I have another thread running on this issue but it made me think as to how the security system should work on a 97 assuming no chipped key.
If the immobilizer is tripped, I can't recall in an 850 if the engine will still turn over but it kills the injectors power or fuel pump pressure?
97 850 won't stay running - Security system question
- Has thanked: 2203 times
- Goupil
- Year and Model: 98' V70 LPT
- Has thanked: 30 times
- Been thanked: 114 times
On my M4.4 V70 I've tried a key without the chip, it starts for like half a second then the immo kills it
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
Thanks Goupil. Appreciate your reply. I am now continuing the subject on another thread that started on a different path but has now merged with this one. When you says the immo kills it, what does it kill? Electrical feed to ignition, can't be starter as it did start first time, but them once the immo is tripped when you turn the key does it try to start again or do you get nothing?
viewtopic.php?t=101018
Thanks,
Thanks,
- Goupil
Not sure what the immo is cutting, might be able to find it by looking at wiring diagrams. I'd say either the ignition or the fuel pump.
As far as I can remember, I think you need to go back to pos.0 on the ignition to get it to crank again. I'm currently using a non-immo ECU but I can throw a spare one in to try again.
Any help is appreciated!
Thanks,
Thanks,
