2009 V50 6DCT450 Gearbox issue TCM-0482
Dangermouse79
Year and Model: 2009 V50 2.0D
Post by Dangermouse79 »
Hi everybody,
Any chance I could pull on your extensive knowledge? :D I have a 2009 V50 2.0D that is slipping in odd gears until finally getting the Transmission Low Performance light and losing the odd gears altogether along with reserve. The fault code I am getting is TCM-0482, Clutch Odd Gear, Torque Signal, Plausible Signal. I have already change the oil (there was over 1 litre too much in there), and changed the solenoids on the valvebody. Still getting the same result.
Maybe the input turbine speed sensor next?? Any help would be much appreciated.
Regards
Darren
