steering rack torque specs
5rivers
Year and Model: V70 1998 T5
Been thanked: 14 times
Post by 5rivers »
Greetings everyone,
I came across an online manual for the 850 and found the torque specs for the steering rack.
But, for the life of me, I cannot find my notes or the online manual.
Does anyone have the torque specs for the 15mm bolt/nuts that secure the rack to the subframe?
And the torque specs for the one bolt with the 18mm nut on the steering rack?
My car is a '98 V70 T5 auto
Appreciate your help!!
5rivers
1998 V70 M56, silver/grey, has tranny issues, #?# owner, 330,xxx miles, a handy parts car
1998 V70 AT, nautical blue, 2nd owner, 260,000 miles, Sold
1998 V70 AT, T5, forest green, 3rd owner, 172,300 miles, Mimas 16" rims
5rivers
Post by 5rivers »
Here is what I have found after looking for the past hour:
rack to subframe bolt/nuts - 37 ft lbs (I am presuming this for all the bolts with 15 mm heads and the one bolt/nut with the 18 mm head)
rear engine mount - 37 ft lbs
subframe bracket bolt 177 ft lbs Need your HELP on this, please!
(not sure if this is for the bolt with the 18 mm head or those with the 14 mm heads OR both? - for the triangular brackets)
Sway bar bolts ??ft lbs??
Extra info:
tie rod nut - 52 ft lbs
locknut (aka jamb nut) 52 ft lbs
5rivers
Has thanked: 1855 times
Been thanked: 1717 times
Subframe large bolt, 105Nm + 120 degrees angle torque.
Procedure for this is in the info I e-mailed you in the RackReplacement document.
Sorry, can't post that here or we get in trouble!
5rivers
Post by 5rivers »
Thanks for your reply and email :)
5rivers
You are welcome!
Has thanked: 1508 times
Been thanked: 3827 times
I have a spare Haynes manual I’ll send you Kally, but give me a few to find it.
5rivers
Post by 5rivers »
That is very nice of you!
5rivers
