Radiator leaking where upper hose connects.
- 02V70
- Year and Model: 2002 V70XC
- Has thanked: 53 times
- Been thanked: 40 times
The top outlet pipe on my radiator had a crack running through it parallel and was leaking coolant. I put a bunch of rtv around it and put the hose on, and it lasted about a year. (2-3k-ish miles.). Now it is leaking again. How can I fix this? Is there a way I can repair it, or do I need a whole new radiator? I think there is metal underneath the cracked plastic. Can I try to cut all the plastic off so that the hose grabs onto the uncracked metal?
2002 v70 X/C 288k miles
- 02V70
I replaced the head gasket about a year ago. I’m pretty sure this is what caused it.dikidera wrote: 29 Jul 2023, 03:37 Test for blown head gasket. I blew my radiator at that junction from overpressure. The hole was massive.
- 02V70
New radiator time I guess… Fcp has a nissens one on sale. Is that a good brand? I have seen other threads in this forum of people getting that one with no problems.
Also if I have to order transmission line clips does that mean I have to drain the transmission fluid?
Is there anything else I should replace while I have the radiator out that isn't that expensive? Right now, I'm going to replace the upper and lower hoses.
- Has thanked: 987 times
- Been thanked: 1075 times
Search MVS for threads on how to replace the radiator. It can come out the top or the bottom. Pick working standing up or lying on your back with the car on blocks.
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 532 times
They get broken by clamping down too hard with the hose clamp.
Better if you can order the original spring clamp.
Remove elec fan.
drain coolant , disconnect hoses,.
Disconnect tranny line, drop both rad and intercooler out the bottom.
Transfer threaded clips to new rad and push both intercooler and new rad as one unit together up from below,
Stand them on a milk crate whilst you insert bolts from the top.
Drain trans fluid from old rad into a cup to measure loss, it was less than 1/3 cup for me.
Remove elec fan.
- 3560 Views
Last post by t3yf5g
- 13 Replies
- 7053 Views
- 616 Views
Last post by jonesg
- 12 Replies
- 5666 Views
Last post by difflock54
- 11 Replies
- 2512 Views
Last post by bob850
