AW 71 driveshaft wanted
- Has thanked: 927 times
- Been thanked: 1002 times
Do you have front and rear shafts with a center bearing? Do you want used? No salvage yards near by that have this? I think this may be the same as 240 drive shaft.
- davep84
- Year and Model: 2000 S70 GLT
- Has thanked: 1 time
- Been thanked: 9 times
I have the rear one and the front used a center support bearing. I just can't reuse the front half because it got damaged upon removing the center bearing. Used would be fine. I wasn't aware that the 240s shared the same driveshaft. Unfortunately I haven't had much luck at local salvage yards. Thanks for the reply.
