I am at the point where I want / need to upgrade my brakes to the larger 302mm, but I know that there are clearance issues with some / most 16" wheels.
I saw the write up on here about big brakes on small wheels, but the writer references Columbas, while the picture looks like Perfos.
So what fits what, and is grinding necessary ? And are some of the parts available from junkyard P2's ?
Edit: I finally found the pictures of Volvo wheels, and I do have Columbas, not Perfos on Sveedy. Pic in write-up is correct.
Will the larger 302mm brakes fit Perfo wheels Topic is solved
- Has thanked: 2854 times
- Been thanked: 1332 times
I'd guess no. The wheels are so similar in appearance and spec, I can't believe they'd be different enough to avoid the bracket modification reality.
Perfo
Size: 6,5 x 16
Offset: 43MM
Rec Tyre Size:
excl AWD 195/50 ZR16 87W*
AWD 205/55 ZR 91W
Columba (from Big Brakes on Small Wheels)
Size: 6,5 x 16
Offset: 43MM
Rec Tyre Size:
excl AWD 205/50 ZR 87W*
AWD 205/55 ZR16 91W
Perfo
Size: 6,5 x 16
Offset: 43MM
Rec Tyre Size:
AWD 205/55 ZR 91W
Size: 6,5 x 16
Offset: 43MM
Rec Tyre Size:
AWD 205/55 ZR16 91W
- foggydogg
- Has thanked: 83 times
- Been thanked: 405 times
Thought about doing this using spacers myself.
Note the comment about the regular space saver not fitting the fronts after wards.
- Goupil
- Year and Model: 98' V70 LPT
- Has thanked: 30 times
- Been thanked: 112 times
Columba don't fit, Perfos do.
I've sold my Columbas so can't compare IRL where the difference is, maybe the shape of the barrel ?
Columba pictured here, my Perfos are out of reach on the top shelf under three layers of headliners
Gotta get those repainted and throw some tires on them
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
- Sveedy
- Has thanked: 445 times
- Been thanked: 479 times
The more I think about, I'll just wait and get 17" rims regardless at this point. The clearance between caliper and inner wheel is a little too close for my comfort / environment. One little rock popping up in there, could ruin a wheel.
" We need clearance, Clarence "
1999 V70 GLT
1999 V70 GLT
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 97 times
- Been thanked: 340 times
Perfos fit.
That's what we've run as back-ups on her car with the 302's.
- Been thanked: 4063 times
Perfos are better wheels anyhoo…..Colombo’s are always asking you questions….
- BlackBart
- Has thanked: 967 times
- Been thanked: 921 times
HARR!!
I love Columbas - the curved hub area reminds me of those shaped wooden WWI era propellers. The Perfo is a modernized, more anglular version of it.
- 36 Replies
- 2536 Views
Last post by Nevada1906
- 1024 Views
Last post by Chuck W
- 457 Views
Last post by misha
- 3123 Views
Last post by 93Regina
- 653 Views
Last post by tryingbe
