Plug color Topic is solved
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 417 times
Been thanked: 457 times
Plug color
Post by Sveedy »
I decided to look at my plugs today - this is what I found.
Not sure about this color......I'm used to white or black typically. I'd think major head gasket leak, but fresh engine and no signs of coolant issues ( exhaust vapor/smell, drop in coolant level ) so I'm at a loss.
1999 V70 GLT
Has thanked: 1505 times
Been thanked: 3818 times
Dry light powder colour? Might be a fuel additive. Are you running a high end detergent gasoline?
Sveedy
Post by Sveedy »
Actually, yes - a little additive for a long highway drive I took the other day. But less than recommended on the label. Just wanted a little octane boost for higher fuel demands etc for a sustained highway drive.
1999 V70 GLT
Hmmm, I had the correct nostril sniffing on this one! I’ll guess that is it.
454cid
Year and Model: 1996 850
Has thanked: 145 times
Been thanked: 130 times
Post by 454cid »
Although the color reminds me of the coating the swamp water leaves in my trucks cooling system, I believe coolant "burns" white. I pulled and cleaned the plugs in my truck, and the plug with crusty white garbage on it, near the intake manifold coolant leak had quite a bit of white build up. I was actually relieved when Google told me coolant, as that made perfect sense given the known issue. I cleaned all the plugs, checked the gap, and re-installed them.
I need to find my original Volvo plugs. I'm going to see if I can clean them up and re-use them.... I think I saved them just because the 3 electrode design is new to me.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
duke1
Year and Model: 855 1994 10v
Has thanked: 416 times
Been thanked: 34 times
Post by duke1 »
Sveedy wrote: 29 May 2022, 16:58 I decided to look at my plugs today - this is what I found.
hi thats near perfect colour for a sparkplug,black is burnt oil white remnants of ethylene glycol once its been super heated. i would be happy to see such colour a nice tan is good!happy motoring :P
BlackBart
Has thanked: 927 times
Been thanked: 884 times
Post by BlackBart »
Sveedy, my plugs are white with some writing and a little silver thing on the end..............ohhh, you mean the other end!
Sveedy
Post by Sveedy »
^ :lol: I know. I should have been clearer about that.
1999 V70 GLT
