I officially want to sell this. Location: Antlers, Oklahoma. I am willing to be a bit flexible on price. Make offer.
Info: 1998 volvo v70 RED 5-speed manual, GLE/SE (volvo trim ID), 2.4NA (non-turbo). Mileage: 165,xxx on odo, 358,xxx on chassis, 256,xxx on motor.
The good:
Its a manual! Pick a gear! Sip gas at 30mph in 4th (1500rpm) or put your foot down at 30mph in 1st (4500rpm).
Overall mechanically sound
timing belt kit done about 30,000 miles ago (by a previous owner)
heater core changed by me (about 12/2021)
PCV done (about 12/2021)
all fluids changed recently (3mo or less)
AC is cold; does NOT leak (replaced the Schrader valve)
new Wolo horns (used by activating green led button seen in pic of steering wheel)
4 QC 3.0 USB ports (used by activating yellow led button, both 12v ciggy sockets replaced)
new alignment
wheels freshly balanced
like new tires
new spark plugs
has 3rd row seats (see pic, has only half installed, other half does not fit with full size spare (donut included)
has premium 811 stereo with AUX
all factory speakers replaced with new Skars (tweeters look jank but fancy!)
good transmission and clutch (90%?)
full size spare
like new headlights
like new turn signals
has hitch receiver
NEW fuel pump (starts right up, no problem)
new oil dipstick
new oil cap gasket
new coolant thermostat (engine operates at 10C lower temp)
i recently did a complete overhaul on the sunroof seal. Does NOT leak.
hauls lots of big things like couch, lumber, and even a pool table (moved a friend)
tows small (~2000LB @55mph) loads very well without electric brakes
it offroads really well!
LOTS LOTS LOTS LOTS of extra parts included. If current switches, blower motor, o-rings, foglights, etc break, you can simply replace them with these extra parts! Timing belt kit, front metal bumper with styrofoam, scv70 steering wheel part of that LOT of parts.
The bad:
missing front courtesy lights
needs engine mounts (i will provide 1 of 5 mounts needed)
the exhaust stinks (can be detected while stationary, window down)
has the slightest fluid leak when first turned off
2nd row driver side seatbelt does not work (needs to be replaced)
The ugly:
scratches, dents, peeling clearcoat.
This is the 'give-me-the-ugliest-look-you-can-but-im-still-cute' type of car.
headliner included but recently removed, stripped of cloth, and cleaned to later install shag; will not complete
Car is from Ohio: I completely overhauled a rusted out windshield 12/2021. I treated the rust. Glass pros sealed and installed windshield. I washed he car on Sunday 4/16/23. Did not see a leak.
I had an accident in this car; someone in 2000s f150 pulled out in front of me. I swapped the hood. The bumper cover has some damage (see pics). Engine was not touched except for the finger loop at top of dipstick.
UPDATE1: FS ugly but reliable 98 v70 red 5 speed for sale, $2400, Antlers OK Topic is solved
- CIK7
- Has thanked: 328 times
- Been thanked: 87 times
- 20230416_184855.JPG (520.35 KiB) Viewed 494 times
- 20230416_184921.JPG (534.93 KiB) Viewed 494 times
- 20230416_184945.JPG (454.88 KiB) Viewed 494 times
- 20230416_184957.JPG (496.48 KiB) Viewed 494 times
- 20230416_185049.JPG (445.59 KiB) Viewed 494 times
- 20230416_185133.JPG (387.8 KiB) Viewed 494 times
- 20230416_185241.JPG (424.35 KiB) Viewed 494 times
- 20230416_185325.JPG (313.56 KiB) Viewed 494 times
- 20230416_185505.JPG (392.15 KiB) Viewed 494 times
- 20230416_185602.JPG (437.06 KiB) Viewed 494 times
- 20230416_192307.JPG (324.18 KiB) Viewed 494 times
- CIK7
The cheap metal universal knob adapter snapped. Now feels more like shifting with factory with it being shorter by about 6 inches. Also I might swap the 5 spoke wheels (pictured above) for the s80 2.9 wheels i originally put on (pictured below).
- 20230123_093046(0).jpg (372.42 KiB) Viewed 476 times
- CIK7
Disregard this comment.
