I replaced the heater hoses on my 98 V70 some years ago using standard heater hose. Cut the ferrules off with a Dremel, and it worked great. Problem is that if you want to do this without kinking the hose you end up doing loopdidupes. Has anyone found a way to make a curve or a 90 degree bend in these hoses? I've thought of trying copper pipe fittings, maybe two 45 degree elbows.
Any clever ideas out there?
Heater hose replacement Non-OEM KINKY
- Eddystone
- Year and Model: 1967 Ford GT40 Mk IV
- Has thanked: 63 times
- Been thanked: 81 times
All U.S. market models.
All running and on the road.
- Has thanked: 2215 times
- Been thanked: 1853 times
How about a coil spring inside it?
454cid
- Year and Model: 1996 850
- Has thanked: 151 times
- Been thanked: 139 times
I was looking for just such a thing a few days ago. I found purpose made springs for inside hose on Amazon. I think they were from Earl's. I did not end up making a purchase, as I decided to buy a formed hose for what I'm working on.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
- Has thanked: 987 times
- Been thanked: 1078 times
The auto parts store may have an assortment of heater hoses with formed bends at lower cost than OEM hoses. I found a suitable formed hose for a 240 Volvo flame trap this way.
- Eddystone
As usual, Robert has an answer. One option is the silicone hose do88 kit sold at IPD and FCP.
- Been thanked: 504 times
When I did this heater hose mod in 2015, I just used regular heater hose (Gates brand), the bend was not that bad and it worked fine the way it was modified...
See photo #6 in the thread below and you will see the curve is not that bad.
DIY: 1998 Volvo S70 GLT Heater Core, Heater Hoses Rebuild!
viewtopic.php?t=69238
- Eddystone
I think it probably depends on exactly what brand of heater hose you get hold of. What I had was quite flexible, though I suspect it was Gates.cn90 wrote: 21 May 2022, 19:54 When I did this heater hose mod in 2015, I just used regular heater hose (Gates brand), the bend was not that bad and it worked fine the way it was modified...
- foggydogg
- Has thanked: 83 times
- Been thanked: 405 times
Dr. Abscate is working up this very solution, and I agree, it probably depends on the brand of the hose. That stone-age red stuff is too stiff the do anything but straight in.
hausmeister
- Year and Model: 1995 850T5-R
- Has thanked: 278 times
- Been thanked: 85 times
- 16 Replies
- 4110 Views
Last post by PeteB
- 23 Replies
- 6835 Views
Last post by callahanoffroad
- 11 Replies
- 978 Views
Last post by MoVolvos
- 488 Views
Last post by Richard99
- 20 Replies
- 3566 Views
Last post by Lordflash
