Yellow acc. plug
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 445 times
Been thanked: 479 times
Post by Sveedy »
I thought I'd post this for those wanting to tie into the yellow accessories plug up under the left side kick panel.
For the male prongs, I cannibalized a couple of random plugs from under the hood of a parts car.
Port # 2 on the plug will give you switched power, and port #8 will give you a ground.
1999 V70 GLT
BlackBart
Has thanked: 967 times
Been thanked: 923 times
Post by BlackBart »
Which one for Hyperdrive?
Sveedy
Post by Sveedy »
^ :lol: I've got that covered with Blind Optic Fiber.
1999 V70 GLT
Has thanked: 1611 times
Been thanked: 4075 times
Courtesy of our Friend in Fairbanks...
viewtopic.php?t=99074&hilit=accessory+plug
Accessory connector!
How come no one ever remembers the accessory connector?
Right there under the dash, little yellow 8 pin connector clipped
to the steering column just WAITING for a job like this.
It's got to have some pretty serious self-esteem issues by now... :(
The white arrows are pointing at it ( Ignore the Door Chime legend and it's red circle ) :
98 S-V-C70 Accessory Connector.pdf
Looks like some enterprising individual even came up with a kit for
using the empty mating plug that it leaves the factory with - Sweet!
https://www.ebay.com/itm/254614458625?chn=ps
_
You can also scavenge pins from other JY connectors or even
some styles of stereo wiring adapter harnesses to snap in there.
Has thanked: 2210 times
Been thanked: 1852 times
Thanks abscate for the info and Sveedy for the prompt!
Has thanked: 312 times
Been thanked: 818 times
Post by erikv11 »
Same setup (of course) on an 850, many many posts about this in the archives viewtopic.php?t=69527
