Right rear shock bad.
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
02V70
Year and Model: 2002 V70XC
Has thanked: 53 times
Been thanked: 40 times
Post by 02V70 »
On my 2002 V70XC, the right rear side of the car is bouncy indicating a shock failure. All of the other corners are fine. I know it's recommended to replace in pairs, but what would happen if I only replaced one of the rear shocks?
Is it possible to just replace the shock and not the whole coil assembly? I know you can easily do it on the non XC models, but it seems the shock is attached to the spring on mine.
If replacing the shock requires a spring compressor, would I still need a spring compressor if I replace the shock/coil assembly?
Do coils wear out often? Based on this photo is the ride height lower because of a worn spring?
2002 v70 X/C 288k miles
Has thanked: 1505 times
Been thanked: 3818 times
Replacing one shock is fine if it failed for a defect rather than being worn out.
There are a lot of internet parrots who spew lore without understanding of mechanical function.
02V70
Post by 02V70 »
My Volvo has almost 300k miles and I’m not sure when or if the suspension was replaced, so I’m assuming it’s failing due to being worn out.
Skymongrel
Year and Model: 2023 XC90, S80 2007
Has thanked: 19 times
Been thanked: 19 times
Post by Skymongrel »
Congrats on 300k! Nice. You probably already figured this out but the rear shocks are self leveling shocks called Nivomat shocks, and are really expensive. You can convert to regular shock from what I understand. You should confirm that your car hasn't already been converted.
To my eye the ride height looks normal? Get a tape measure and compare the wheel to fender measurement for both sides. If they are very different then you might need new coil. I believe you can replace the coil or shock independent of one another. Also, check shock for leakage, if it's bad you should see where hydraulic fluid has leak out.
For the record I've never replace my rear shocks on my XC70...but I did have a coil break on my front struts!
02V70
Post by 02V70 »
I don’t think I have nivomat shocks since they don’t look as thick and don’t have the rubber boot. I inspected the other side rear shock, and although it works, it is leaking. The front ones look fine.
Should I replace the whole assembly with the coil or just the shock part?
The measurement of both wheels are the same
br0dy519
Year and Model: 2004 XC70
Has thanked: 126 times
Been thanked: 116 times
Post by br0dy519 »
This doesn't help you now, and I Haven't done this job yet, but some crazy bird on here used the spare tire jack somewhere on the suspension to make this job easier. I believe the solution was highly praised. Worth a search of the forums.
I replaced the rear shocks on my 2.4 s60, and they were just shock absorbers. No springs back there.
04s60 2.4
04xc70 2.5t
Skymongrel
If it were me I'd just replace the shock. I just measured the wheel to fender distance on my 2006 XC70 and got 3 inches. They are original shocks, I have 190k. I have 3 inches all the way around (fronts were changed). BTW I think I saw that jack method you referred to ...I wasn't a fan, but then I've never done the rear replacement. Good luck.
02V70
Post by 02V70 »
That's what I will end up doing. I ordered two Sachs shocks for $60 each from Rockauto and a spring compressor. The rubber bushings seemed fine so I will probably reuse those too.
Blacklab467
Year and Model: 2007 xc 70
Has thanked: 114 times
Been thanked: 263 times
Post by Blacklab467 »
Here’s the link to a post that I did on this job a couple years ago, it’s easy and can be done in a few hours with basic tools. Hope this helps.
viewtopic.php?p=588012#p588012
2003 XC 70 (sold)
