
Project 2000 S70 SE - LEDS
viewtopic.php?p=611673#p611673
S70 LED 1.png (2.49 MiB) Viewed 463 times
S70 LED 2.png (1.75 MiB) Viewed 463 times
jsrnsis
Year and Model: P80 enjoyer
Has thanked: 25 times
Been thanked: 68 times
Post by jsrnsis »
This car hates me
1998 V70XC black 183xxx
2014 S80 T6 AWD 110xxx
1998 V70XC nautic blue 155xxx
1997 850 GLT 123xxx
2024 Honda CRF110F
Previous Volvos:
1997 850 GLT 239,577
1998 V70 NA silver 202,510
1994 850 NA gray 125,000
1998 V70 NA white 163xxx
Has thanked: 1836 times
Been thanked: 1709 times
Well that certainly sucks. In context, these are near 25-30 year old cars in a rust area. We need to send you more positive thoughts to get you through this latest challenge!
levalexi
Year and Model: 2000 v70 xc se
Been thanked: 6 times
Post by levalexi »
I took advantage of some sale on Walmart the other week and got both LHD and RHD OBX front strut bars. I think it was like 200ish shipped for both
jsrnsis
Post by jsrnsis »
scot850 wrote: 05 Dec 2023, 12:58 Well that certainly sucks. In context, these are near 25-30 year old cars in a rust area. We need to send you more positive thoughts to get you through this latest challenge!
So far the cascade of events being rusted fuel line causing low fuel pressure which caused a backfire which blew out the exhaust manifold which happened to be RTV'd in place and needed the cylinder head to come off as well as to replace some valve stem seals which has led to a broken head bolt. On the bright side, it's on the very front of the engine so it's the easiest to access.
1997 850 GLT 123xxx
2024 Honda CRF110F
Previous Volvos:
