98 S70 Base B5254s motor - Big Mistake removing rear camshaft seal - trashed?
rockridge
Year and Model: 1998
Post by rockridge »
Hi All,
Been trolling the site for years and there is tons of knowledge here.
So I thought I had a RMS leak but thought I would change out the exhaust cam seal first to see if the oil was coming from there.
I had a tough time removing the old seal so I used a drill for a pilot hole to sink in a metal screw to remove the seal. The drill penetrated not only the seal but the mating surface behind it. I don't know if it is part of the camshaft or the head or what. A 1/2 in. piece of the metal went into the internal engine. Am I now looking at pulling the head to see if I can get the metal shard out and what is the surface that the cam seal sets up against? Am i "screwed"?
Thanks for the help!
Has thanked: 1610 times
Been thanked: 4068 times
You are in luck. On a 98, the cam doesn’t have VVT, so the next piece of metal is just a webbing of the cam cover. I’ll confirm by picture tomorrow. The sealing surface isn’t thiswebbing but the circumference of theccylinder head cover, so a hole won’t matter
I think you are clear of the cam thrust surface but a hole in that wouldn’t matter either.
Don’t sweat that piece of metal. It will just sit in the cam cover. I found a flock of Canada Geese in my oil pan once. The only effect was the oil life was down.
God, thst was awful, even for me.
454cid
Year and Model: 1996 850
Has thanked: 151 times
Been thanked: 139 times
Post by 454cid »
abscate wrote: 11 Jul 2022, 07:12 I found a flock of Canada Geese in my oil pan once. The only effect was the oil life was down.
I don't know what that means, but I can imagine all the poop.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
Chuck W
Year and Model: 97 854 T5
Has thanked: 97 times
Been thanked: 340 times
Post by Chuck W »
No, I know what you're looking at. Kind of a rough-looking hole in the lower part of the casting?
That's supposed to be there. You didn't damage anything.
Install the seal and carry on.
