'91 240 won't start! trying to help a neighbor.......
TBerlinghof
- Year and Model:
OK gang, here's the story! 91 240 w/over 200K. Running rough last couple of weeks so my neighbor who is 75, God bless him, takes it into a Volvo speciality shop thats pretty good. They charge him $80 for 4 Bosch plugs and tell him it needs an o2 sensor[b].($200 bucks[/i]) [/b]He can't start it, I go over with a can of starter fliud and it won't turn over. I pull the plugs and the are wet with gas! I disconnect the vacuum line to the Fuel Pressure regulator and it starts with a very rough Idle and won't stay running for more than 15 seconds or so. I find a new regulator for $50 bucks local, slap it in and it is still not starting! Tried all the spark issues, good spark from the coil, all plugs are getting spark, tried w/o the mass air meter hooked up, check that the fuel pump was pre charging the system....looking for some new tricks to get the 'ol heap running! As always thanks for any insight! TC
TC Berlinghof
'01 S60 T5 Geartronic, K&N, Mobil 1, couple of goddies from IPD's catalog!
(Wife's daily driver, My weekend project!)
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
You can access fault codes on this model using the diagnostic unit in the engine compartment.
Go to https://www.matthewsvolvosite.com/chat/p ... php?t=9708 which is a post I did on this subject. It is applicable to the 240, 740 & 940.
Go to page 2 and scroll down.
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
- 12 Replies
- 9754 Views
Last post by Saimon3
- 447 Views
Last post by Everet Miller
