My 94 T5M and the 93 NA 20V manual I parted out for the manual swap of my 96 R have a brake light switch that thread into the bracket and have 2 wires to it.
The brake pedal switch on my 96 AT has a different switch bracket and a brake light switch that bolts into the brackes and has a yellow connector woth 4 pins.
What are the extra pins for? Do they give a signal to the Transmission module so you can't burn up the converter while stepping on the gas and brake peadal simultaneoisly?
And most importan: can I use the 2 pin switch on the 3 pedal unit for the manual swap of my 96?
96 brake light switch Topic is solved
454cid
- Year and Model: 1996 850
- Has thanked: 145 times
- Been thanked: 128 times
I replaced mine on my 86 850 NA last year, when cruise stopped dis-engagingly easily, and then someone told me my brake lights weren't coming on. It's a two circuit switch, and one circuit appears to be for the lights, and the other for the shift interlock. When I removed the old switch, but still drove the car for a day or so to work, I had to use the shift interlock bypass button in order to get out of park.
I think my switch just snapped into place.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
454cid
Some how they work together, though.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 93 times
- Been thanked: 146 times
Confirming -
Automatics have an extra set of contacts for
the shift lever interface release solenoid.
If you don't depress the brake pedal,
the car won't let you shift out of Park.
You should be Good to Go for a stick!
- Clemens
- Has thanked: 473 times
- Been thanked: 219 times
Cool. Good to know. Now I hust have to find out which of the 2 wires are for the brake lights and which are obsolete.
update:
I found a wiring diagram. red yellow are brake light, green and blue/yellow are the shift interlock.
update:
Summer: 1996 855 R
Winter: 1994 855 T5M
Donor: 1995 854 10V
Donor: 1995 854 10V
- 13 Replies
- 4619 Views
Last post by S40volvo2007
- 11 Replies
- 6062 Views
Last post by Memark
