Where is this additional vacuum hose supposed to be connected?
HenryScott
- Year and Model: V40 2019
In the 1996 850 Turbo, there is a vacuum hose running from the intake manifold to the vicinity of the fresh air intake, where it connects with the turbo. According to the hose diagram on the hood, it should be connected to the PTC connection. However, the issue arises because the PTC connection already has a vacuum hose connected to it, along with the PCV hose. The question is, where is this additional vacuum hose supposed to be connected?
- Has thanked: 311 times
- Been thanked: 817 times
Check all vacuum hose connections, someone may have jumbled up the routings.
Vac lines on a 96 850 are the same as on n a 98 x70: viewtopic.php?t=63615
