1994 Volvo 940 one headlight is working. New bulb in other one not working. If I put the brights on they both work. Have voltage at the plug, voltage at the relay.
Is it the relay itself? Is there another in the cluster I can swap to check?
Headlights only one working
OK something new. If anyone can help I’d appreciate it. As per my previous post I thought when I put the brights on that both of them were working. As of right now my passenger side headlight only works but my driver side does not. When I put the brights on the driver side bulb lights up but I have nothing on the passenger side. This makes no sense and I change the relay
- Has thanked: 928 times
- Been thanked: 1002 times
Check the condition of the wires near the headlights. The insulation may be failing and giving strange results. This may also cause various, changing faults.
