Downpipe Extra Unused Fitting
rrres
Year and Model: 1999 v70XC
Has thanked: 12 times
Been thanked: 34 times
Post by rrres »
Noticed that there's some kind of tack welded fitting on the down pipe, just before the flex pipe. What's this for? It doesn't look like a threaded fitting. I'm looking for a place to install an o2 sensor for an AFR gauge and was wondering if I can use this.
downpipe extra fitting.jpg (79.56 KiB) Viewed 642 times
It's blowby
Has thanked: 2200 times
Been thanked: 1852 times
Do you have a heatshield?
rrres
Post by rrres »
scot850 wrote: 26 Dec 2022, 19:45 Do you have a heatshield?
Yeah, It has a heat shield and was temporarily removed in that photo. It was held on by three bolts: one on the downpipe flange, then the other two bolts at the top of the exhaust manifold. The fitting in question is way down there, next to the angle gear flange. It's about 3/4 inch diameter with an 1/8 inch diameter center hole with some kind of pin sticking out of the center hole.
It's blowby
No idea what the lower one is for. Sorry.
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 445 times
Been thanked: 479 times
Post by Sveedy »
I'm no expert, but I think that location would be too close to the turbo. I seem to remember that when I installed mine, it was to be installed apx 18" away from the turbo. I am using the front o2 sensor bung for mine, but I have a tuned ECU from Vast, and Aaron has instructions on how to do that switch.
1999 V70 GLT
Sveedy
Post by Sveedy »
1999 V70 GLT
rrres
Post by rrres »
Thanks for the replies.
I was watching the "SimplyVolvo" youtube channel and saw that the downpipe on his 850 had two of these tack welded things.
I found another photo online which shows the same things.
It's blowby
VanBoisvert
Year and Model: 1995 Seat Marbella
Post by VanBoisvert »
Have you installed it? I am waiting for your reply. Please reply to me soon.
Edit: Still waiting.
Chuck W
Year and Model: 97 854 T5
Has thanked: 97 times
Been thanked: 340 times
Post by Chuck W »
Is it mounting for additional shielding or whatever due to it being AWD?
