1997 V70 subwoofer & amplifier installation
woodhead
Year and Model: 1997 V70
Post by woodhead »
Does anyone have any pictures or tutorials on how to install a subwoofer & amplifier in a 1997 (mk1) Volvo V70? I think I only found 1 hole to run the power cable from the engine compartment to the cabin, but it's in a damn tight spot. My hand doesn't fit there and none of my tools fit so I can't cut a hole into cable bushing.
Not my car but pretty similar:
Goupil
Year and Model: 98' V70 LPT
Has thanked: 30 times
Been thanked: 112 times
Post by Goupil »
I ran the power cable for my fuel pump on the driver (LHD) side, there's a grommet with spare holes (you need to cut the "cap" to use them). You can undo the 2 shock nuts holding the fuse box and remove the airbox to get some room, cant exactly remember how much I had to take off.
It then runs under the dash and in the conduit under the carpet on the driver side to the boot
edit: checked on the car and i actually used this piece of tubing that's already going through the firewall, I'm mixing up things with the cruise control install on a 940
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
woodhead
Post by woodhead »
Goupil wrote: 16 Aug 2022, 12:07 I ran the power cable for my fuel pump on the driver (LHD) side, there's a grommet with spare holes (you need to cut the "cap" to use them). You can undo the 2 shock nuts holding the fuse box and remove the airbox to get some room, cant exactly remember how much I had to take off.
with a cap like this on top?
Do I have to cut it or will it come off? I seem to recall seeing this suggested in the past, but I recall the last time I checked there was already some wire coming through the cap so I gave up on this one.
Goupil
Post by Goupil »
Yep one of those, there should be at least one spare unless some aftermarket stuff has already been wired
woodhead
Post by woodhead »
Goupil wrote: 16 Aug 2022, 14:37 Yep one of those, there should be at least one spare unless some aftermarket stuff has already been wired
I have to recheck that one tomorrow. I have no idea what has been installed but a thin wire if I recall correctly comes through the cap and goes somewhere but not to the battery.
