Passenger Axle Seals - 04 XC70 Topic is solved
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
br0dy519
Year and Model: 2004 XC70
Has thanked: 126 times
Been thanked: 116 times
Post by br0dy519 »
Hi guys.
Why do I do jobs on Sundays? I'm doing the passenger side balljoint, wheel bearing, and CV axle today. The CV axle came out so easily I was surprised. Problem is it took three seals/orings with it it looks like. When I look inside the bevel gear, it looks like there are two wells for the two smaller seals. Any idea on these? I'm booting up VIDA now but if someone has a quick answer it would be great. Need the vehicle tomorrow :cry: wonder how screwed I am
04s60 2.4
04xc70 2.5t
Has thanked: 1509 times
Been thanked: 3827 times
I’ll guess someone left an old oring on the axle..
Parts 5 and 8
br0dy519
Post by br0dy519 »
Upon closer inspection.. it looks like it may be one seal teared to bits. The one piece is a big circular spring
04s60 2.4
04xc70 2.5t
br0dy519
Post by br0dy519 »
Oh you look to be right abscate. Isn’t this seal very dodgy to replace. I’ll look into it. Thank you.
04s60 2.4
04xc70 2.5t
br0dy519
Post by br0dy519 »
Correct P/N : 9143885 , Corteco 1034061 available at 1/4 cost of the Volvo P/N.
abscate's post is at the rear diff. I was replacing the front passenger CV when it happened, so here is the diagram and correct number for the front. This guide helped me : https://www.matthewsvolvosite.com/angle-gear-leak-fix/
VIDA repair instructions show the job is an easy 2 minute fix. Pry old one out with screwdriver. Grease and set new one in. Easy peasy. Car will be back on the road Tuesday as long as I can source the seal locally.
Thanks!
04s60 2.4
04xc70 2.5t
