97 850 GLT break between catalytic converter and pipe to muffler Topic is solved
mkc1
Year and Model: 850 GLT 1997
Has thanked: 27 times
Been thanked: 10 times
Post by mkc1 »
Hi,
My 97 850 GLT has developed a break where the pipe to the muffler attaches to the cat. The shop I've taken it to says they'll have to replace the cat to repair it because they can't weld it back together (partially because there's too much rust, partially because they don't have a welder with a hooked tip.) Does this look like something that could be fixed without replacing the cat to you guys?
Thanks!
ImageIMG_0060 by mkc2006, on Flickr
"Learning mechanics is easier than learning male psychology. You can figure out an engine; you can never figure out a man." -- Pepa Marcos, Mujeres al borde de un ataque de nervios [paraphrased]
1997 850 GLT "Volvo"
1997 850 AWD "Junior" (for parts, sadly)
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Take the car to a shop that know how to use a welder.
It's easy and not more than 10-15 min repair.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Chuck W
Year and Model: 97 854 T5
Has thanked: 97 times
Been thanked: 340 times
Post by Chuck W »
Welding it will most likely be a temporary repair. Getting it clean enough for a good weld is going to be the problem.
foggydogg
Has thanked: 83 times
Been thanked: 405 times
Post by foggydogg »
mkc1 wrote: 20 Jul 2022, 09:05 Hi,
Thanks!
My '98 came to me with three broken motor mounts, and the pipe failed in that exact same place. I took it off the car - not a small job on a turbo, but not hateful - and found a local muffler shop that MIG welded it for me. The guy said using argon as the shielding gas makes it easier to deal with rust; all he did was wire brush the parts, five minutes and $20 later I was on my way.
The biggest problem getting it off the car was the bubble joint under the clamp. Heat is your friend.
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
misha wrote: 20 Jul 2022, 14:44 Take the car to a shop that know how to use a welder.
This is what I've done with four P80 cars, all of which broke at that spot in the exhaust. Take it to the local exhaust shop (not the chain, the local shop) and have them repair it in place. Repairs are still holding up on the three cars I still have. Two of them were done 5 or 6 years ago, maybe I have a good exhaust shop.
mkc1
Post by mkc1 »
Thanks for all the responses! The original shop I took it to decided they could weld in a new section of pipe after all without replacing the cat, so $300 later, it's good. Thanks again!
