For sale: Ugly 98 V70 NA gle/SE red 5-speed MANUAL $2200 Antlers Oklahoma
CIK7
Year and Model: 95 854T & V70trailer
Has thanked: 328 times
Been thanked: 87 times
Post by CIK7 »
Make an offer.
Info: 1998 volvo v70 RED 5-speed manual, GLE/SE (volvo trim ID), 2.4NA (non-turbo). Mileage: 165,xxx on odo, 358,xxx on chassis, 256,xxx on motor.
The good:
Its a manual! Pick a gear! Sip gas at 30mph in 4th (1500rpm) or put your foot down at 30mph in 1st (4500rpm).
Overall mechanically sound
timing belt kit done about 30,000 miles ago (by a previous owner)
heater core changed by me (about 12/2021)
PCV done (about 12/2021)
all fluids changed recently (3mo or less)
AC is cold; does NOT leak (replaced the Schrader valve)
new Wolo horns (used by activating green led button seen in pic of steering wheel)
4 QC 3.0 USB ports (used by activating yellow led button, both 12v ciggy sockets replaced)
new alignment
wheels freshly balanced
like new tires
new spark plugs
new steering rack
fresh power steering fluid (valvoline ATF)
has 3rd row seats (see pic, has only half installed, other half does not fit with full size spare (donut included)
has premium 811 stereo with AUX
all factory speakers replaced with new Skars (tweeters look jank but fancy!)
good transmission and clutch (90%?)
full size spare
like new headlights
like new turn signals
has hitch receiver
NEW fuel pump (starts right up, no problem)
new oil dipstick
new oil cap gasket
new coolant thermostat (engine operates at 10C lower temp)
i recently did a complete overhaul on the sunroof seal. Does NOT leak.
hauls lots of big things like couch, lumber, and even a pool table (moved a friend)
tows small (~2000LB @55mph) loads very well without electric brakes
it offroads really well!
LOTS LOTS LOTS of extra parts included.
The bad:
missing front courtesy lights
needs engine mounts (i will provide 1 of 5 mounts needed)
the exhaust stinks (can be detected while stationary, window down)
has the slightest fluid leak when first turned off
2nd row driver side seatbelt does not work (needs to be replaced)
Both rear windows need new window motors
The cute: It's name is the Rotten Tomato!
The ugly:
scratches, dents, peeling clearcoat.
This is the 'give-me-the-ugliest-look-you-can-but-im-still-cute' type of car.
headliner included but recently removed, stripped of cloth, and cleaned to later install shag; will not complete
Car is from Ohio: I completely overhauled a rusted out windshield 12/2021. I treated the rust. Glass pros sealed and installed windshield. I washed the car on Sunday 4/16/23. Did not see a leak.
I had an accident in this car; someone in 2000s f150 pulled out in front of me. I swapped the hood. The bumper cover has some damage (see pics). Engine was not touched except for the finger loop at top of dipstick.
96 964 silver, 146K, diff&trans/engine self-destr, crushed 😭
CIK7
Post by CIK7 »
Price change ^ $2500 to $2200.
CIK7
Post by CIK7 »
For now, I am keeping it.
