Urgent help with vacum Lines
xcreator
Year and Model: 1997 s70
Has thanked: 1 time
Post by xcreator »
Hey everyone
I have a 1997 volvo S70 2.0 Turbo GLT 226hp European
I bought it thinking it was all good but noticed the turbo was a bit sluggish and late 3500rpm kicking in and a big suction sound when hitting throttle.
So i was going to check the waste gate adjustment and noticed the massive problem in hand.
For starters, the waste gate pipe was connected to a PCV line and many other vacuum lines just cut off with a screw blocking it, very shocking.
So with help of this forum i found some diagrams and good help but I have 3 more pipes i can not figure out where it goes.
I have the Turbo control valve now connected right.
Below i will put photos of what i have so far and also the 3 mystery lines i need to know.
Thanks every one in advance, any help is welcome and appreciated.
On The first three photos is my Turbo control valve how i have it connected according to the diagrams.
The 4th and 5th photo is the 2 mystery pipes labeled D and E i don't know where it should go, they are broken plastic pipes i am guessing comes from PCV not sure if its both or just one of them, any which way i don't know where they should go.
And last photo is the other mystery pipe labeled G, i don't know where it goes, it's under the intake manifold.
Also on last photo i have pipe H witch is going to the PTC on the intake pipe near the Turbo entrance on compressor side, this i connected according to diagram.
So if someone could help me decipher where D, E and G go
Thank you so much for your time
Mystery 1.jpg (68.25 KiB) Viewed 661 times
Mystery 2.jpg (42.3 KiB) Viewed 661 times
MYstery 3.jpg (45 KiB) Viewed 661 times
WhatAmIDoing
Has thanked: 104 times
Been thanked: 105 times
Post by WhatAmIDoing »
E should connect to an elbow coming off the PTC nipple I believe. Can't quite tell where the other lines are relative to the engine. I think the long vacuum line that runs under the manifold connect to a port somewhere on the timing side of the engine and the other end connects to the turbo?
xcreator
Has thanked: 1 time
Post by xcreator »
Thank you for your response
Next to E is line D its a ticker plastic line in the same rubber sleeve as E, is this the one you say must go to turbo?
But i have all the turbo lines conected as on photos.
Line G is bewteen a gap of the 2 metal pipes of the intake manifold at the moment it was conected to the vacuum tree.
xcreator
Has thanked: 1 time
Post by xcreator »
D and E are mounted on the right side of the engine on the turbo side of it. and G is on the left side if you facing front of the car
Goupil
Year and Model: 98' V70 LPT
Has thanked: 30 times
Been thanked: 114 times
Post by Goupil »
I'd guess D and E are the two lines going to the PTC since they're wrapped in this foam stuff
If I remember correctly, the small one of the two goes to the front of the intake (under the vacuum tree)
Some pictures on this thread might help
viewtopic.php?f=1&t=28487
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
xcreator
Has thanked: 1 time
Post by xcreator »
Thank you
That semms right ill check this out tomorrow
thank you once again great help
moses3
Year and Model: 1997 850 GLT
Has thanked: 68 times
Been thanked: 5 times
Post by moses3 »
This video should help
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
This may help even more: viewtopic.php?t=63615
