A/C stopped working
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
Metallo
Year and Model: XC 70 AWD 2.5 - 2006
Has thanked: 7 times
Been thanked: 6 times
A/C stopped working
Post by Metallo »
Hi folks,
2006 - AWD XC70
The A/C no longer blows cool air, so I ran a VIDA diagnostic and got the following:
If I press the AC switch it does not look like the compressor starts.
According to my wife, the radiator fan is always on, and it became very noisy.
My questions:
  • Is the part below the one supposed to be defective?
    Snap 2023-06-30 at 17.50.59.png (88.48 KiB) Viewed 357 times
    How can I be sure that the sensor is the issue?
    If the sensor is the problem, do I need to empty the system before replacing the sensor?
Thank you!
Alex
Polar 940 Turbo SW - 1997
jonesg
Year and Model: 2004 V70
Has thanked: 69 times
Been thanked: 479 times
Post by jonesg »
They usually have a check valve that allows swapping out without losing gas.
Has thanked: 1500 times
Been thanked: 3810 times
Look for specs on the sensor for voltage or resistance as a function of pressure and see if it is responding in good faith. Inspect the connector and wiring carefully forcuts and bruises
That’s the last steps in diagnostics
chrism
Year and Model: S80 / 2005
Been thanked: 78 times
Post by chrism »
As a test to verify a faulty sensor, can the wires be temporarily jumped (bypassing the sensor) to see if that will call for the compressor to engage? That is a common test on the older models.
Metallo
Post by Metallo »
Could you please confirm if the sensor is the one I posted in the above VIDA screenshot?
If so, I guess I need to remove the front bumper to access it, am I right?
Thanks you all for your advice.
Alex
jonesg
Post by jonesg »
remove the air dam , see if you can reach up.
I took my air dam off 6 yrs ago, still have it someplace.
jonesg
Post by jonesg »
Mine was similar, you might have to drop rad and intercooler out the bottom together, you should be able to get to the sensor.
Metallo
Post by Metallo »
Thank you guys, I will give it a shot and see if I can get to the sensor.
Has thanked: 292 times
Been thanked: 765 times
Post by erikv11 »
chrism wrote: 01 Jul 2023, 05:22 As a test to verify a faulty sensor, can the wires be temporarily jumped (bypassing the sensor) to see if that will call for the compressor to engage? That is a common test on the older models.
Yep, absolutely.
Remove the connector, carefully run a wire across the two terminals inside the connector, start the car see if the AC engages. Only use for short-term test.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
P80GLT
Has thanked: 154 times
Been thanked: 176 times
Post by P80GLT »
When my A/C compressor seized Vida gave me a pressure sensor fault code therefore the code doesn't always mean the sensor is faulty. More checks need done before you change the sensor
1997 850 GLT website
2010 XC90 SE...SOLD
2005 V70 2.5T SE
