Tires? What do you recommend?
I need new tires on my 2013 S60. Currently have Hankook 215/50 ZR17. Should I go with same? What is a great, reasonable cost tire for all seasons. I live in NY, have snow in winter, but it's plowed regularly. Any thoughts?
- BlackBart
- Has thanked: 967 times
- Been thanked: 923 times
Today? Yes.
But seriously, if you're in snow country, an "all-season" tire does none of the seasons really well (or well at all). If you have the budget, you can get a spare set of factory steel wheels or used alloy wheels for a dedicated winter set of tires. Easy to swap and free with no mounting and balancing.
You might do some browsing for suitable tires here at Tirerack.com.
https://www.tirerack.com/tires/TireSear ... rmance=ALL
I entered your 17" size for a search. You can sort results by category. They can also ship to a local shop to you for mounting.
* Also.... avoid Chinese tires and Euro-sounding tires that are in fact Chinese (Example Laufenn) The Korean and Taiwan brands have good reputations. The Bridgestone Blizzak is a VERY good snow tire with no studs. The General Altimax Arctic is a good bargain snow tire (General is part of Continental, a good tire). You probably can't lose with Michelins. Goodyears are generally overpriced.
I can't keep up with all the models out there. You can read the reviews / tests / and comparison charts on TR for a specific category of tire and learn a lot. You may find it has "decent, decent, good," and then a lousy rating in some critical category. If that's an important attribute I want it to have I write if off immediately. I like a good average of excellents and very goods and price.
If you shop only by long mileage, you'll get a hard tire with little grip. Conversely, you don't need a high performance sticky summer tire, which will wear out fast and be lousy in anything slippery.
- Has thanked: 987 times
- Been thanked: 1078 times
Thanks for the summary of what you should look for in a tire for various conditions. And to consider tires for only specific conditions.BlackBart wrote: 09 Jan 2023, 13:49 Today? Yes.
- BlackBart
Nope. And it isn't really the tread pattern or the symbols on the sidewall - it's the rubber compound and road temperature. It can be just cold and dry and a generic all-season just won't stick. A Blizzak has completely different rubber compounds and the porousness of the rubber cells and it sticks to ice and cold roads. They're actually quite impressive. That said, they will wear out FAST on warm dry roads.AlanS wrote: 09 Jan 2023, 16:07 So, I guess there is no 'hybrid' tire...great for all purpose. I don't plan on driving that much in the snow, so I will try to look for a performance minded tire.
A high performance summer tire is very sticky on warm roads. On cold pavement, it can't stick. It may be decent in the wet. There are made-up categories now called high performance all season and ultra performance all season. I don't even know what that means. I think it means that it has half decent wet and chilly weather performance but is stiff enough so that it doesn't wallow around and roll off the rim at high speeds on sports cars.
- kallekula
- Year and Model: S70 2000
- Has thanked: 58 times
- Been thanked: 75 times
Used to always have two sets of tires for my cars when I was living in Sweden. Most people do. The winter tires sat on ugly steel rims and had studs. Winter tires didn’t need to be studded but are superior to M&S tires on icy roads. Certainly don’t miss changing tires every winter and spring
BMW 540i 2002
S70 Base 2000
- Has thanked: 1613 times
- Been thanked: 4078 times
Alan, you really don’t need a winter tire down on Long Island. Unless you are in forced , must drive job situations, a decent all season will do. Our winter is pretty mild.
- 14 Replies
- 7101 Views
Last post by GBS
- 14 Replies
- 2455 Views
Last post by bmdubya1198
- 19 Replies
- 3736 Views
Last post by precopster
- 910 Views
Last post by jimmy57
- 1557 Views
Last post by pgill
